April 05, 2025, 12:51:54 pm *
Pages: [1] 2 3 4  All
Author Topic: XXHE 1.186a on Win7 - what went wrong?  (Read 49988 times)
nik.d
« on: February 22, 2014, 01:22:02 pm »
Yesterday re-installed Win7 back, now having 'Conversion Error' repeating on several albums randomly chosen.
XXHE reports RAMdisk full while only one (standard, 16/44) CD loaded on 4GB RAMdisk.
The content of playback drive is interesting: first file is ok (size/bitrate) but all others are not.
On albums with less tracks there's no 'Not enough space' message, XXHE goes to unattended and one track is played.
Thanks!
George
« Reply #1 on: February 22, 2014, 01:39:53 pm »
George,
First off, congrats with your new system (well, looking at your sig ... yes) That is ... hmm ...
First quick question :
Did you try this without Playbck Drive (just empty the field for it) ?
Native .WAV files normally play ? (if you need to try, first answer the question above to gain some speed).
« Reply #2 on: February 22, 2014, 01:42:16 pm »
Next question :
When you play Attended, will the next track automatically play ? You can drag the time cursor (in the bottom) towards 1 minute before the end to gain some testing speed here.
nik.d
« Reply #3 on: February 22, 2014, 02:11:54 pm »
Thank you Peter, I like seeing long row of yellow LED's, he he.
I've already booted to normal OS to see what's happening.
- Loaded one album previously showing errors: 18 tracs FLAC files, no RAMdisk.
Conversion errors again, XXHE goes to Unattended and plays track. I'm able to select and play next track with 'Alt+N'
- Loaded native WAV, 21 tracks, no error window/message shown
- Same in Attended w/ WAV - no errors
« Reply #4 on: February 22, 2014, 02:23:20 pm »
George,
Attended is just that and this is not Normal OS.
Did you empty the field for Playback Drive ?
I can of course repeat all the questions, but it would be more useful if you just answer them. Ok ?
(so revisit what I asked please)
nik.d
« Reply #5 on: February 22, 2014, 03:30:28 pm »
Understood your question first time but I did (re)booted from Min to Normal OS while waiting reply. I'm not mixing Unattended/Attended and Min/Normal OS Happy
Back to MinOS and no RAMdisk started at all. 'Playback drive' field cleared of course (did it in NormalOS already).
- Unattended FLAC 'Conversion Error' for all 18 files (this album). With 'Alt+N' can advance to next track - with new series of error messages.
- Attended FLAC plays OK, can move time slider for next song etc.
- Native WAV plays OK both Un- and Attended
« Reply #6 on: February 22, 2014, 03:44:00 pm »
If this is to be understood as "playback automatically advances to the next track" then ...
Right from the start I expect a multi-threading issue. But I don't know how to test it further.
You mean, did not start at all ?
Anyway, I don't want to scare you, but I suppose you don't have another LGA2011 processor laying around ? If so, test it. If not, what to say ...
(Anthony never received any issue, if you know what I mean ... (but of not, just ask))
If you go to TaskManager and rightclick on a random process and choose Change Affinity - do you see all the processor cores ?
Btw, you can try to switch off Hyperthreading (in the BIOS) and see whether it makes a difference.
nik.d
« Reply #7 on: February 22, 2014, 04:18:01 pm »
No, playback not automatically advancing, you suggested this 'to speed up things' in testing.
RAM disk should be read as "I have not created any RAM disk(s)"
16 LED's present and active. Slow an cool Happy
Have you looked at pics #3 & #4?
Same album, in RAM disk: first file ok, 30MB / 1411kbps (std 16/44) while all others (2nd marked) 2.58KB only and 3072kbps
This is where XXHE shouts 'Hey you, No Disk Space Anymore!' Happy
« Reply #8 on: February 22, 2014, 04:26:10 pm »
Oh boy. George, if you are not able to "detach" problems from eachother, we will never get anywhere.
Now do this and do not do anything else :
- Attended.
- NO PLAYBACK DRIVE.
- Start Play on a list of FLAC's.
This stops at the end of the 1st track ?
nik.d
« Reply #9 on: February 22, 2014, 04:55:33 pm »
Oh boy indeed. OK:
Min OS
Attended
No RAM disk.
Problematic album: Jesse Cook, The Blue Guitar Sessions, 14 tracks
Play does not stop. It continues to next track. And next. No problem at all.
Same album
XXHE in RAM
RAM Playback drive
Unattended play
Results with error seen on pic #1.
The content of RAM Playback disk/folder is shown in pics #3 and #4.
First file is converted OK (30MB) others are 2.58KB only
« Reply #10 on: February 22, 2014, 05:02:00 pm »
Yes. And if you "concentrate" on one problem at a time, your second list would not suddenly have changed 5 things. So if I were you I would have made that second list with one change only (compared to the first attempt / first list) : Play Unattended (and change nothing else). Thus :
- UNattended.
But I think you have already done this, but not sure because of all your mixes. But tell me explicitly.
If still no go :
Do you have an album with MP3's ? When you try this, doing that according above list is sufficient.
nik.d
« Reply #11 on: February 22, 2014, 05:19:16 pm »
Unattended
Error messages all over
XXHE continues with shutting services, plays first track.
First track ended
XXHE stops and exits unattended
nik.d
« Reply #12 on: February 22, 2014, 05:21:53 pm »
No MP3 on this PC/HDD's, can copy from 'work PC'
nik.d
« Reply #13 on: February 22, 2014, 05:29:29 pm »
MP3
Unattended
Error decoding...
Track plays
EDIT
And stops/exits unattended after first track.
« Reply #14 on: February 22, 2014, 05:37:16 pm »
Do you have a W8 OS disk readily available ?
Did you already try my Hyperthreading Off suggestion ?
