November 23, 2024, 12:17:16 pm *
Author Topic: SQ of WAV vs M4A  (Read 24312 times)
« Reply #15 on: February 11, 2014, 12:37:12 am »
Now that checksum will tell you if they are completely identical. If you're only one sample off (even one byte) than the checksum will not be the same. This is the difficulty, you cannot know how your rip is comparable to the presumably unripped ' cloud'  version. They have to be from the same source AND have the same start and end samples. So no padding or truncing allowed...otherwise you'll end up with an unequal checksum even if the music is 100% the same.
I'd say only the CD ripping process gives reproducible results unless there is some smart checksum that is able to match the actual music data with a reference regardless of padding/truncation.
On a more DIY track you could align the two datasets on peak values in a (hex) file or music editor (pick a channel and search for nice extremes) than you can observe if the dataseries before and after the peak are exactly the same. Of course with the absolute sample magnitude. If not: they will not be equal enough to sound the same!
regards, Coen
« Reply #16 on: February 11, 2014, 04:16:20 pm »
Another graph from a CD and an ITunes track (256kbps). The WAV of the iTunes record was created with the internal device.
It is here very well to see, that the frequency was cut reduced to well below 20KHz.
Peters remark about the "Virus program" is ............ .
« Reply #17 on: February 11, 2014, 05:15:32 pm »
Joachim,
I am glad you can see/confirm that "well below 20KHz". But I don't see it or don't know where to look. sorry
« Reply #18 on: February 11, 2014, 07:04:02 pm »
Joachim,
In the middle of the .............. .
« Reply #19 on: February 11, 2014, 07:11:15 pm »
I must be thick ...
So you like riddles eh ? Too difficult for me.
