April 09, 2025, 01:39:43 am *
Author Topic: 1.186a Change WP pop-up  (Read 15480 times)
Tjeerd
« on: February 07, 2014, 02:08:56 pm »
Hello Peter,
I’m using XXHE version 1.186a on an audio-PC (W7Pro / i7 / 2x SSD / NAS), playing in unatt. and min-os, and I get (some times) the following pop-up;
Change WP
Error setting the Wallpaper: Er is een generieke fout opgeterden in GDI+
The music plays (by the way, his version off XXHE sound very very good) and the wallpaper appears. So there seem to be nothing the matter except the pop-up.
Question: what to do?
Greetings,
Tjeerd
« Reply #1 on: February 07, 2014, 02:42:03 pm »
Hi there Tjeerd,
Is this with Q3,Q4,Q5 = 1,1,1 ?
If yes then the OS has too much difficulties with showing the wallpaper (no matter it does appear) and I think this error can occur. Solution : don't show the Wallpaper (see Settings).
But is this 1,1,1 the case ?
Tjeerd
« Reply #2 on: February 07, 2014, 03:58:11 pm »
Correct, i use setting 1 for Q3, Q4, and Q5.
Tjeerd
« Reply #3 on: February 07, 2014, 04:02:47 pm »
Tjeerd, you can also try change the SFS slightly and see whether that helps (and now leave on the Wallpaper showing of course).
Tjeerd
« Reply #4 on: February 08, 2014, 11:36:06 am »
Thanks for the tip.
At this moment a have disabled “At Attended” (blue) in the CoverArt setting, and so far this seems to help (with Wallpaper showing).
Tjeerd
« Reply #5 on: February 08, 2014, 11:45:39 am »
Uhm Tjeerd ...
And that ChangeWP popup came from UNattended ? Or did I just assume that ...
Tjeerd
« Reply #6 on: February 08, 2014, 01:11:27 pm »
Correct. Unattended.
Tjeerd
« Reply #7 on: February 08, 2014, 01:19:09 pm »
Odd !
Hmm ...
Tjeerd
« Reply #8 on: February 25, 2014, 11:26:20 am »
Hereby an update.
I have changes the SFS setting 16 days a go form 120x120 to 12x12 (and still playing with this setting and with “Wallpaper showing”).
The pop-up is still appearing, but only when playing FLAC-files (resolution 16/44,1 - 24/88,2 – 24/96 – 24/192).
Showing Wallpaper:
-   Sometimes the wallpaper shows after a few minutes (the music is already playing).
-   Sometimes the wallpaper don’t show at all (the music is playing).
-   Sometimes the pervious wallpaper is still showing at the moment a new album is starting (the pervious will disappear and the new one shows).
-   When playing FLAC-files the track indication (mirror side of the wallpaper) stocks at the first track.
Any ideas’?
Greetings,
Tjeerd
« Reply #9 on: February 25, 2014, 01:25:02 pm »
Hi there Tjeerd,
Thank you for the update. But ideas ? I already told I'm afraid : don't use the Wallpaper (or don't use the 1,1,1 setting Wink).
But a question : Suppose you make 0,0,0 of Q3,4,5 - do you then still see that back of the FLAC album stuck after the first track ?
Tjeerd
« Reply #10 on: February 26, 2014, 02:29:39 pm »
I will try 0, 0, 0 for Q3, Q4 and Q5 and let you no what happens (and listen carefully for sound changes).
Just a question for you:
When will XXHE perform (sound, processor use, memory use, etc) at his best;
A – just playing Flac-files as it is?
or
B – Convert Flac to WAV (with FLAC Frontend) and play this converted file?
Greetings,
Tjeerd
« Reply #11 on: February 26, 2014, 06:12:29 pm »
Tjeerd,
If all is right it will not matter - but use a Playback Drive. Next you will see that each kind/sort of Playback Drive matters ...
bdohmeyer
« Reply #12 on: March 03, 2014, 03:38:14 pm »
I have Just purchased 1.186a, and it sounds great.
I get the same error, and I read that the Q settings might have something to do with this. Are there any standard/generic settings for Q, SFS, and Clock Resolution that I could start from which might help prevent the error from occurring?
Processor i7 970: 3.2GHz-3.46GHz, 6+6 cores/ W7 Ultimate 64bit SP1 / Mb Asus X58/ RAM 24GB/ OS and XXHE on Samsung 111 SSD,  WD RE4 WD5003ABYX, 500Gb, 7200rpm, 64Mb cache playback Drive, WD20EFRX Storage drive, PSUSeasonic Platinum 660 + - 2%.
XXHE 1.186a/ Metrum Hex w/ USB Hi Face module/#4 Engine/ Adaptive/ 512/ Straight Contiguous/ PP:Low/ TP:Real Time/ Clock Res. 1ms/ Allow Ph. Alig.:Off/ HDCD:On/ ALL Services Off/ SFS:120 Unattended/ Minimize OS/ Peak Extend: On/ IPhase Off/ ArcPredict/ fx:On. Output x 4/ Q1=6, Q31,Q41,Q51. xQ1=10
Preamp:XX.  (Hex Straight to Amp). Amp:AR Ref 150 (Sovtek KT120s),
Coincident Total Victory II (96dB 1m@1 watt)
« Reply #13 on: March 03, 2014, 04:34:58 pm »
No, sorry ...
Well yes, set Q4 to not 1 and the same for Q5. But that violates the SQ severely.
Just shut off the showing of the Wallpaper in Settings for sure avoids the error message. So solution : don't show the Wallpaper Coverart.
Can't make it better or at least not at this moment (but will look into it).
Page created in 0.012 seconds with 19 queries.
