November 23, 2024, 08:22:32 am *
Author Topic: XXHE 1.186a "crashes"  (Read 21283 times)
Stanray
« Reply #15 on: February 08, 2014, 12:55:34 pm »
OK, great. I will install it.
« Reply #16 on: February 08, 2014, 03:13:02 pm »
Well, this has been solved. How ?
Apparently Windows is "capable" of setting the PATH environmental variable wrongly. What exactly was wrong with it I could not see, but *if* something is wrong it just won't work and executing something while being in a certain folder (like the XX folder) while the program is in c:\windows\system32\ then won't work.
So for others, mind this please. A solution is available.
Stanray
« Reply #17 on: February 08, 2014, 10:29:33 pm »
Thanks again Peter for this "remote surgery".
I see you left some mysterious folders and files behind ($Recycle.bin; Recovery; System Volume Information).
Not to be touched I suppose?
Stanley
« Reply #18 on: February 08, 2014, 11:14:56 pm »
Hi Stanley,
Peter probably unchecked a "view" option in the Folder Options to be able to see some system files and folders that are normally hidden.
Doing this helps when trying to diagnose some problems Happy
Stanray
« Reply #19 on: February 09, 2014, 12:13:08 am »
Of course, I see.  yes
Thanks Alain.
Stanley
