March 31, 2025, 11:56:10 pm *
Author Topic: Room EQ with XXHighend?  (Read 12226 times)
minzyman
« on: January 27, 2014, 01:44:10 am »
Has anyone addressed room correction when using XXHighend, with digital EQ filters such as Fab filters or some Win version thereof? I have a few nasty room dips in the bass, about 15db dip at 60Hz and again at 120Hz and the bass response in my room is quite weak. This is especially apparent near the right speaker, where the wall configuration is different from the left side.
I have a friend who is running a Mac system and has several Fab filters addressing a few issues in the bass (only) on his system and the bass response is awesome, the kick drum and low level detail really gets your foot tapping.
Any digital EQ software out there that is recommended to work with XX?
Thanks.
/LM
W8 = Jan 10, 2013 (1.186a)
Zalman (Fanless) Chassis with ZUMA Design: Intel DH77EB MB and Intel i7 3770s (quad core) CPU / 16GB RAM / Win 8 Pro SP1 from OCZ SSD / second (Playback) drive OCZ SSD / music on 3 TB eSata HD / XX on OS disk SSD Engine#4 Adaptive Mode / Q1/-/3/4/5 = *6*/-/*1*/*1*/*1* / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = *4.0* (max 120) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = *Core1-2* / UnAttended (Just Start) / All Services Off  / No Running Time / Minimize OS / NO XTweaks / 24/768 Phasure NOS1 async USB DAC, Driver v1.0.3 at *8ms* -> main amps -> speakers. No remote, screen off at unattend playback, cd rom unplugged, ethernet cable unplugged, max core temp 117 degrees F.
Stanray
« Reply #1 on: June 02, 2014, 12:37:37 pm »
This post didn't get much attention.
On the CA Forum f.i. (http://www.computeraudiophile.com/f23-dsp-room-correction-and-multi-channel-audio/dirac-24-192-when-18496/) I read that Dirac software isn't ready for 705600/768000 or 352800/384000 files.
Are there any other developments?
Thanks.
Stanley
Robert
« Reply #2 on: September 24, 2021, 11:19:22 pm »
I've just read Kal Rubinson's latest review in Stereophile on Dirac Live 3. This software is certainly improving and by all accounts easily audible to ones ears.
Is it time to include the ability with Xxhighend to enable such programs?
Others get good reviews audiolense, Acourate to name two.
The listening room is the most problematic for most listeners. Certainly mine has some serious problems.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #3 on: September 25, 2021, 10:54:49 am »
Dear people,
There is no single way that such software will be doing anything good to your sound. I don't know whether it is in this topic, but with some tricks I once had it running, and it totally kills the sound.
Of course we all have our standards, and for example Robert's can't be judged, but for anyone owning a NOS1 this really is not working out.
Best could be to try e.g. Foobar and get a bit used to the sound, and then try something like Dirac Live. You sure will be able to "equalise" the room (better : listening position), but there will be no listening joy. Thus my promise : net it will be worse.
I did not read Kal's review, but know that he is (almost ?) exclusively in multichannel. That is fine, but maybe not for us.
Page created in 0.011 seconds with 19 queries.
