November 23, 2024, 09:54:25 am *
Author Topic: Playback stops after 4/5 tracks  (Read 6917 times)
« on: January 23, 2014, 09:40:12 am »
Playback stops after 4/5 tracks have played. My settings are as per my sig.
« Reply #1 on: January 23, 2014, 11:21:34 am »
Hi Arvind,
Question first : Can't you make new topics or something ? I mean, it seems that you announce your problems randomly in other topics ? So I (again) moved this to a new topic for you.
Can you post your log XX, X3 and X3PB log files from such a session ? When playback has stopped, grab the newest X3 and X3PB log files and the two latest XX log files (assumed that you only brough up XXHighEnd ONCE after it happened and then go for the log files).
« Reply #2 on: January 24, 2014, 05:52:43 pm »
While attempting to get the best setting on my set up, I changed the Q1 from 6 to 14 & Q5 from 1 to 5. The SQ is ideal for my set up & it also solved the problem of playback stopping after 4/5 tracks.
However I will send you the log files as reqd by you, if you still need it.
« Reply #3 on: January 24, 2014, 06:02:36 pm »
Thank you for the feedback Arvind. But log files are no longer needed.
