April 02, 2025, 10:08:04 am *
Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19  All
Author Topic: USB to PC chassis ground ? (noise) - The biggest change ever !  (Read 287579 times)
« Reply #90 on: January 24, 2014, 08:02:45 pm »
What is wrong in this picture ?
Well I can see is that there is a USB A to B converter which does not seem like a great idea - unless it has been modified in some way?
toddn
« Reply #91 on: January 24, 2014, 08:18:32 pm »
Kind of hard to tell in the picture, but is there tape around the USB cable shield where it plugs into the adapter?
« Reply #92 on: January 24, 2014, 08:19:27 pm »
Peter - is your PCIe card totally isolated from ground i.e. is the ground on the backplane now also isolated as well as having replaced the bracket with a plastic one?
By the way some time ago I spent much time getting all the grounding and earthing sorted in my system. At that time I played around isolating the USB ground at NOS1 I also lifted the black wire from the USB socket. Also I taped the bracket of the PCIe card to isolate it from the PC chassis but I could not hear any difference at all. Not a jot. The only thing I did not do was lift the ground on the PCIe card from the backplane.
But there were other changes to grounding that made a big difference................. and did not make any sense at the time but maybe they do now?
« Reply #93 on: January 24, 2014, 08:24:31 pm »
The back of the letters NOS! is blue. Can't see the inside of the NOS1  Happy
« Reply #94 on: January 24, 2014, 08:33:27 pm »
Paul, Yes. But I'd say both are the same thing. So I'm sure I'm missing something.
« Reply #95 on: January 24, 2014, 08:43:37 pm »
Something else for a change ...
« Reply #96 on: January 24, 2014, 09:03:01 pm »
Also after the posts about Windows 7 I thought I really had to listen to it again. This time with 1.186 with Q5=1 settings. And the result? exactly the same as before. It is not even close W8 is MUCH better. W8 sounds clear and precise but smooth and never tiring, piano sounds just fantastic the tonal quality of a real instrument comes across and the sound is stay up all night good never tiring. Instruments are separate from the speakers and the bass much better quality detached from the speakers and stereo. I was listening to Britten Peter Grimes the other night there were instruments precisely located in the space behind the speakers bass was stupendous.
W7 does not get even close to W8 it sounds "smudged" less defined rounded over and bass loses its impact sounding monotonic and all from somewhere in the middle.
In fact I could use the same description as Peter did in his comparison but just changing the 7 and 8 around.
Very strange. I really would like to use W7 just to get the album art back but here it just does not sound good enough!!!
« Reply #97 on: January 24, 2014, 09:10:15 pm »
So the sound floates in space, like the electric ground of the nos1 circuits, like the exterior being wrapped.... with space/air (like by spacers of foam)...  And some blanket damping the sound....
« Reply #98 on: January 24, 2014, 09:27:25 pm »
If I remove the metal bracket (the bracket that is now plastic on your card) from a PCIe card and just plug it into the socket on the mobo with no bracket at all on the card so that nothing on the card is touching the frame of the PC and I then measure for continuity between the ground plane of the PCIe card (ie the track around the holes that the bracket screws into) it shows that the ground plane of the PCIe card is still connected to the PC frame (PE). So isolating the bracket only does not achieve anything and the ground pin of the PCIe card needs to be isolated / cut to achieve isolation. I may have missed it in this long thread but is that what you have done to your card?
toddn
« Reply #99 on: January 24, 2014, 09:35:23 pm »
Paul,
I ascertained the same thing about a week ago, reading .1ohms from the card screw holes to the PC casing without the bracket even on the PCIE card. Also, no noticeable change in sound either.
« Reply #100 on: January 24, 2014, 09:35:58 pm »
I have done that Paul.  I did not think it would work but it does.
« Reply #101 on: January 24, 2014, 09:57:25 pm »
The pci-e bus is connected to the mobo ground, wich in its turn is connected to the casing (at the mobo montage screws). No surprises here. Nevertheless, this gnd connection is electrcally far away and more important there is no alternative groundpath anymore.
Imho thats why it works.
Regards, Coen
« Reply #102 on: January 24, 2014, 10:00:46 pm »
Hey Paul,
Then I'm probably saying the same as Anthony does, but the difference is huge. I did not check anything like Todd this though ...
« Reply #103 on: January 24, 2014, 10:02:02 pm »
Hi Anthony - I isolated the bracket temporarily using tape and I could not hear any difference.
Not sure if it has any bearing at all but I had strange result changing the earth layout of my system some time ago (which I posted about then). My amp is 4 x channels (amps) and each is bridged so 8 amps altogether. That does not mean a lot other than because it is bridged it accepts balanced inputs from NOS1. When I first installed the amp I had much trouble getting noise levels down to the low levels they were with my previous SE amp (never believe what anyone tells you about balanced connections ha ha). So I went through everything. The electronic ground of my amp is not connected to PE (ie it is not connected the case of the amp) so the case of my amp is not connected to anything except PE. The last thing I did with the earthing arrangement was to connect the case of my amp direct to the earth spike in the garden (which the PC and NOS1 PE's are connected to also but by a different route). So true star earthing as close as I can get it. That could not make any difference could it? wow what a difference it made probably one of the biggest & most fundamental improvements in my system. Maybe there was hash/rfi (or trafo induced eddie currents) on the case of the amp that are now routed away from NOS1. Maybe for that reason the ground of the USB in my system clean and so lifting the USB ground is not making the same difference it is making for others. Who knows? I don't suppose anyone really understands grounding arrangements anyway? and they are different for different systems and locations. A true black art.
« Reply #104 on: January 24, 2014, 10:12:01 pm »
Page created in 0.016 seconds with 16 queries.
