April 02, 2025, 10:08:05 am *
Pages: 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19  All
Author Topic: USB to PC chassis ground ? (noise) - The biggest change ever !  (Read 287581 times)
« Reply #60 on: January 24, 2014, 11:55:36 am »
You put the NOS1 back in the transport box, drilled holes in the carton and play it from there ? Wink
nik.d
« Reply #61 on: January 24, 2014, 11:58:24 am »
Anyone hungry? A lot of popcorn here  Happy
« Reply #62 on: January 24, 2014, 12:02:16 pm »
The white protection cubes are being used?
« Reply #63 on: January 24, 2014, 12:19:37 pm »
I've pulled the bracket from the PPA card and listened all day today and there is a general change for the worse in a similar flavour to the Silverstone, but only about 50% of the change that happens with the Silverstone.  The symptoms are quite similar but I think I hear only about half of the "buzzing without buzzing" that Peter started talking about.
Thanks for the experiment!
Today I succeeded in getting the silverstone to work with external linear 5V. I am not really exited about the sound, grounding the card helps a little but the sound stays sharp and ill defined. A rather different effect than on the PPA card.
I prefer the sound with the regular PC supply's 5V on the silverstone. Both a grounded and ungrounded bracket have their pros and cons to the sound. Depends on the music what goes best. This is no good and I need a different approach (like reinstalling the PPA card again).
regards, Coen
« Reply #64 on: January 24, 2014, 12:45:11 pm »
regards, Coen
Yeah, I still prefer my ppa card with the subsequent modifications.
Hopefully Peter will end his teasing and let us know what strange brew he has concocted to get the Silverstone sounding right.
« Reply #65 on: January 24, 2014, 12:57:25 pm »
The NOS is swinging in the air on USB cables!
regards, Coen
p.s.
I'd also opt for the protection (styrofoam?) cubes.
nik.d
« Reply #66 on: January 24, 2014, 12:57:49 pm »
...Hopefully Peter will end his teasing and let us know what strange brew he has concocted to get the Silverstone sounding right...
Peter is mentioning need of opening NOS1, doing something in there. I have not opened mine. What (USB thingie) can be isolated fm ground?
« Reply #67 on: January 24, 2014, 01:07:13 pm »
This is unrelated to the riddle tweak as such;
In the right leg there's the main PSU and (being in front of the NOS1) under the top right bolt of that PSU is a black wire; unscrew the bolt, detach the wire (it is not soldered), isolate it's bare end and ticj it through the sleeves at the right side or something (so you at least know where it's *not* going).
Notice : Not the best solution at all because it now may catch "noise" but do NOT detach it from the USB interface as of now because it is too fragile there; also, this is all trialling.
Remember, it is part of the isolation at the PC side, and part of the Silverstone setup and without anything else (like using W8) this will NOT work for the better. So let this wire be as it is for now.
Unless you applied my riddle tweak of course ...
Or anyone did already ?
haha
« Reply #68 on: January 24, 2014, 01:26:11 pm »
It seems easy to try, but a photo will be more reassuring ? And I guess that having the NOS1 disconnected from mains will be safer ?
« Reply #69 on: January 24, 2014, 04:00:17 pm »
Come on now guys, I'm sure you can be more creative !
Ok, a hint. Nothing has been applied here yet. There is a clue in this picture. A small one, but it is there ...
nik.d
« Reply #70 on: January 24, 2014, 04:16:16 pm »
Hmm, 9V battery was included as well, but surely can cost more than 40c
Leo
« Reply #71 on: January 24, 2014, 04:19:44 pm »
1. connected the 9v battery and use it to lift earth potential of the usb  a couple of volts
2. finally got rid of the red light in your mains connectionbox (really Peter.....)
« Reply #72 on: January 24, 2014, 04:27:50 pm »
The only time I've heard anything like 'white-harp' was when I bought a 'Mana Acoustics' platform for my CD player many years ago. They used the resonance characteristic of thick glass sheet to almost tune the sound to 'white-harp'.
So I think the riddle/tweak has something to do with the pink foam pads that come with the NOS1 as 'feet'. (I have a set of pink and a set of white pads. Hey, maybe the colour makes a difference???) Did you buy a particular thickness of double-sided sticky tape to attach them somewhere on the NOS1 chassis? Or maybe using them to isolate/dampen the USB connectors at each end?
Haha, back to the colour idea. Did you buy a specific colour of foam pads? Don't tell me - was blue the best colour?
Well, you did say 'ridiculous'!
« Reply #73 on: January 24, 2014, 04:31:42 pm »
There is a little odd white pad under the power (? usb?) wire on the right of the NOS1.
Did you lift the wiring to the NOS with the foam blocks?
regards, Coen
« Reply #74 on: January 24, 2014, 04:45:17 pm »
I will be monitoring this all the time. Now if you do all too (and I hope some more of you) and keep on shooting, then maybe now and then I'll put in another hint.
When possible I'll try to confirm guesses in the good direction but I will do my best to not unveil all right away. When you hear nothing of me you can bet that the guesses were all over wrong. So, I'll try to be honest. Example of this :
At this moment I can say that one of you has been in the direction fairly well but it is so much off still that it isn't worth mentioning. whistle Still, if that person would know it is him, he would have a headstart which can't be caught up by the others.
Btw, the one who is the first to post the 100% correct solution wins a nice audio attention which for sure will improve SQ and which I have been keeping a secret for almost a year by now. Will be shipped to wherever you live.
This is home brew and let's not start a riddle topic about that.
Funnily enough though this thing is the most highly related to the riddle-tweak. yes
