April 02, 2025, 10:08:07 am *
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19  All
Author Topic: USB to PC chassis ground ? (noise) - The biggest change ever !  (Read 287584 times)
« Reply #210 on: January 28, 2014, 01:28:47 pm »
By the way, when you still mention the "power supply", even if all works fine since I disconnected (and isolated) the black wire, you are not talking about the 2 toroidal power supplies right ? This shows my total lack of knowledge about electronics...
As far as I understand it should be this wire (coming from USB ground) and not the mains ground you might refer too.
See picture.
Peter, correct me if I am wrong!
Thanks Bert for the picture... I forgot it when I came back yesterday... Yes, this is the wire I detached and isolated Happy
« Reply #211 on: January 28, 2014, 01:34:03 pm »
My USB-cable only has D+, D- wires and separate ground wire (no 5V wire). The ground wire can easily be disconnected.
What influence could disconnecting the ground wire have? I haven’t dared to try it (Ok, this also shows my lack of proper knowledge about electronics  blush1)
Stanley
Hi Stanley,
Since Peter has this project, I would say that we're all in the "same boat" and while Peter is the Captain, we are the sailors Happy
« Reply #212 on: January 28, 2014, 01:41:33 pm »
As always, I arrive late, but I also remarked (I am with W8) that there is more weight on the right side. It is obvious. I played a little with the balance (preamp) but it does not completely correct this.
I have another observation, but it is not really related to the isolation from ground... For a while now, I need to increase the volume to get a nice level ? I don't recall having to increase gain like this with W7, but I have not used W7 for many months now...
« Reply #213 on: January 28, 2014, 01:47:12 pm »
While mentioning 'sleeves' you actually wanted to say 'slot openings' on the right side and that wire is put through one of slots?
(Red circled area from /your above/ photo)
Jajajajajaja Happy
« Reply #214 on: January 28, 2014, 01:57:01 pm »
Ok sound quality changes.
Thanks a lot Coen.
Strange remark perhaps :
From the three people in here of whom I think they are able to judge sound (elements !) similar as I do/can, now all three described the same. This makes it a virtual 100% though the data is a bit on the lean side. Wink
Especially when thinking that one of the three is me. Haha.
That it is especially the bass which draws to a (right) side is interesting and another matter; I'd say that for the bass it would be the most difficult (compared to highs) and it makes me think it is the proof of jitter influence (always the most easily heard in the bass); what would be new to me is reasoning how jitter influences one side more than the other (I'm only saying that I never needed to reason over this subject) ...
« Reply #215 on: January 28, 2014, 01:59:59 pm »
Peter, when changing something like isolating the ground from USB... I know what I am to say is not based on anything scientific, but could it be that when the noise patterns change, the filtering changes in some way and is able to extract more details - IOW, a detail that is buried in noise will be emphasized ?
Sorry if it is kind of "childish" and badly described...
« Reply #216 on: January 28, 2014, 02:07:20 pm »
I notice that in your sig you "keep Kan - not persist"... Don't tell me that you have seen people from Star Trek Wink
Google for "Khan (Start Trek" - it will be clearer...
« Reply #217 on: January 28, 2014, 03:09:00 pm »
Adjusted Alain. Thank you.
« Reply #218 on: January 28, 2014, 03:15:56 pm »
Alain, no clue yet. Really. However, we must keep the base idea in mind here :
What I've seen is that the usage of USB changes the DC Offset on the mains and it goes via PE (Protective Earth, not saying that nothing will happen when PE is not in order). Now, DC Offset will always be on the mains (the more apparatus you use the more) so it shouldn't be really that. However, the way USB is used should imply a frequency on the mains; the same as the general DC Offset but now looked at from how it springs (current spikes).
What I do not know is how that will creap into precious D/A chips or clocks in front of it - if at all. But somethings *has* to happen in these directions because it is totally audible.
Maybe you are right somewhere, but it needs to go over the mains first, just because that was my whole idea about it (and now I feel I must have been right haha).
Stupidly difficult ...
« Reply #219 on: January 28, 2014, 03:37:06 pm »
Totally  OffTopic
"Khan is depicted as a North Indian Sikh—"Khan" is a title; his parents are from Chandigarh, Punjab, India..."
Marla McGivers: "From the northern India area, I'd guess. Probably a Sikh. They were the most fantastic warriors."
My parents were (when they were alive) Sikh. And I have to say that Khan is the weirdest Sikh I've ever seen.
Back to USB to PC chassis ground...
« Reply #220 on: January 28, 2014, 04:03:30 pm »
And there is the matter of the right channel tilt. This is less noticeable in the midrange, but bass heavy instruments are constantly more to the right.
PS: Not disputing what you hear, but bass instruments usually ARE placed to the right. (Of course there are many exceptions, depending also on the genre).
« Reply #221 on: January 28, 2014, 06:27:39 pm »
In my system with W8 and with both sides of the USB disconnected the position of the sound image is exactly the same as with both sides not insulated. SQ similar in both cases.
« Reply #222 on: January 28, 2014, 07:14:54 pm »
Juan,
But without isolation (PC side) there is more hum ?
At least that's what I recall you saying ...
« Reply #223 on: January 28, 2014, 08:57:19 pm »
Juan,
The contrary Happy
http://www.phasure.com/index.php?topic=2838.msg29816#msg29816
« Reply #224 on: January 28, 2014, 10:25:53 pm »
Juan,
The contrary Happy
Thanks Alain,
Peter, I´d say that with both sides isolated there is a similar hum as when both sides are non isolated. So, more hum than when only the card is isolated.
Now I have a different problem, lately I´ve been using the NOS1 RCA outputs but today I wanted to test some XLR cables and when I plugged the cables in the XLR NOS1 inputs the meters were reading 0.00mv. This happens with both sides isolated and it was n´t happening in the other cases, with only the card isolated or with none of them isolated.
