« Reply #135 on: January 25, 2014, 12:52:50 am » |
Or "viscous" maybe  I recall the SME tonearm had a kind of stabilizer in some oil, to reduce the effects of warped LPs and vibrations... Alain PS: I think I will follow this to encourage myself and realize a system to suspend my components...
« Reply #136 on: January 25, 2014, 12:59:26 am » |
Yes Alain. And "viscous" would be the proper phenomenon I think. Still it will be the viscosity which determines the damping but attaching in the mean time. It is not so easy. So think of it : speed of sound in water is 3 times or so higher than in air. Doesn't seem right for damping eh ? Also, when being in a swimming pool (under water) - hey Anthony - what sounds are profound ? the lower frequency ones. So it is not so easy indeed ...
nik.d
« Reply #137 on: January 25, 2014, 01:14:59 am » |
Peter, I must admit this is ingenious idea. It can be worked out with very professional look. And some silicone liquid would generate more lifting power. What about Alain's suggestion, hanging NOS1 on elastic stripes or hoses, something similar to what I did for HDD's inside PC: Edit: Below cage is soft, open cell sponge to dampen vertical oscillation.
« Reply #138 on: January 25, 2014, 01:38:15 am » |
Yes...
Floating and/or suspending components is very interesting... Would there be differences - results or should they all be effective...
« Reply #139 on: January 25, 2014, 06:55:02 am » |
« Reply #140 on: January 25, 2014, 08:22:26 am » |
But... Why not simplify this with big enough rubber bands to suspend the whole thing ? Talking about condoms recently, why not...
Have a look at what we drove past today. My wife took some convincing but she finally took my iPad and grabbed this photo from the passenger window of the ute.
« Reply #141 on: January 25, 2014, 08:24:05 am » |
Sorry Peter! I have no idea how to downsize this on my iPad.
EDIT: Got it!!!!
« Reply #142 on: January 25, 2014, 08:56:41 am » |
Have a look at what we drove past today. My wife took some convincing but she finally took my iPad and grabbed this photo from the passenger window of the ute. R u suggesting to use sperm as a floating agent? Regards, Coen
« Reply #143 on: January 25, 2014, 09:15:12 am » |
Not in least Coen. Really, not the least. No. Not at all. No.
Leo
« Reply #144 on: January 25, 2014, 09:24:50 am » |
So I guess my nos1 is sounding extra good because of the magnetic suspension I use .....
Leo
Dedicated silent audio pc HFX classic, Windows 8 pro 64bit / Intel 3930 CPU 6 cores 12 threads, ASRock x79 Extreme4-M/ SeaSonic Platinum 400w ATX PSU / 16Gb RAM , music on (SATAIII), MinOS/ Engine#4 Special Mode / Q1/2/3/4/5 = *6*/0/1/1/1 Qf=1 (Dev.Buffer = 4096) / not Invert / Playerprio = Low / ThreadPrio = Real Time / *Scheme = 1-2* @ UnAttended /Services Off + No Running Time / Octo Arc Prediction Upsampling / *SFS=0,4 max= 120* XT Tweaks balanced load 43, nervous=100, cool when idle 1, Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = On / Double Octo Arc Prediction Upsampling / -> USB with Dexa clock -> 24/768 Phasure NOS1 async USB DAC, Driver v1.0.3 (2ms) -> direct to AMP: Gainclone mid high, Hypex DPS400 low, horn system (tractrix for mid/high, BD for bass with Oris200)
phantomax
« Reply #145 on: January 25, 2014, 12:13:07 pm » |
Hi guys, I had a lot of fun yesterday. Sorry I was too shy to participate although I could never figure out the solution. But here is the proof that we all are in the same boat of fools.  Please forget the dust. It's almost impossible remove it there behind. Maxi
Audio PC -> AsRock Z79 intel i-3 4170 @~800MHz, 16GB, Windows 10 64 bit build 14393.0 from RAM, DIY Linear Power Supply. music on LAN / Engine#4 Special Mode/Q1/-/3/4/5=*30*/-/*1*/*1*/*1*/ Q1Factor = *5* / Dev.Buffer = 1024 /ClockRes = *15ms* /Memory = Straight Contiguous / Include Garbage Collect / SFS = *0,69* (max 0,69 / Phase Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 1-3 / Not Switch Processors during Playback = Off/ Playback Drive none (see OS from RAM) / UnAttended (Just Start) / Always Copy to XX Drive (see OS from RAM) / Stop Desktop, Remaining, WASAPI and W10 services / Use Remote Desktop / Keep LAN - Not Persist / WallPaper On / *OSD Off* / Running Time Off / Minimize OS / XTweaks : Balanced Load = 35 / Nervous Rate = 10 / Cool when Idle = n.a / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Not the best / Time Stability = not stable / *Custom Filtering low for 176400* / Always Clear Proxy before Playbck = On -> Modified Audiotrak Prodigy HD2 internal soundcard with analog tube buffer (Broskie cathode follower) -> Passive biamplification: Canary Audio CA-301 MkII for highs- mids and Counterpoint SA-100 for lows -> Audiovector M-3 Super / modified Musical Fidelity X-3 (6h6p tubes) -> Grado 1000 headphones.
« Reply #146 on: January 25, 2014, 12:28:51 pm » |
LOLOLOL
But that is what I meant; when a visitor comes over he really will think "what is this fool doing ?". It will look like voodoo puppets to a stranger ... as he believes never believes in that so you are crazy.
Thank you for sharing Maxi. Peter
« Reply #147 on: January 25, 2014, 12:32:38 pm » |
And some silicone liquid would generate more lifting power. But that's my point George. All what will create more lifting power will also pass on the waves better (especially the lower freqencies). What about Alain's suggestion, hanging NOS1 on elastic stripes or hoses, something similar to what I did for HDD's inside PC: Should work too. But this starts to approach the footers of good fame, and the bands will always pass on vibration. This is such micro stuff ... Not easy ... Peter
« Reply #148 on: January 25, 2014, 12:59:37 pm » |
So I guess my nos1 is sounding extra good because of the magnetic suspension I use ..... Leo, It should. But, is this completely free floating ? So, I envision a plate just floating in the air (and this technically can exist). And not *any* touching of material anywhere. So you have that ? Picture ? Thanks, Peter
Rob181
« Reply #149 on: January 25, 2014, 01:37:15 pm » |
Hi Guys...a first time poster...I do not have the tech or computer skills that exists in this forum...but thanks to someone much smarter than me...I do have my Amp & NOS1 floating on air...spring isolation. A big thanks to both Peter & Anthony for helping me on my XXHighend journey...it is only the beginning... As a teaser...there is more to come...captured by acg...Rob
