« Reply #120 on: January 24, 2014, 11:30:07 pm » |
Yeah sorry, poor pictures.
I hate those riddle tweaks  . The damn thing is floating in a box of water!
« Reply #121 on: January 24, 2014, 11:30:14 pm » |
Peter, have you recently been abducted by someone or something that did not have a skin colour that is known to mankind ? You sure have a lot of fun... Me too in fact ! Alain
nik.d
« Reply #122 on: January 24, 2014, 11:43:50 pm » |
I hate those riddle tweaks  . The damn thing is floating in a box of water! No Coen, I think Peter added some oil. For Engine #4
« Reply #123 on: January 24, 2014, 11:48:12 pm » |
Zr.Ms Phasure NOS1 or in English : HMS Phasure NOS1 or in American : USS Phasure NOS1 or in Australian : HMAS Phasure NOS1 or in Canadian : HMCS Phasure NOS1 or in Norwegian : HNoMS Phasure NOS1
« Reply #124 on: January 24, 2014, 11:57:21 pm » |
I hate those riddle tweaks  . The damn thing is floating in a box of water! No Coen, I think Peter added some oil. For Engine #4  LMFAO!!!!
tillen
« Reply #125 on: January 25, 2014, 12:05:27 am » |
LMFAO
PC- Asrock X79 Extreme 4-M - i7 4930K Hyperthreading On (12 cores) 32GB, Windows 10 Pro 64 bit build 10393.0 RAM-OS, music on LAN / Engine#4 Adaptive Mode / Q1/-/3/4/5 = 14/-/1/1/1 / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = 0.05 (max 60) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/ Playback Drive / UnAttended / All Services Off / Keep LAN - Not Persist / Minimize OS / XTweaks : Balanced Load = 43 / Nervous Rate = 1 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = Stable/ Custom Filter Mid 705600 / -> USB3 from MB - Sw#3 off NOS1a = Up) -> Clarixa USB-> 24/768 Phasure NOS1a async USB DAC 75B, Driver v1.0.4 (4ms) -> Blaxius BNC interlink
« Reply #126 on: January 25, 2014, 12:07:39 am » |
I hate those riddle tweaks  . The damn thing is floating in a box of water! No Coen, I think Peter added some oil. For Engine #4  LMFAO!!!! http://www.vibratechtvd.com/innovation&technology.html
« Reply #127 on: January 25, 2014, 12:12:32 am » |
LMFAO
Yeah, Peter is LHFAO here  !
« Reply #128 on: January 25, 2014, 12:17:27 am » |
Coen, SHIPping won't take long.
And you know what ? 2 hours ago I betted you were going to win this game. So you did.
We had great fun over here (still have), and all who contributed - great thanks for this fun.
Peter, Ciska, Paul.
« Reply #129 on: January 25, 2014, 12:30:22 am » |
Incredible... A fantastic idea, but very very extensively unbelievably crazy... Now I imagine doing the same with my 60 pounds power amp... And why not the speakers also... Finally each of us should get a boat But... Why not simplify this with big enough rubber bands to suspend the whole thing ? Talking about condoms recently, why not... Alain
« Reply #130 on: January 25, 2014, 12:34:34 am » |
Yes, sure thought about the amps and speakers. Amps (and btw PC) are normally doable, speakers could be a problem.  Oh, when we were designing this house, there were to be chains right through the sealing, those chains connecting to the sealing above that, the speakers just hanging on it. That never happened ...
« Reply #131 on: January 25, 2014, 12:36:36 am » |
George, You were so right in your first post with box and foam. You are also so right in your last post about the oil which it really is intended to be (all about the viscosity and no electrical danger in the first place). Notice though that the foam really has to be some stiff low mass material and that it isn't to tough the surrounding box anywhere.
Todd, You were actually the one who functionally was the most close in an early stage.
Mani, You were right about the colour, but people can really take a grey etc. bag for the "isolation".
Leo, I personally think you should be granted a bigger prize than Coen will receive for this one : 1. connected the 9v battery and use it to lift earth potential of the usb a couple of volts. But as you know, no matter how many times we send you something it will NEVER arrive. However, the dinner invitement is still open.
Thank you all, Peter PS: By positioning the interlinks carefully, you will be able to have the NOS1 floated in the middle without touching an edge of the box anywhere. When you indeed try this with the box provided with shipping, take care that some extra strong material surrounds the box (could be a rope). Indeed it is so when you move your NOS1 it feels really "suspensive" and you can feel how it it now sounds. This is a relation between its mass and the upwards force and oil will make it more suspensive but also more "attaching" to the floor. This is the math needed (what frequency to block). To cover for the hammering sound upon the NOS1 (so not through the floor) it was my idea to put something like a box over it. That simple, but should work (for about the whole frequency range I'd say, but just a feeling).
toddn
« Reply #132 on: January 25, 2014, 12:41:49 am » |
Well, I was kind of on the right track with isolating the equipment from the floor resonance with an inner tube. Just not quite crazy enough to think of floating that inner tube in a pool of water!!! In all my years going to CES in Las Vegas, I have never seen such a thing! Crazy & Genuis are sometimes not to far apart
W10-10074 XX HighEnd 2.03 PC -> i7 3930K AS Rock MB W/ Dexa Neutron Star & linear PS supply mod. For Processor Clock, Hyperthreading On (12 cores) @430MHz (!), 16GB, Windows 10 Pro 64 bit Insider Preview build 10074 Samsun SSD, XXHE on 2GB RAMDisk (IMDisk), music on LAN / Engine#4 Adaptive Mode / Q1/-/3/4/5 = 14/-/1/1/1 / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS W10 = .14(max 60) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / W8 Scheme = Core 3-5, W10 Scheme = Core 1-3 / Not Switch Processors during Playback = Off/ Playback Drive 2GB RAMDisk (IMDisk) / UnAttended (Just Start) / All Services Off / Keep LAN - *Not Persist* / WallPaper Off, W10 Running Time Off / Minimize OS / XTweaks : Balanced Load = *63* / Nervous Rate = 1 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = On / *Custom Filter Mid 705600* / -> USB3 (Silverstone W/Dexa Neutron Star Clock & Linear PS> *Clairixa USB* -> Uptone Regen w/ Dexa Neutron Star & linear PS -> 24/768 Phasure NOS1a 75B (BNC Out) async USB DAC, Driver v1.0.4b (*4ms*) -> Blaxius BNC interlink -> 8 channels of Hypex NCore 400's -> DYI BD Orphean Horns w/ qty-3 custom 15" open baffle bass drivers and qty-8 12" open baffle subwoofers per channel
« Reply #133 on: January 25, 2014, 12:44:08 am » |
Would you describe the sounds as "liquid" or "wet" Peter?
« Reply #134 on: January 25, 2014, 12:51:40 am » |
You can't guess how much we are laughing here. But "boxed" seems not right anyway.
