« Reply #105 on: January 24, 2014, 10:12:45 pm » |
I would not give you a price as a photographer  Up to now, with those pictures, I see pieces of the NOS1 and you attaching your shoe lacets Seriously it has to do with ground and/or isolation, but... Alain
« Reply #106 on: January 24, 2014, 10:14:27 pm » |
Tape ????
« Reply #107 on: January 24, 2014, 10:20:31 pm » |
Hi Paul,
In quick AB testing removing the USB bracket made very little difference to me. However, when I listened to it for a number of days it became unbearable to me (and to Peter it seems) but there are elements to the Silverstone sound that are excellent and so some persistence too get to the bottom of it should be worthwhile. Removing the bracket on my ppa card made a much smaller difference but in a similar vein till the Silverstone.
Time for my morning swim...back in an hour.
PS Paul, you fits finally won a game of cricket yesterday!!
« Reply #108 on: January 24, 2014, 10:24:29 pm » |
It's strange... I don't see the second USB connection, but there is something that looks like a "cap"... Trimpot ? No...
« Reply #109 on: January 24, 2014, 10:33:58 pm » |
Anthony - not sure how much of a win it was with your best players out but hey we will take anything going now!!
Not sure what effect the Dexa's are having in my system as they and their PS are not connected to PE (and definitely sound worse when they are). The clock output is floating as well.
« Reply #110 on: January 24, 2014, 10:37:58 pm » |
OK... I don't see the second USB input ? It has been removed... And aside of the usual USB input, there is something that I can't define... I guess this is part of the isolation process on the NOS1...
« Reply #111 on: January 24, 2014, 10:42:01 pm » |
Dhl tape. Another hint to air/space. Are you using the bubblefoil for the tweak?
« Reply #112 on: January 24, 2014, 10:42:17 pm » |
The USB input is not at its usual place ? Mine is aligned with the "O" and yours with the "S" ? It does not make sense...
Tore
« Reply #113 on: January 24, 2014, 10:52:25 pm » |
Peter is playing with the second usb input
Phasure Mach III, 12/24 core (Win 14393.0 on RAM-OS / controlled by RDC, / connected directly to music server / XXHighEnd 2.11 / Minimize OS / Engine#4 Adaptive / DB=4096 / Q1=10 / xQ1=15 / Q3,4,5=1 / SFS=0.69 max=140,19 /XTweaks = 35, 10, 0, 0, 0 / Straight Contiguous / Clock Resolution = 15ms / Scheme 3-5 (low/realtime) / Unattended) mobo USB3 port -> Lush^3 -> Phasure NOS1a B75 G3 -> Blaxius^2.5 , Crazy A monoblocs, Avantgarde Duo Omega
« Reply #114 on: January 24, 2014, 10:59:51 pm » |
Do you use a Blue Tape ? From one picture it looks as if you have covered a part of the holes "NOS1" from under the cover...
« Reply #115 on: January 24, 2014, 11:14:07 pm » |
The box and Peter are on the ground? Like at ground potential...or iow the NOS1s casing is at ground potential... Than unscrewing the internal pe wire would make sense.
« Reply #116 on: January 24, 2014, 11:18:55 pm » |
LOL
« Reply #117 on: January 24, 2014, 11:19:45 pm » |
« Reply #118 on: January 24, 2014, 11:22:09 pm » |
Its a watering can spray water all over the inside of NOS1 and reduce everything to earth potential.
« Reply #119 on: January 24, 2014, 11:27:18 pm » |
Yeah sorry, poor pictures.
