November 23, 2024, 07:55:45 pm *
Author Topic: Device not supported  (Read 6845 times)
Leo
« on: January 12, 2014, 12:41:34 pm »
A minor problem that I notice since 1.186a is that after rebooting (sometimes) and now once after punching alt n while playing an album allready for a couple of tracks, I get the message that the device can not play, format not supported and some other messages. When I check the settings the device has changed from KS Phasure to Headphone. When I change the device back to KS Phasure it behaves normally again.
Just hickups of W8 or something else ?
regards,
Leo
« Reply #1 on: January 12, 2014, 01:00:47 pm »
Leo,
The basis of this will be the way XXHighEnd allocates the device now (or better : sets its settings from the last saved ones), and this doesn't always go in a decent fashion. So once in a while (say once per week) I have similar (well, I guess it is similar/the same) BUT it always end up right because in MinOS I have no other devices (which deviced should be KS devices since WASAPI is turned off anyway). So, I may get a message at startup of XXHighEnd (not yours, but I know it's from the same area) but next it is always OK because when (say half of a second) later things are finalized, there appears to be one device only, and that one gets selected. Still that message I receive will hold up (it must be clicked away).
Summarized, things are not 100% decent (are timing related), but if you don't need that other device (headphone in your case) just disabled it. Now you (thus) still may receive a message, but there is no "opportunity" anymore for XXHighEnd selecting the wrong device (there is one only, and that's the one you want).
Leo
« Reply #2 on: January 12, 2014, 01:06:01 pm »
'there is one only, and that's the one you want'
You couldn't have said it better Peter!
I will disable the others.....
thanks,
Leo
