November 23, 2024, 08:53:38 pm *
Author Topic: Core appointment lock to 100% CPU  (Read 25536 times)
« Reply #15 on: January 12, 2014, 07:58:11 pm »
And now I still don't know whether the behaviour is different in MinOS. Is this question so difficult ?
I never used MinOS in my life, but if I have to I'll try it!
First I'll try SFS 12.
Too late, the graphs are all empty!
Restart te music: 100/100/80/80% and then all go to 0% and that's history.
CPU for XXHE in resource monitor says 50% and in task manager 72%. Something is definitively broken!
« Reply #16 on: January 12, 2014, 08:37:40 pm »
Hey, why don't you just say so then ? I mean, I won't force you if you are somehow afraid of that. Ok, that's history too then. Happy
For now. Happy Happy
Maybe you can remember that I have been talking about cpu graphs of W8 and that I don't trust them ? But this is why I asked you to look through TaskManager only. That is what I look at so that is my reference.
But now I am not sure whether you just told the problem has gone ...
Gerard, please notice : If you're telling that at the start of playback you see 100/100/80/80% then *that* is normal in itself. Well sort of, but not of further importance. If only during playback itself all is close to 0% ...
Keep in mind though, this is about XXHighEnd playback. And in your case there's also the "after playback problems".
Please try to be as clear as possible, or this topic receives a high post count without real necessity. It is difficult enough already, right ?
Take your time,
« Reply #17 on: January 12, 2014, 09:39:43 pm »
"Maybe you can remember that I have been talking about cpu graphs of W8 and that I don't trust them ? But this is why I asked you to look through TaskManager only. That is what I look at so that is my reference.
Take your time,
I meant the graphs just ended showing activity at all so they did not receive their data or something like that.
The cpu was still high I'm certain.
After 20 minutes I got a stop, everthing froze and later a message like ' failed to ... endpoint ' . Clicked away the message and graphs apeared again with cpu1 and 2  to the max.
After killing xxengine with blue led all 4 cores went down to almost 0% so the problem is solved for the moment.
 For now maybe better you spend your time on somethings more clear. I cannot make chocolate of this now!
« Reply #18 on: January 12, 2014, 09:43:59 pm »
Gerard,
I sure wanted to refer to that  "chocolate" earlier in the topic ...
But not many outside of Holland would understand.
« Reply #19 on: January 12, 2014, 10:52:56 pm »
Gerard,
Google is your friend Wink
I cannot make chocolate of it (litterally translated Dutch saying, meaning I don't understand it)...
« Reply #20 on: January 12, 2014, 11:46:03 pm »
Hi there Alain,
By chance I was taking this afternoon chocolate with churros. Do you know what are churros? Take a look: https://www.google.es/search?q=chocolate+con+churros+madrid&espv=210&es_sm=93&tbm=isch&tbo=u&source=univ&sa=X&ei=vhXTUtDSBqbP0QWSy4DYBA&ved=0CE0QsAQ&biw=1920&bih=1075
Chocolate con churros are very popular here. The most common shape of a churro is like a ribbon and that´s why the word "churro" is used also to say that something has gone wrong. If I wanted something went right (straight) and if it went wrong (crooked) I´d say "this has come made like a churro"
 Wink Juan
« Reply #21 on: January 13, 2014, 10:34:07 am »
The better translation would be :
I can't make anything out of it.
But even that is not quite right, because it would be something like :
There are no building blocks present to build the house.
Or put differently :
How to make chocolate without cacao.
We (in Holland) easily say :
Can't do a thing with that.
While more literally and more brief (this is all about the briefness of the message) :
Can't do a thing with it.
I am trying to get rid of the "it" because in Dutch another word is used and while that too refers to the subject ("it") it is less explicit. So see the defference between "that" and "it" - "it" is more anonymous - while we have another version which I can't translate.
blahblablah Happy
Anyway, the chocolate thing is not about not understanding as such, but it is telling the addressee that he didn't provide the data to make anything out of it. It is close to accusing.
Meanwhile there's the option that indeed you didn't understand the provided data yourself, so it is a soft middle way of telling a person that possibly he is wrong.
Thinking further it could go as far as the cacao being available, but now I don't know the recipe. "Can't make chocolate of this" now nicely can go either direction.
Hey, and you expect us here to speak English ?
« Reply #22 on: January 13, 2014, 01:17:42 pm »
« Reply #23 on: January 13, 2014, 01:37:45 pm »
This is what I found: onsamenhangend, onbegrijpelijk, onlogisch of raar etc.
If you (the reader) translate this to english you understand what I think of the behaviour of my HTPC. Wink
« Reply #24 on: January 13, 2014, 02:38:54 pm »
I must say that when I read your answer yesterday, by context I could apprehend what it was about, but I preferred to verify Happy  I like the expression because it is a different way to express things. I will try to formulate it in French.
I feel the same sometimes with my pc by the way Wink So many things happening in that box. I am sure that the electrons running inside are all a little grazy
