November 23, 2024, 12:13:54 pm *
Author Topic: Playback Drive Format  (Read 8111 times)
coliny
« on: January 09, 2014, 02:02:39 pm »
Your page on formating gives this command:-
format F: /fs:exFAT /q
Should it not include command for 64K cluster:-
F: /FS:exfat /A:64000 /Q
« Reply #1 on: January 09, 2014, 02:06:49 pm »
Hi Colin,
The question is good but the answer is No;
The command given is an emergency format (for when the volume appears not to be empty - occupied by system files), and later XXHighEnd will be able to format it herself because of your command - now with its own under the hood options.
coliny
« Reply #2 on: January 09, 2014, 04:42:09 pm »
Hi Peter
I have 7GB unformated on my drive so for now I will format it NTFS 64K clusters using W7 partition utility and see how it goes.
Thanks
Colin
« Reply #3 on: January 09, 2014, 09:02:45 pm »
My experience with the ramdisk is that no matter what you've formatted it to, xx will reformat the playbackdrive to exfat.
The strange thing is that I could hear differences between different "original" diskformats.
Regards, Coen
coliny
« Reply #4 on: January 10, 2014, 12:02:48 pm »
Thanks Coen
For me also XXHE has changed it to exFAT.
I think there's no gain for me using playback drive. In terms of speed that is.
Colin
Page created in 0.128 seconds with 19 queries.
