November 23, 2024, 08:49:04 pm *
Author Topic: Q5=1=PC crash & other misdemeanours  (Read 25895 times)
« Reply #15 on: January 10, 2014, 08:31:43 am »
As it happened I did not need a "next time" I got a wallpaper error message when I brought XX GUI back up. Then when I tried to use XX again it was so slow as to be unusable. I went back to full o/s - no better - so then I restored the o/s back to an earlier time that did not work either so this morning I will try a reinstallation of XX.
MMmmm
« Reply #16 on: January 10, 2014, 09:49:57 am »
Paul, what is that Wallpaper message ?
In Unattended and W8 I don't think many Wallpaper messages exist. Actually none (but could be an OS message). And now things start to go off track somewhat because in W8 you CAN NOT use the Wallpaper with these settings (1,1,1) - or at least I can't. I am pretty sure (not 100%) that this is written (ToolTips), including the cure for it.
You should have switched off your Wallpaper which was explicit advice for W8 in the first place (say a year ago) and now you are using it while you can't even see it ? 0.9z-9b and Q5=1 same thing ?
And so now I don't know what you are doing out there ... Wink
PS: Regardless, please don't forget to answer the question from my first sentence and whether that message comes from Attended or Unattended.
« Reply #17 on: January 10, 2014, 10:28:08 am »
Actually Paul, who cares that I don't know what you are doing and in addition it may not be clear at all about that Wallpaper (I have been fighting with it myself and maybe I even got it working). So ... what happens when you just switch it off ? Maybe it helps ?
« Reply #18 on: January 10, 2014, 11:38:05 am »
Well this is typical of my luck with computers. After further investigations another fault manifested at the same time - my USB music disc has gone faulty - accessing files takes an age and I tried the disc on another computer and the same problem. So that caused XX to be slow just when I started to test Q5=1.
But Q5=1 is still a problem I shall continue investigations later when I have some time. Watch this space..............
Meanwhile it looks as though I may need a new disc.
« Reply #19 on: January 10, 2014, 12:08:05 pm »
Woops  -  OK with some embarrassment  blush2  Q5=1 seems to be working now with wallpaper switched off.  Wallpaper only causes a problem with Q5=1 though - I have had it on (with other settings) for some time without problems.
Ah well got there in the end.
Now onto my hard disc problem!!!!  Why me?
« Reply #20 on: January 10, 2014, 02:40:53 pm »
Paul, I thought I just had posted here with some outlay of Q4 (ToolTip isn't correct) but my post is nowhere. And now I have to run ...
« Reply #21 on: January 11, 2014, 10:45:50 am »
Whatever I wrote ended with "should be in its own topic", which I now made here : 1.186a - Tooltip on Q4 (stalling issues).
Page created in 0.117 seconds with 19 queries.
