November 23, 2024, 06:33:18 pm *
Author Topic: CUE file bugs  (Read 6106 times)
« on: November 23, 2007, 08:19:50 pm »
My CUE files are made using EAC.  When using cue files a lot of times the song titles are screwed up... letters dropped,,,It happens to song titles where inexplicably EAC has not put quotation marks around them (most songs titles when you open/edit a cue file will be in quotes and therefore read correctly; if they aren't in " " when you open a cue file to read/edit it the song title won't look right in XXHE).  It happens often enough that I'd like to not have to go back and add quotes manually... f**bar is able to read them correctly, so maybe it can be worked out in XXHE easily enough, without messing up SQ! hehe
Just to let you know.  Still have to select cue files from starting explorer... All of us thousands of users of CUE files would really like to select cue files using "Library Button" and Library Tab (clicking album cover plays the cue/wav file).
thanks,
The CUE File Brigade
« Reply #1 on: November 23, 2007, 08:45:33 pm »
rofl
Good point Dave. I did not know it. Easy enough to solve.
