November 23, 2024, 01:48:58 pm *
Author Topic: 1.86a For W8 only?  (Read 10894 times)
soundgals
« on: January 02, 2014, 09:23:54 pm »
In the realease notes and SQ comments, I only see W8 mentioned. Just wondering if there's any advantage to running the latest version on W7 as well.
If so any guidelines on optimum parameters for W7?
Geoff
September 26, 2012 (0.9z-7-3)
Windows 7 Ultimate N 64bit SP1, XX on OS disk, music on USB spinning disks, Galleries on OS disk, Mac Mini 2010 8GB Ram / Engine#4 Adaptive Mode / Q1/2/3/4/5 = 14/0/0/0/0 / Q1Factor = 1 (Dev.Buffer = 4096) / ClockRes = 15ms / Straight Contiguous / SFS = *2* / not Inver / Playerprio = Low / ThreadPrio = Real Time / Scheme = 3 @ / *Playback Drive = USB2 2TB* / UnAttended (Just Start) / All Services Off  / No Running Time / Minimize OS = On / Double Octo Arc Prediction Upsampling / -> 24/768 Phasure NOS1 async USB DAC, Driver v1.0.2 (4ms) -> main amps
Robert
« Reply #1 on: January 03, 2014, 04:40:57 am »
Definitely worth running with W7 a noticeable improvement in sound quality. Check my signature, I'm limited by using a laptop which has only 2 cores. I've found Peters W8 settings to also work with W7. Havn't tried changing settings yet still getting use to the sound.
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #2 on: January 03, 2014, 07:59:29 am »
Good question Geoff. And mas Robocop says. I have now injected a remark about it in the Release Notes.
Supports Windows 7, Windows 8 and 8.1 and the Server versions thereof. Vista and XP are also supported but the Sound Quality (dialing) possibilities of these are significantly less.
soundgals
« Reply #3 on: January 03, 2014, 12:05:27 pm »
Thanks Robocop and Peter for clarifying that. I've been listening to it initially with Peter's settings for the 0.9.... version; but will also try it with the W8 settings under W7. I'm just looking for good starting points and will tweak it from there to get the sound I want on both OS's. I find it's better to start at different extremes and then work my way towards something that best suits the system.
Of course, I'll be trying it under W8 as well.
geoff
« Reply #4 on: January 03, 2014, 01:40:21 pm »
Hi Geoff,
Im using windows 7 and Peter's Win 8 XXHE settings (allmost). I can tell you it sounds great. Good start of 2014!
Best wishes to all.
Best Regards Johan
soundgals
« Reply #5 on: January 03, 2014, 08:25:04 pm »
Hi Johan,
Thanks. Will definitely give those settings a try under Win 7.
Just got it running under Win 8 with excellent results.
I haven't yet tried fetching music files over the lan, where the lan is only on while fetching the files. This is an interesting feature indeed and seems to imply that storing music on a NAS is now preferable to a drive tethered directly to the computer. Although Peter is mainly speaking about an old computer instead of a NAS.
I would rather use a NAS as long as there are no delays or SQ hits.
Geoff
« Reply #6 on: January 03, 2014, 10:42:42 pm »
NAS should be the same Geoff.
soundgals
« Reply #7 on: January 05, 2014, 10:32:14 am »
Great! Will give NAS a try.
geoff
