November 23, 2024, 02:17:06 am *
Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12  All
Author Topic: SQ of 1.186, best ever! (Again)  (Read 168614 times)
« Reply #135 on: March 09, 2014, 08:10:50 pm »
Hahaha! ok, enough for this mysterious conversation.
Hey, I had not noticed it, I have reached the 800 posts, not bad! Happy
« Reply #136 on: March 09, 2014, 09:42:01 pm »
Watch out Juan, I am just 116 posts behind you ! Wink
« Reply #137 on: March 09, 2014, 10:04:12 pm »
Salut mon pote! I see it, but let me discover some new issue to get a word in and see how I took off again. Meanwhile I take the opportunity to read carefully what you say hahaha  Rules
« Reply #138 on: March 09, 2014, 10:40:48 pm »
Salut mon pote Happy
I have to admit that I did not understand that 118 vs 115db thing, but I figured you were maybe talking about the previous pair of speakers Peter had before the Orelinos... Still I am not sure about it, but that adds me a post Wink Unless you answer and we still have the same gap Wink
« Reply #139 on: March 09, 2014, 10:55:24 pm »
LOL!
« Reply #140 on: March 09, 2014, 10:57:47 pm »
No comments  Grin
PS: Have you read the PM I sent you?
Robert
« Reply #141 on: March 09, 2014, 11:13:00 pm »
One presumes Peter has increased the efficiency of his system albeit his speakers by 3db by a mod. Always a good thing to do.
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #142 on: March 09, 2014, 11:22:05 pm »
Hi Juan,
Yes I received your email Happy And you should have received my answer, unless the cold here has thicken the airwaves to a point where it will be delayed Wink
Regards Happy
« Reply #143 on: March 09, 2014, 11:31:18 pm »
Thinking about it, there are a few things that come to mind...
First, if you go on with the speaker efficiency, you will reach the threshold of pain sooner than later Wink
Second... This is more a question than a remark, but... What is it that MS puts in their Windows that affect the sound in one direction or the other depending on the version ? I thought that they were allowing a "bypass" for things like KS ?
Finally, when I will be able to regain my whole sound system, I will try to compare again USB 2 against USB 3. I just did a DPC latency checker (thesycon) with W7 and the silverstone and there is a "burst" happening at intervals that wasn't there when using USB 2 ? Wouldn't this make USB 2 better than USB 3 ? I just remembered this lately, but it was like this some 2 years ago...
EDIT: I am seriously drifting from the thread...
« Reply #144 on: March 10, 2014, 08:27:17 am »
Could be interesting Alain. I also see bursts but not through DPC (which I didn't use since W8 came out and it didn't work well for W8) but through other means. Not sure wheter we see the same. If it is the same (which I should/will check) then I already know this can not be avoided in W7 (while in W8 it is not there). For USB3 I mean.
And I don't think I ever tried to look at things through USB2 (W8 nor W7).
Thanks ...
« Reply #145 on: March 10, 2014, 08:34:15 am »
Oh, nothing is manipulated (like in EQ-ing) that I know of (all is "bit perfect"). But it is all about how the OS (and PC) imply minuscule changes in power behaviour at the DAC end.
Nothing much special. swoonswoonswoonswoonswoon
But working on it ...
Muziekliefhebber
« Reply #146 on: March 28, 2014, 11:59:34 am »
Beste forumgebruikers en muziekliefhebbers die XXhighend spelen in demomode vanwege beperkte financiële middelen. Gebruikers die wel de volledige XXHighend functionaliteit kunnen ontsluiten kunnen beter deze post/reply van mij gewoon beter niet lezen.
Met betrekking tot de geluidskwaliteit van XXighend heb ik een aantal opmerking/vraag aan andere forumleden die ik kwijt wil over mijn audiosetup. Voordat ik hiermee start is het verstandig om eerst even wat meer informatie te geven over mijn bescheiden(afgezien van de speakers) audio-setup:
Ik speel af in DEMOMODE met de volgende set:
-Harman Kardon HD990 DAC/Cdspeler (kun je dus tevens ook AB vergelijk doen van C versies van de nummers tegen  de FLAC/WAVE varianten!)
-MIT 330 series 2 interlink (oud maar fijn!)
-Unison Research Unico Primo versterker (natuurlijk klinkende muzikaal geluid)
-Power x1 stroomkabels (beter dan de standaardkabels vreemd, genoeg toch echt duidelijk te horen)
-Avantgarde Uno hoornspeakers (een keer met geluk goedkoop op de kop weten te tikken) met filterloze middentoner.
-Dualcore Laptop met 4 gb geheugen en externe harddisk
-USB > Spdif via M2tech Hiface 1
Ik doe via XXHighend niet aan upsampling (klinkt n.l. beter zonder upsampling in mijn set). Mijn DAC doet intern aan upsampling (384, Blackfin processor). Ik gebruik kernel streamingmode en straightcontinuous omdat hierbij het geluid de meeste 3D biedt in het stereobeeld en de textuur van echte instrumenten het meest natuurgetrouw blijkt weer te geven.
Mijn vraag:
Zijn er meerdere gebruikers zoals ik die de vorige variant van XXhighend (0.9z-9B in DEMOMODE) ook beter vinden klinken dan 1.186 in DEMOMODE? Ik lees praktisch alleen maar berichten dat de nieuwste versie het beste klinkt. Ook heeft iedereen bijna de NOS-DAC van Peter.
Zelf ervaar ik dat 0.9z_9B natuurlijker klinkt, een betere resolutie geeft, het hoog verfijnder klinkt en minder synthetisch.
Ik heb alle mogelijke settings geprobeerd in 1.186 maar krijg niet dezelfde kwaliteit als onder 0.9z-9B met mijn FLACfiles.
Globale settings die ik nu gebruik:
-DAC settings: 32bits /96khz
-Clck resoltion 15 ms
Xtweaks:
-Balanced Load:42
-Nervous Rate:50
-Cool when idle:1
-Provide Stable Power:1
-Utilize cores:1
-SFS op 0,5 (minimum) en Mx van 32,0
-Straight Continuous
-Include Garbage Collect:on
-Stop Desktop Services
-Stop Wasapi Services
-Stop remaining services
Qsettings:
Q1=14, Q2 t/m Q5 =0
Ik ben benieuwd naar jullie ervaringen in DEMO versies!
Groeten van een beginnend forumlid.
Muziekliefhebber
« Reply #147 on: March 28, 2014, 01:58:53 pm »
Dear folks at the XXHighend forum,
Regarding the perceived differences in soundquality when using DEMO versions XXhighend 0.9Z_9B v.s. the new iteration 1.186 i'd like to know your own experiences.
I'm playing DEMO versions for quite a long time now because I 'm on a tight budget.
My setup of the moment:
-Harman Kardon HD990 DAC/Cdplayer-all-in-one (also easy this way to test CD versus FLACstream editions of the same music using the same apparatus(HD990)
-MIT 330 series 2 interlink (old wine but stil a very nice soundmatch)
-Unison Research Unico Primo integrated tube hybrid amplifier (naturaland musical sounding)
-Power x1 powerchords (I don't understand why it makes such a difference with standard ones,  but it does!!)
-Avantgarde Uno hornspeakers (I bought them very cheap in the past when I had the chance)(filterless design speakers)
-Dualcore Laptop with 4 gb ram memory and external harddisk
-USB > Spdif -->M2tech HIFACE type 1
I am not using  up/multi-sampling in xxhighend because my DAC is allready doing that.
My question to the other forumwriters/reader is:
Do you also find 0.9z_9B more musical, more natural( and also more refined an with better real dynamics) sounding than the new 1.186 version?
The new 1.186 xxhighendversion sounds a bit more 'synthetic,processed' to my ears but what are your experiences playing with both DEMO versions.
Regarding 1.186 I allready played with a lot of different settings but still I like 0.9z_9B more.
Global settings I use right now:
-Clock resolution 15 ms
Xtweaks:
-Balanced Load:42
-Nervous Rate:50
-Cool when idle:1
-Utilize cores:1
-SFS at 0,5 (minimum) and Mx van 32,0
Qsettings:
Q1=14, Q2 t/m Q5 =0
I'm interested in your opinions about the differences in perceived sound quality (using DEMO versions of XXHighend (0.9z_9b vs 1.186). Please let me know your XXHighendsettings used when you have been testing.
« Reply #148 on: March 28, 2014, 02:15:42 pm »
I think minimised os is essential to the forum opinion. Now you have to get a licence to use that. My advice is that you save some money the coming weeks/month and purchase a licence. It one of the best audio buys you will ever do and one of the cheapest too.
Regards, Coen
« Reply #149 on: March 28, 2014, 04:03:58 pm »
+1
Page created in 0.144 seconds with 19 queries.
