November 23, 2024, 01:45:04 am *
Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12  All
Author Topic: SQ of 1.186, best ever! (Again)  (Read 168597 times)
Jud
« Reply #120 on: March 02, 2014, 09:36:01 pm »
Dear oh dear - Here I am with one Windows install already upgraded to 8.1 (I'm assuming no way to downgrade; original W8 install was a download I didn't save - let me know if this assumption is incorrect) and the other at W7, wondering whether to buy another copy of W8 to upgrade the W7 install.
So is 8.1 completely hopeless?  Has anyone tried it in the past week or so during which Peter has once again found some merit in W8?
Robert
« Reply #121 on: March 02, 2014, 10:00:16 pm »
Gosh with the multitude of changes I think everyone needs to slow down a little.
I have yet to try W8 and still happy with W7. This sound is still well ahead of any opposition I've heard.
But its got to the point that the latest W7 settings are way beyond my computer anyway.
What with 12 cores and beyond its getting into Star Wars land.
We all recognise that the evolution must go forward but we need time to listen to settings and one would hope MUSIC.
Don't let the technology over ride the Music.
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #122 on: March 02, 2014, 10:37:26 pm »
My computer is in simple words, an office PC with a 4core Intel proc. as per sig.
I made several tests with Peters “seagull” track and was listening especially to the 3D image and the highs with the VERTU CD (Stanley Clarke & Lenny White).
From my experience on my system the RAM disc has no positive effect on the SQ under W7 & W8, so all is running on the spinning disk.
Under W8 I got the following results.
A)   All on the spinning disk – best 3Dimage and nice highs.
B)   Playback drive on a RAM disk – 3Dimage was smaller, harsh highs,
C)   Playback and XXH on a RAM disk -  smaller 3Dimage than under B), harsh highs.
Robert
« Reply #123 on: March 03, 2014, 12:21:57 am »
I would disagree with you on Ram disk, it made a noticeable difference on playback in W7 and I continue to use.
I use 4g for ram disk playback due to running some 24/192 music files.
I don't use ram for XXhigh as not enough ram. But I would love to. I only have 8g total. You need at least 12g of ram to make this work well for both.
I'm limited by my notebook size can't put more ram in.
Robert
Oppo 205 UDP Dac
« Reply #124 on: March 03, 2014, 12:58:12 am »
Hi Robert,
When I started playing with the ramdrive, I was using only 512MB for XXHE as a second ramdisk.
Peter explained that more was needed for the XXHE ramdrive, but in specific situations like HDCD music or FLAC - any other format than WAV.
Since I do not really have many HDCDs (one could deactivate the feature) and all my music is in WAV format, I could continue using only 512MB (I could even go lower than that). This of course stands only for the XXHE ramdrive, not for the music ramdrive...
« Reply #125 on: March 03, 2014, 01:21:35 am »
Hi Jud,
It seems that W8.1 would be a new "cracker" like W8 was when comparing to W7 about a year ago... Since we are still struggling with W8, I presume that W8.1 is/was not an important concern, apart from the fact that W8 versions are more complicated to find nowadays, not to say impossible...
About getting W8 again... Maybe there are still some stores that carry W8 ? I looked around but it would require that you have your product key to validate your request for W8... Maybe Microsoft support ?
Jud
« Reply #126 on: March 08, 2014, 11:56:27 pm »
About getting W8 again... I looked around but it would require that you have your product key to validate your request for W8... Maybe Microsoft support ?
Alain, I now have W8 (along with 8.1 and 7), thanks to your idea above.  I remembered that I did get a product key when I bought the W8 download.  Searched my email, found the key, and with that was able to download and install it.  Many thanks for mentioning the simple and obvious idea (the product key) that I had overlooked.
« Reply #127 on: March 09, 2014, 12:14:56 am »
Jud,
Happy to be of some help Happy
On my part, going back to W7, I forgot that my copy was already a W7 with Service Pack 1... I went through all the Windows updates, then realized it was not good... Had to redo the whole thing again... I think I have a "crossfade" memory between versions Wink
« Reply #128 on: March 09, 2014, 04:29:38 pm »
By now I have reasons to believe that while Windows 8 can sound more harsh or nasty in the highs, this is actually because it is more accurate so it shows better when your chain is *not* that better. So :
With my change to Windows 7 some 5-6 weeks back by now, I recall my remark "not sure about the bass"; I took that for granted. But at explicitly showing some sub-low to someone here the other day, ... where was that.
For other reasons we had to go to W8 but right away I noticed that sub low again. The next couple of days I was practicing my "feel your woofers" theories and it is just right.
So from this alone (which seems stupid ?) I tend to say that W8 has to be the better one.
Next is how to get that highs more under control; I think I already got "somewhere" but it is not finished yet.
With that in mind, I now think I do have those highs under the control needed (but maybe still not 100%) and I now have no urge to compare with Windows 7.
However, when I do now (in this situation as of now) Windows 7 sounds ugly; not distorted as such (like how it could be perceived say two months back) but just totally inaccurate. So what should have happened is this :
For W8 bass already was under sufficient control and therefore let W7 sound worse there, and while now highs got better for W8, W7 suddenly loses there too.
All is so relative ...
... and difficult, because it can well be so that most of us (or you) will not easily perceive a difference between W7 and W8 regarding the highs because that first needs a more crazy high frequency output level (so this is all speaker related) while for the bass it is quite easy to judge W7 as the better one because the bass is lower (keyed) in general. *This* though is not-right because in the same time it won't be a tight bass and for *that* to happen (for differences !) it first needs a speaker which can show that (in the really more low regions that is).
Not sure whether anyone can follow this. wacko
The other aspect is the 3D capabiilities of either, which I dedicate to better high freqency representation and "squares" which require those (very) high frequencies. So (synth) music with squares in them tend to do this 3D best while W8 is/was the opposite of that (way more flat than W7);
All I know at this moment is that I seem to be more focused on let W8 behave right in the highs than taking notice of the 3D aspects of it, while I also don't recognize any "too flatness" any more.
Remember, I changed things in my audio chain, so this is not really XXHighEnd (settings) related. It is true though that for W8 too the lower SFS (like 0.11 etc.) works for the better once the nastyness is out.
« Reply #129 on: March 09, 2014, 05:23:01 pm »
Hi Peter, I see in your signature you have the word *modded* regarding the NOS1. Can you tell me please what does it mean?
« Reply #130 on: March 09, 2014, 07:29:16 pm »
Juan,
This is all about speed. No "modded" NOS1 or whatever in there. But 118dB speakers instead of 115dB - Yes (you can have that too.  Wink Wink)
The "mod" is in the same area and works out similarly (way more highs yes) but I had to take that out.
So the more speed implies "better tracking" (read this as less distortions in the highs) which now (to my current idea) follows the better accuracy of W8 while at the same time it also follows the less accuracy of W7 better (the distortion in W7 becomes profound).
It is so complicated ... and I'm only always trying to reason out (or proove) what happens because of which.
« Reply #131 on: March 09, 2014, 07:40:35 pm »
Thanks Peter, some parts of your response are certainly  complicated to understand, others not.
Yes, of course I would like to have those 115db...but  scratching
Regards  Wink
« Reply #132 on: March 09, 2014, 07:56:19 pm »
118dB ...
« Reply #133 on: March 09, 2014, 07:59:23 pm »
Oh, I thing we are talking about different speakers  Wink
« Reply #134 on: March 09, 2014, 08:06:19 pm »
No, well, uhm, I made a mistake. So :
That was correct. sorry
