April 17, 2025, 09:09:45 am *
Author Topic: No sound from Engine #2 and DDDAC1543 SPDIF  (Read 10235 times)
goon-heaven
« on: May 30, 2007, 11:05:45 pm »
Without wishing to confuse the issue...
My Engine2 dont make music either... XP SP2, RME digi 96/8, DDDAC1543, blah blah
But I am soooo happy with 5minutes from Engine1 before she goes belly up too.
7Ultimate 64bit on Patriot Torq 128 SSD, XX on 2Gb RAMDisk, music on NAS, i7-860 HT Off / Engine#4 Special Mode / Q1/2/3/4/5 = 1(32 samples)/0/0/0/0 Playerprio = Low / ThreadPrio = Real Time / Scheme = 3 Attended / FileSplit 1Gb / -> LynxTWO-B buffer size 32 -> EmmLabs DCC2 SE
« Reply #1 on: May 31, 2007, 09:44:40 am »
I put your post in a separate topic.
Can it be so that you are using the MME drivers ?
I don't think they can work with Engine#2 (which was just made for the signed drivers -> MME are not).
goon-heaven
« Reply #2 on: May 31, 2007, 12:10:36 pm »
I use foo_output_asio(dll).dll in FUUBAR.
But I have no idea what driver XX is using? Presumeably, the default RME one??
Best regards
Steve
« Reply #3 on: May 31, 2007, 12:45:55 pm »
Steve,
For Engine#2 it will be the Primary Device (which always is the first one in the list if you click on the top combobox in XX.
So it is a matter of choosing "a" device of which you know it gives sound. It is up to you whether the one sounds better than the other (which for sure is important if you have two soundcards, which btw would be the same as the difference between the RME-MME drivers and the RME-non-MME drivers.
I hope you get it to work ...
goon-heaven
« Reply #4 on: May 31, 2007, 01:17:01 pm »
Hmmmmm..
Yes it works now......
Thats the 4th non problem today. It must be Thursday.
Sorry for wasting your precious time.
« Reply #5 on: May 31, 2007, 01:29:58 pm »
No Steve, it's my own fault. Although it's in the Help.htm, it's there as a kind of sidenote. I must make this more explicit, which I will do right now.
Page created in 0.046 seconds with 17 queries.
