November 23, 2024, 04:08:04 pm *
Author Topic: Enable HPET for 'Time Performance Index'  (Read 20888 times)
coliny
« Reply #15 on: December 27, 2013, 09:12:15 am »
Yes the problem was sometimes winmgmt was disabled.
This occurs if press power button to shutdown during or after unattended play, next time I boot winmgmt is disabled.
If I use the following sequence to shutdown from unattended play then all is well:-
Alt-S
Alt-T
Alt-X
close XXHE
shutdown.
Now that's sorted I tried disabling HPET but then TPI shows "Not the Best" so for my computer I did need to execute the Command Prompt instruction :-
bcdedit /set useplatformclock true
to get TPI - optimal
Regards
Colin
« Reply #16 on: December 27, 2013, 09:48:27 am »
Hi Colin,
I don't think that using the power button to shut off the OS is any good at any time; usually that is a (form of) hibernate mode, and the times that that worked well (recover from that) have gone since Vista.
But super that you sorted that out !
I think you make it way too difficult for yourself;
It would be correct what you're saying, but it is not correct to do it that way. I know, this is because of your history and the n/a thing, but you should just use the Try Change button when the n/a has disappeared anyway.
Notice that there's so much more in there and that you should let XXHighEnd arrange for it all in a consistent fashion. Just try it ...
Regards and thanks a lot for the feedback,
