November 23, 2024, 06:33:07 am *
Author Topic: high cpu load during play  (Read 5704 times)
coliny
« on: December 18, 2013, 09:17:28 am »
Started XXHE this morning and it was slow to respond. Checked with Task Mgr and found that XXengine3 was continuously using more than 50% cpu during play. Stopped play and cpu load dropped to very low %, no other processes were using high cpu %.
Same problem after a reboot.
I've done this check before with my current configuration and XXengine3 was only using about 2% cpu during play.
Logs attached
W7 Starter, 2gb ram
* X3-20131218-074007.log (18.47 KB - downloaded 442 times.)
* XX-20131218-073658.log (6.53 KB - downloaded 441 times.)
« Reply #1 on: December 18, 2013, 09:34:46 am »
Hey,
Most probably you set your Q5 to 1 as recently suggested. This consumes 100% of the cpu core involved and is intentional in itself (but will only really work well in the upcoming version).
Is that it ?
coliny
« Reply #2 on: December 18, 2013, 10:35:19 am »
Yes that was it, I've put Q5 to 0 and OK now
Thanks
