November 23, 2024, 10:55:16 pm *
Author Topic: Windows 8.1 Fresh Install and Local Account problems ?  (Read 4629 times)
« on: November 11, 2013, 12:22:12 pm »
All,
I installed Windows 8.1 as a fresh install on just another PC, and before anyone runs into problems, a small report about this;
Unlike the Upgrade from W8 to W8.1, in the situation of a Fresh Install there is no Local Account account available "yet". So, this requires that MS Account to be used at first, with the notice that the Userid will be an email address etc. Ok ...
As it was explained here : Re: Windows 8.1
by Juan, afterwards we can create a local account and use that further on. However ...
First off there is the notice that I don't think we are able to get around the MS Account, like I could with that upgrade. I mean, it looks like it really needs that Internet Connection because ...
You can't change any of these (Account or Personalise) Settings without being Activated first. This is a bit hard to explain because you can't even continue without creating the account which I think needs the Internet connection in the first place, but anyway and for sure it needs the Activation and *this* for sure needs the Internet connection (and the License Key btw). So, without Activation hardly anything can be "personalised".
Note : On the Native W8 this is actually the same, but work arounds for that exist. With W8.1 I am not so sure.
On to the real expected culprit ...
This new Local Account you will create is NOT an Administrator. This exhibits by the most nasty UAC (User Account Control) questions as we were used to from Vista at first, and at all these questions the MS Account's Password must be enetered (you know, that one with the upper- and lower case and numbers in them - a real pain to begin with.
Outside this, the UAC setting of that Local Account can not be changed to 2nd from the top, which causes these questions as usual. But merely :
Since this Local Account is not an Administrator, I don't think anything of XXHighEnd will run, because being an Administrator is really necessary (but I did not try it).
Through the original MS Account's Userid you can put the Local Account in the Administrator's group, but that doesn't change one thing; not sure whether this is a bug or something, but it just does not help.
Using such a Local Account is a pain already because for example no Device Drivers can be installed with it.
The only alternative (I did not try it but should work) is activating the Administrator Account which normally is disabled (but which is always there in hidden fashion). I can explain how to, but I am not really sure (anymore) how this implies other anomalies, which I recall from once using it.
So what I think at this moment is that the MS Account is obligatory to be on some safe side. And otherwise along the lines we should be able to make that new Local Account a real Administrator (I am pretty sure it can be done, but all takes time to find out).
Btw, once your MS Account has been setup I don't think it needs any Internet Connection anymore (but write down that Passord because it is prone to forget because of the rules needed to it).
