April 05, 2025, 01:38:53 am *
Author Topic: But the new Priority Scheme changes SQ just as well ...  (Read 7719 times)
« on: November 19, 2007, 03:41:40 am »
It just slipped to my mind that the new Priority Scheme as applied per 0.9s might or will influence SQ just the same. I mean, at judging Unattended Playback you'll listen through this new scheme just the same. This cannot be avoided, although you can play with the priorities (that would be Thread Priority).
To let behave all as similar to as how it was before 0.9s Thread Priority should be set to "Nothing" after a reboot or "Normal" in between (which could be slightly different from Nothing after a reboot, but let's say that doesn't matter).
The new priority scheme is applied as well to Attended Playback.
Page created in 0.024 seconds with 19 queries.
