November 23, 2024, 09:45:27 am *
Author Topic: Losing Windows Activation  (Read 22121 times)
« Reply #15 on: September 25, 2014, 01:07:07 pm »
I will put internet back on en see wat will happend.
If you already did that, then it won't help for sure.
OK, so this must be a Windows 8.1 "feature". Maybe this solves it for you :
Windows 8.1 sounds super poor and you shouldn't be using it for music.
Does that help ?
haha
But I am serious ...
« Reply #16 on: September 25, 2014, 01:26:00 pm »
Wait a minute ... I suddenly recall something ...
Yes, such a window, or maybe a smaller one preceeding the one you posted ? - can appear at irregular intervals. But all you need to do is press one little "back" button or whatever it exactly is and which I forgot. So, looks "dangerous" but is not at all.
Possibly I just applied alt-tab (switch to other task) or something like that.
Can't you find something which looks like what I am talking about ?
Michel
« Reply #17 on: September 25, 2014, 06:15:33 pm »
i can't remember such a window..If it happend again i will look for it.
Mayby its a good idea to roll back to windows 8 or 7?
For w7 i never had any of dis problems..
Michel
« Reply #18 on: September 25, 2014, 06:26:19 pm »
Michel, if you can go back to Windows 8 I would always do that ... (SQ)
Michel
« Reply #19 on: September 25, 2014, 11:42:37 pm »
I have not had windows 8. I immediately switched from w7 to w8.1.
But I'm starting to believe that w8.1 so was not a best choice ..
Therefore, I will install w8 (there will probably be one on Spotnet). And go looking for an activation code.
You can expect an email from me for a XXHighend code request soon ..
regards,
Michel
