November 24, 2024, 01:06:22 am *
Pages: 1 2 3 [4]  All
Author Topic: Windows 8.1  (Read 54189 times)
« Reply #45 on: October 20, 2013, 06:56:16 pm »
Yes it's the pro version. I always buy the pro version since sometimes I would have to connect at the office (through VPN) and so I have to specify the domain...
EDIT: I would gladly change to English, at least it would make things so much easier when we communicate and I have screenshots...
« Reply #46 on: October 20, 2013, 07:07:30 pm »
Alain,
Maybe superfluously, but if you get yourself the Pro version in English, that can be changed to French;
I think it will still be so that when you buy whatever version in another language (also the Pro version I reckon) you can only upgrade to a version in the same language (no matter you can change that to another language later). Downside : the officialy language versions are always later (can be months).
I struggled for maybe 10 years after obtaining a Dutch version the first time. You just can't get rid of that (when you keep on upgrading).
I'm not sure whether you say this is your problem, but if so, yes I recognize that.
« Reply #47 on: October 20, 2013, 07:17:52 pm »
Exact... I was more at ease with English since programming involved only English programming. But circumstances changed this at home, so now I never looked back. But it is complicated when trying to translate with the correct words...
I don't know why I never thought at some point to switch back to English...
« Reply #48 on: October 20, 2013, 07:35:29 pm »
Alain, can´t you do this?: http://windows.microsoft.com/en-us/windows-8/add-language-keyboard
« Reply #49 on: October 20, 2013, 08:02:13 pm »
Juan,
Thanks a lot ! I now am in traditional Chinese... Wink Just joking haha Wink
I am in English now ! Super !!!
« Reply #50 on: October 20, 2013, 08:04:59 pm »
I also thank you, because even if sometimes I do not fully understand your artistic performance in English (...Wink...), I can see that you were suggesting the possibility to do this Happy
Now I will try to have the music play with 8.1...
« Reply #51 on: October 20, 2013, 08:23:00 pm »
Wink
« Reply #52 on: October 21, 2013, 01:05:05 pm »
I removed my previous post to write it again, since there was a few errors.
It is possible to use Min OS, but unattended mode will potentially give headaches to some users. "Potentially", because as we know it, what happens for an individual will not necessarily happen for another.
From Minimized OS and unattended...
When the music finishes and XXHE comes back, an error appears and is related to explorer.exe (it can't start correctly with the 0xc0000142 error).
I could post the screenshot but though I changed my W8.1 language from French to English, some messages still appears in French. The result is that explorer.exe does not load back, so no icons, no taskbar... I either press Minimize OS to go back in Normal OS mode (it restarts the system), or do a hard shutdown.
I also noticed that using "Start Is Back+" (StartIsBackPlus_setup) also seems to add this error under certain circumstances, but I am less sure about it. There was an update yesterday, but it still was behaving this way. Again this could be fine for someone else.
And remember to bring back the Explorer 8 screen and uninstall Explorer 7 for Win 8...
As for SQ, I will leave this to better pairs of ears than mines Happy
Page created in 0.151 seconds with 19 queries.
