November 24, 2024, 01:05:52 am *
Pages: 1 2 [3] 4  All
Author Topic: Windows 8.1  (Read 54188 times)
« Reply #30 on: October 20, 2013, 12:07:04 pm »
Hi Juan,
A little complication happened... I was able to minimize the OS yesterday, but had to leave. Now I am trying to reconstitute how this happened, because now I am stuck in Minimize OS, while XXHE is not available on the system anymore. I know that there is a hole in my description, because it's impossible that I could go in Min OS, but then have no trace of XXHE anymore since...
I will reinstall a backup and go again through the conversion process.
« Reply #31 on: October 20, 2013, 12:25:36 pm »
Sorry Alain, I can´t help, I don´t have 8.1 installed in my Music PC, maybe Peter...
« Reply #32 on: October 20, 2013, 12:33:37 pm »
Hi Juan,
No, no worry. I will certainly not disturb anyone on this Happy Something went wrong and it is probable I did something I should not have...
To take it on the positive side: I will search harder to see if there is a way to get around that email thing Happy
« Reply #33 on: October 20, 2013, 02:04:23 pm »
Juan,
Your description is right, but like Alain said you need to use the emailaccount initially.
Looks like they want to make competition to Google/Android.
I did not try to get my old account back but I hope it's not too much work.....
This morning my videocard made everything look double, no gain no pain...
« Reply #34 on: October 20, 2013, 04:49:28 pm »
Juan,
Yes, it looks that to sign with an email account is needed for W8 and W8.1 but not necessarily it has to be a Microsoft Account. I don´t see a problem doing it with a Local Account, other different thing is doing it with a Microsoft Account...Please take a look to this article, it has interesting opinions about it and other aspects of W8.1:
http://www.tweakguides.com/Windows81_3.html
« Reply #35 on: October 20, 2013, 04:58:44 pm »
Hi Alain,
Go to "Configuration" in the right side of the screen in the bottom, once it is open go to the bottom again where it says "Change the configuration of your PC" (this is a literal translation because I´m using it in Spanish), when you are there look for  "Accounts" and go to "Your Account" and there you have the option to sign for a Microsoft account or for a local account,  take this one. That´s it. It is not very easy to find it out how to do it and I guess that Microsoft wants everybody using their account to sell more apps, etc. that is also the sense of W8 that is to sync your computers and mobiles.
If you find a difficulty let me know.
Hey Juan !
I bought a Surface ( Windows RT which is almost Windows 8 ) a couple of months ago, and this needs the same stupid Live Account (with password restrictions which makes you forget your password for sure) and I thought to apply your hints to it.
It worked !
Great thanks,
« Reply #36 on: October 20, 2013, 05:13:29 pm »
 thankyou
« Reply #37 on: October 20, 2013, 05:37:17 pm »
I did the conversion again from W8 to 8.1. This time, I deactivated all the series of choices that ask if you want to "activate" this and that. I even unplugged the network cable at that point.
Well it did not ask me for an email account this time Wink
EDIT: I also did not do all the Windows Updates... I only used the KB 2871389. It is the update that prepares W8 for the conversion.
EDIT2: You will know you have not done that update (KB 2871389) when you don't see the possibility to update to W8.1 when you access the Windows Store.
« Reply #38 on: October 20, 2013, 05:56:56 pm »
Great Alain!, now we are waiting for your opinions about SQ in W8.1.
If I understood you well you had a plain vanilla W8, so it means that it is possible to install W8.1 without previous updates. Is that correct?
« Reply #39 on: October 20, 2013, 06:00:26 pm »
Ah! I see your EDIT, you wrote it while I was writing  scratching
« Reply #40 on: October 20, 2013, 06:09:26 pm »
Hi Juan,
Well, almost Happy Only one update is required for the conversion (the KB from my previous post), then restart the PC and access the Windows Store.
BUT****: Jud strongly suggests to uninstall Explorer 7 for 8. I would add to this "Bring back the W8 interface first through Explorer 7 for 8. I  before uninstalling it"... I would do this before converting W8 to W8.1. Not that it is absolutely necessary (I haven't test this), but it does not work with 8.1 anyway...
I presently am at the point where I can minimize OS and bring it back. I will install the NOS1 drivers, then go back in minimize OS and try to see how it works Happy
When I "scr*p" a Windows version, it does not take long to restore it, but it's the almost 4GB of download for W8.1 that takes long... unhappy I wish there was an ISO W8.1 file that I could download and install at least on a DVD or a USB stick...
« Reply #41 on: October 20, 2013, 06:19:57 pm »
Alain, you can create an ISO from any download ?
(I'm sure you will find the tool for it)
The hardest part is to make it bootable without destroying 10 DVDs or so. But what was it ? yup, just looked it up : Windows7DownLoadTool (official MS product, free).
I think there's a post about this somewhere in the forum. But maybe not how to exactly use it. How to avoid 10 failed DVDs yes (and why do I think you participated there ?)
« Reply #42 on: October 20, 2013, 06:22:19 pm »
Re: Windows7/8 Dual Boot (etc.)
« Reply #43 on: October 20, 2013, 06:33:43 pm »
It's the other aspect of it that I am concerned about... Getting an official 8.1 version that will not bring problems... And be in French... unhappy
As for the bootable DVD... Maybe I have been lucky, at least for this. I have wasted a lot of CDs and DVDs in some other times though...
« Reply #44 on: October 20, 2013, 06:48:41 pm »
In French ... Shouldn't that just be the Pro version ?
Page created in 0.132 seconds with 19 queries.
