November 24, 2024, 03:45:44 am *
Pages: 1 [2] 3 4  All
Author Topic: Windows 8.1  (Read 54211 times)
« Reply #15 on: October 19, 2013, 08:41:11 pm »
Funny thing is the wallpaper on my regular PC gets the same as on the music PC, so I can read what's playing while writing this.
Hi Gerard, can you elaborate a bit more on this one please ?
I can't understand it ...
Thanks !
« Reply #16 on: October 19, 2013, 08:55:22 pm »
This is what I see on my regular non-music PC:
« Reply #17 on: October 19, 2013, 08:57:43 pm »
Yes, I understood that. But this doesn't look like "Desktop Services" shut off + Unattended ??
« Reply #18 on: October 19, 2013, 09:00:40 pm »
And this is the next song playing:
« Reply #19 on: October 19, 2013, 09:01:35 pm »
Hi Gerard,
Did you do all the Windows updates in preparation for the upgrade to W8.1 or you did them selectively ?
And yes, it seems that the live account is now mandatory. I don't like this...
« Reply #20 on: October 19, 2013, 09:02:17 pm »
Only unattended, desktop services are on because I like to see what's playing.
« Reply #21 on: October 19, 2013, 09:04:31 pm »
Alain,
I had updates on all the time because there is so much to be improved and I trust MS is doing their best now to do so.
(Like I trusted win8 would be better then W7  unhappy)
« Reply #22 on: October 19, 2013, 09:08:19 pm »
Ah ok... So I am not the only "rebel" around Wink
And when you mean "unattended", does it also imply that the OS is minimized ? This was where I had problems playing unattended (Min OS)...
« Reply #23 on: October 19, 2013, 09:32:22 pm »
Minimized OS still scares me!
« Reply #24 on: October 19, 2013, 09:46:18 pm »
Ah... Thanks Gerard Happy I can understand. For me, it is the direct connection with the power amp that is a concern for me... Happy
« Reply #25 on: October 19, 2013, 10:06:47 pm »
Gerard and Alain, it is not mandatory to have the live account activated to run W8.1 (nor W8), if you have it activated all your computers share the apps, pictures, etc but you can avoid to log in with your live account password when windows starts. Also if you have the live account activated and want to sync computers you have to be connected to internet, which is not good for SQ.
http://windows.microsoft.com/en-us/windows-8/microsoft-account-tutorial
Jud
« Reply #26 on: October 20, 2013, 03:23:11 am »
Please note that the Explorer 7 for Win 8 software Peter has kindly bundled with XXHE does not work with 8.1.  Tihiy, the author of that software, has got new software called StartisBack+ (version 1.01 at the moment) that does work with 8.1.  Only $3 US for a 2-pc license, so I purchased.
The old Explorer 7 for 8 software made for a nervous moment or two, because if you try to start the program after installing 8.1 the desktop goes blank, and there is no way to make 8.1 start up normally short of putting Windows in recovery mode, which is what I did.
The 8.1 upgrade also wiped out my ramdisks - one the playback disk, one the XXHE install disk - so I will need to re-do them and reinstall XXHE.  (This is using Primo Ramdisk, with the disks set to be persistent across shutdowns.)
« Reply #27 on: October 20, 2013, 05:13:40 am »
Hi Jud,
Do you know if StartisBack+ removes the initial screen layer, as was doing Explorer 7 for Win 8 ?
Were you able to try Min OS and unattended ?
Thanks Happy
« Reply #28 on: October 20, 2013, 11:17:01 am »
Hi Juan,
I tried to avoid having to fill this (with my email account), but it kept on telling me it needed an email account... Looked everywhere but did not see anything like "No, local please" or something like that (as it was in W8)...
« Reply #29 on: October 20, 2013, 11:45:51 am »
Hi Alain,
Go to "Configuration" in the right side of the screen in the bottom, once it is open go to the bottom again where it says "Change the configuration of your PC" (this is a literal translation because I´m using it in Spanish), when you are there look for  "Accounts" and go to "Your Account" and there you have the option to sign for a Microsoft account or for a local account,  take this one. That´s it. It is not very easy to find it out how to do it and I guess that Microsoft wants everybody using their account to sell more apps, etc. that is also the sense of W8 that is to sync your computers and mobiles.
If you find a difficulty let me know.
