November 24, 2024, 12:58:38 am *
Pages: [1] 2 3 4  All
Author Topic: Windows 8.1  (Read 54186 times)
« on: October 18, 2013, 09:26:37 pm »
Windows 8.1 is here. I updated the PC that I use for work and it looks not only nicer but also faster. I personally don´t have any update in my Music PC and it seems that to install W8.1 the other updates are needed. I wonder if anyone has tested it already in the Music PC with XXHighEnd.
« Reply #1 on: October 19, 2013, 12:28:45 am »
Hi Juan,
The present W8 for XXH has the W7 shell, and an update to W8.1 might/will fail.
I do believe that we need a clean installation of W8, installing the update to W8.1 and then following the route with the W7 shell again. I think Peter is working on this already.
« Reply #2 on: October 19, 2013, 01:37:30 am »
Thanks Joachim, yes I am using too the W7 shell, the problem I see is whether we need to install the updates previously to install W8.1 or not and if the updates would affect the SQ.
I think W8.1 has more to do with Internet and apps than with Windows internal changes, excepting perhaps that the Start is now on the desktop. On the other hand, with W8.1 the Desktop Pc that I use for work seems to run faster in general, the same as a laptop in which I also installed W8.1, perhaps there are also some other changes in the OS.
« Reply #3 on: October 19, 2013, 01:46:24 am »
Hi Juan,
I know a technician that told me W8 does not seem to work as fast as W7. While W8 boots faster, it looks as if it processes a little slower.
As for 8.1... I have the feeling it will be a PITA, since we all have seen Peter struggling to "extract" the best of w8.
Another struggle in sight...
« Reply #4 on: October 19, 2013, 02:26:19 am »
Hi Juan,
I did not install any update for W8.
Did you experience any progress with the SQ later?
« Reply #5 on: October 19, 2013, 02:42:43 am »
You are right Alain, and this will happen every time Windows launches a new OS or an important update. That is the weakest and unstable part of a computer-based system. Well, let´s face it with optimism.
Hi Juan,
Joachim, I'm sorry, I think I haven´t expressed myself correctly, I have not installed any updates on my music pc, I've installed W8.1 only on my work pc and in a laptop that I don´t use either for music. Mines were observations based only on a pc while working and as I say it looks to run faster than with W8.
« Reply #6 on: October 19, 2013, 11:28:24 am »
Sorry, but not that I know of ... swoon
Diede
« Reply #7 on: October 19, 2013, 12:17:12 pm »
Hi Juan,
I've been using W8.1 on my desktop for a couple of months now in preview version and I'm happy with it in terms of performance, in my experience a lot faster than W7.
I can confirm however that the W7 shell does not work in W8.1. When I installed it all I got was a black screen when I tried switching, and had to delete Windows NT\CurrentVersion\Winlogon\Shell parameter just to get the normal W8.1 screens back.
However the same guy has developed another small program called startisback+ (http://www.startisback.com/) that he sells for 3USD for two PC's.
It works very well, but is not the same as the W7 shell, you can now actively switch between both, so the W8 shell is still active.
That is why I didn't install W8.1 on my audio PC, and as such can't comment on SQ.
Diede
« Reply #8 on: October 19, 2013, 01:33:58 pm »
Can't we ask MS to put out its version 13 already ? At least it would ensure that we have stability for the next 15 years Wink
On the other hand, if v13 has support for odors, maybe XXHE will have to be deeply modified, with different nose schemes... Wink
When is ADN specific XXHE scheduled for ?  wacko
« Reply #9 on: October 19, 2013, 02:12:31 pm »
To be honest, I so many times have been wondering whether it could not be possible to make some sniffing device at the recording and a odeur spitting machine at my end. This is for movies though and maybe I came to the idea by being into cooking quite a lot and therefore watching such programs.
But for audio I don't see it really unless we like to able to get excited about the smell of a violin or piano (which both really smell nice with the proper oils applied). To me this seems distracting.
Peter (being half serious only)
« Reply #10 on: October 19, 2013, 02:34:09 pm »
« Reply #11 on: October 19, 2013, 03:37:43 pm »
Hi Juan,
Diede
Thanks Diede, we agree that W8 sounds better with the W7 shell but, would it be the same with W8.1?, maybe not. It seems that to install W8.1 it is mandatory to install previously other updates, at least the most important ones as can be read in the Windows 8 site:
"There are some updates you might need before you can install Windows 8.1. In most cases, the latest updates will be installed automatically using Windows Update."... (Prepare your PC - Get the critical and important updates: http://windows.microsoft.com/is-is/windows-8/update-from-windows-8-tutorial)
If it would not be mandatory I´d try W8.1 in the music pc even without the W7 shell to see how it sounds, but if I have to install the other updates I don´t feel secure doing it because then perhaps I might not be able to uninstall them. However, I remember reading from someone else (Alain?) that W8 sounds better, (or it was just different?), if it has the updates installed.
« Reply #12 on: October 19, 2013, 03:57:47 pm »
Hi Juan,
I did some test yes, but I also ran into problems - like unattended not working anymore in Minimized OS... So I finally came back to W8 plain vanilla...
« Reply #13 on: October 19, 2013, 04:24:17 pm »
I see, thanks Alain
« Reply #14 on: October 19, 2013, 08:33:31 pm »
After installing W8.1 on my regular PC without any problem (only the ATI-drivers were not up to date so HDMI-output was underscanned)  I just updated the music-pc.
No problems, only a reboot needed for UAC.
Music sounds good in unattended.
I can not really compare since I'm experimenting with my amps...
Funny thing is the wallpaper on my regular PC gets the same as on the music PC, so I can read what's playing while writing this.
Must be because I use the same live-account-user.
That's something not so nice, you need a live-account to log in.
This was optional in 8, in 8.1 I think its mandatory, unless I did not keep my eyes open?
