November 23, 2024, 02:22:01 am *
Author Topic: "HD Music\Chicago\X" does not show up in library  (Read 28062 times)
charliemb
« on: October 13, 2013, 04:50:04 am »
Hi Peter
"HD Music\Chicago\X" does not show up in the library.
The band is Chicago.  The Album name is X.
However, if I do a date search with D, it shows up.
It also shows up on the left pane if I navigate to the folder.
And in the same directory tree, the following albums do show up:
"HD Music\Chicago\Chicago II"
"HD Music\Chicago\Chicago V"
This is odd when you think of it because just typing in Chicago should show all.
And just typing in X still does not show it.
Makes we wonder how many other albums I have and can't see.
Any ideas?HD Music\Chicago\X
July 2019:
« Reply #1 on: October 13, 2013, 11:02:05 am »
Hey Charlie,
Should be some issue with that one character only ?
So I guess it is solved by naming the album "Chicago X" which I think also is the official name ? So especially regarding this latter, is it allowed to be solved like this ?
I must say it is a bit puzzling that searching for this X doesn't present anything either ...
charliemb
« Reply #2 on: October 13, 2013, 03:52:13 pm »
Exactly         (...try it on your end)
Especially when you consider that I have, for example, the Mercury Living Presence Box set which I stored in a tree like this (and in the following example, just searching for MLP2 finds all):
HD Music\MLP2\CD01\{Artist}\{Album}
HD Music\MLP2\CD02\{Artist}\{Album}
HD Music\MLP2\CD03\{Artist}\{Album}
etc.
This means that searching will find any string in the directory tree should come up with results for all.
So searching for "Chicago" should find:
"HD Music\Chicago\{anything}"   where in this case {anything}=X.
July 2019:
« Reply #3 on: October 13, 2013, 05:19:39 pm »
Of course, that is how it's intended.
All I can tell is that once the album does not show up in the Library Area, the search for it won't find anything anyway (because it sort of physically searches in the Library Area).
It's on the ToDo list !
charliemb
« Reply #4 on: October 14, 2013, 12:57:01 am »
All of this reminds me of another one that you've seen, or that I think you've seen.   When a directory includes the word "flac" in the string, the album shows up in the library, yes,  but the files do NOT load into the playlist.    I've seen this twice with the version in my sig (at the time of this writing it's the current version).
July 2019:
« Reply #5 on: October 14, 2013, 09:23:05 am »
Charlie,
I know that "flac" issue, and I even solved that a few versions ago. Apparently though there's other combinations possible (of how that "flac" is obtained in the title). Can you give me an example of one which won't load ?
charliemb
« Reply #6 on: October 14, 2013, 06:21:07 pm »
Hi Peter
Yes,  I distinctly remember one.  It's an Adele album in 48KHz and 24 bits.
The entire path name is now working correctly as:
D:\Music\HD Music\HD Backup Music\Adele\Live At The Royal Albert Hall 24bit 48Khz
From this path, I had removed the word FLAC in all caps and bare with no parenthesis around it nor brackets.  I only don't remember where it was;  probably it was on the very end.
July 2019:
« Reply #7 on: October 14, 2013, 07:20:26 pm »
Ah, ok. What I recall is that I anticipated on [FLAC] and (FLAC) (lower case as well), thinking it would be rather odd to have it just in there without parenthesis etc.  But either way when I'd remove that "FLAC" unjustiffied, everybody would only complain about the title not being correct (which a chance of zero anyway).
So will remove it.
« Reply #8 on: November 02, 2013, 05:58:06 pm »
Charlie, about the "X" issue ...
I can't mimic that; Created something as you said, put that in a Gallery, but no problem.
I Also tried the Chicago - X version (in this setup Chicago will be the Artist Name and X the Album Name) but also OK.
Now I don't know what to do.
« Reply #9 on: November 02, 2013, 06:00:17 pm »
The "FLAC" issue has been solved for the next version (current is 0.9z-9b, 0.9z-9d for some).
charliemb
« Reply #10 on: December 07, 2013, 08:49:43 pm »
New clues, new information about this problem.
Firstly,  I now believe (almost know for sure) that this problem has nothing to do with FLAC in the folder name.  How do I know?
Well, I never did change the folder "HD Music\Chicago\X".  I left it as X.   So what?  Well, now it shows up!!!
Next, I downloaded a new title with folder name "D:\Music\HD Music\Cassandra Wilson\New Moon Daughter" and I have the same problem.  That being, it shows up if I use a date search using [D], but does not show up if I do a text search if I type in Cassandra or Wilson.   Other Cassandra Wilson albums show up, but not the new one.    ????
WTF !
But what do these two have in common?   Both were downloaded from HDTracks.com.   And recently from HDTRacks, downloads have no folder.jpg.  Instead they use embedded images.
But xxHE does not see the embedded images.  So I manually put folder.jpg there months after I first reported problems with "HD Music\Chicago\X".    So this could be why it now shows up,  because I manually created a folder.jpg.
And I still have no folder.jpg for Cassandra's latest album purchase, and as I said it doesn't show up.
So, if I create a folder.jpg and suddenly it shows up,  then the lack of a folder.jpg file may prove to be the problem after all.  Though the above may prove to be enough to convince.
July 2019:
charliemb
« Reply #11 on: December 08, 2013, 05:02:48 am »
Nope, copying a folder.jpg into the Cassandra Wilson folder did not make it visible.   So that hypothesis is incorrect.
July 2019:
« Reply #12 on: December 08, 2013, 10:59:08 am »
Can't it be about "showing one too few" ?
If you just add one more album (of random artist, like Casandra Wilson was added in relation to Chicago), maybe then the Casandra Wilson album shows up ?
charliemb
« Reply #13 on: December 08, 2013, 07:30:42 pm »
I'm sure I've added at least one album since i first added Cassandra.  So i don't think that's it.
So maybe it is a matter of adding an extra Casandra Wilson album?
No, actually that can't be because I've not added any more Chicago albums since X.  ..and now X shows up.
July 2019:
« Reply #14 on: December 08, 2013, 07:37:11 pm »
Strange Charlie !
Can't this be about a UDF formatted disk ? in there all is strange (this is a sort of organization like CD).
