November 24, 2024, 08:37:20 pm *
Author Topic: AMD 6800K or the i7 2600?  (Read 11701 times)
Michel
« on: October 06, 2013, 04:12:43 pm »
Hi all
I like to know your option about this:
Mine rig is a i7 2600, asus B75 mobo , 8 gb 2133MHZ , Silverstone Grandia GD06B and a HD5450 fanless card. I just bought this card for watching movies. Because i like the amd color in movies...
If i replace this for a AMD 6800K( just for the HD8670D because it has more gpucores and more GB/s) and ASRock FM2A75 PRO4-M.
Will this effect the soundquality?
I really have no idea.
The sound i have now is open, wide, stage en great stereo.
And i love it smile
My files are flac 16/44 and HD tracks 24/96.
Michel
« Reply #1 on: October 06, 2013, 04:52:35 pm »
Hi Michel,
Maybe others have experience with this but I have the hunch that not many will be using AMD's. They have less cores (hyperthreading of the Intel's counted in) which are very useful for XXHighEnd.
There seems to be general consensus about the Extreme 4-M which fits in your case but I don't know whether that's the direction you want to go. Do notice though that any more modern processor deals with any movie easily these days, so it hardly can be about that.
The ASRock is highly tweakable and seems to do exactly what we guys want for SQ tweaks.
Another remark is NOT to have any GPUs on the processor. That only "influences" which we don't want. Otherwise, here too, any passively cooled 20 euro modern video card will play your movies. Whether with the right colour is up to you of course, so that is something to try out.
Not sure this is of much help, but at least I tried ...
« Reply #2 on: October 06, 2013, 05:35:02 pm »
Hi Michael,
While I do not have the same motherboard as the one installed in the XXHE PC, the advantages in having the same components are many as each new tweak and XXHE implementation "should" have the same effect... This makes everything easier to share: ideas, discoveries, perceptions, etc... But of course, it does not mean that you absolutely need to have the same machine...
Michel
« Reply #3 on: October 06, 2013, 05:36:34 pm »
Hi Michel,
Hi Peter.
Many thx for your reply.
Very helpfull.
Intel it is than.
So your saying , its better to have a cpu that has no gpu onboard right?
I switch off the igpu function in the bios.
Its not the same i geuss?
Michel
Michel
« Reply #4 on: October 06, 2013, 05:51:35 pm »
Hi Michael,
Hi Alain
Thx for the explanation.
Michel
« Reply #5 on: October 06, 2013, 06:38:12 pm »
Michel, no idea actually. But I am sure someone else will know ...
« Reply #6 on: October 06, 2013, 09:42:18 pm »
Yep, the IGP will be disabled and without a video card you will have no graphics Happy!
In my setup this wasn't a clear difference for the better, actually I preferred without it. But that was a long time ago. Maybe I should dig up the 20,- EUR card.
As a compromise you could lower the IGP clock to the minimal value.
regards, Coen
Michel
« Reply #7 on: October 06, 2013, 09:50:52 pm »
Hi Coen
I know its better to have a 20 euro grafic card.
The igpu sounds worse.
Michel
« Reply #8 on: October 11, 2013, 12:37:32 am »
Hi Coen
Michel
You are completely right! The IGP s@cks. That I did not think of it myself sooner unhappy. Sq is drastically leaping forward here.
Thanks for the reminder,
Regards, Coen
