November 23, 2024, 04:31:17 pm *
Author Topic: Version 9s-0 impression  (Read 28054 times)
« on: November 18, 2007, 08:28:31 pm »
Indeed the end of XXHighEnd?   grazy
Afther installing the new version I have got a lot of cracks in the sound. Changing Q1 has no more any affect on the cracks. Indeed the limit for mine DDDAC1543 is Q1=22 in the versions before. Changing the PCAS from Scheme-1 to -3 does not have a affect on the cracks.
Changing settings during playback stops the player and the only way to restart the music is via a restart of XXHighEnd!
Johan
« Reply #1 on: November 18, 2007, 09:02:22 pm »
A first wow the the sound i am hearing.... But a little too soon to react on that. But every time i load a new cd or a next track will result in a close down. I thought when reading your explaining that it would only happen once?
Or am i wrong....
 good good good
astacus21
« Reply #2 on: November 18, 2007, 09:18:10 pm »
Hi Peter
Fantastic sound so far, better than before, for sure. I'm using the default settings.
I had some problems with little cracks-pops, but i' ve changed the process affinity manually and they disappear.
I think this release is a huge step ahead.
« Reply #3 on: November 18, 2007, 09:21:51 pm »
Hahahaha, this is probably about the "combinations" I mentioned in the Releasenotes. Not sure though ...
When you want to change something like Invert or Q1 settings, click Stop, change the settings (load your tracks), and click Play.
In upcoming 0.9s versions those things will be possible ...
Edit : Sorry, I was responding to
Or am i wrong....
« Reply #4 on: November 18, 2007, 09:32:24 pm »
What do you mean, "manually" ? (this is kind of important I think)
And how did you set it in XX ?
« Reply #5 on: November 18, 2007, 09:36:23 pm »
When I play "Unattended" all the cracks in the sound are gone! In "Unattended" the changing of Q1 is working.  Without Unattended I have'nt found a solution for the cracks. As I sayed before Q1, invert, priority, scheme, ....has no affect on the cracks!
astacus21
« Reply #6 on: November 18, 2007, 10:31:05 pm »
from the task manager. I change the affinity of the process from there, to use only cpu 1 and not cpu 0 (dual core system)
after further listening i like the sound very much. I'm trying to set Q1 slider to a position that make highs a little softer, because imo after some time they become some kind of fuzzy (something like jitter effect).
I love the speed and the micro details...
Greetings
« Last Edit: March 15, 2009, 08:59:58 am by PeterSt » Logged
Chris V
« Reply #7 on: November 18, 2007, 11:49:41 pm »
Hi Peter
Notes on sound quality to follow Happy
At present I seem to only be able to play just one track of a playlist.  At the end of a track the player just stops and will not respond to pushing any buttons. After about a minute I get the message "engine 3 did not start within the expected time."
To play each next track I have to turn off XXHighend and reload it.  dntknw
Cheers Chris
« Last Edit: March 15, 2009, 09:00:10 am by PeterSt » Logged
Then to SW1X Signature DAC
Chris V
« Reply #8 on: November 19, 2007, 01:29:23 am »
Despite the bugs, this is the best version of XXhighend by far.
In my opinion all the incremental changes since its inception do not add up to the one single improvement made by 9s-0. Dynamic and revealing of small detail, yet without a hint of harshness. It gets my vote drinks drinks drinks
« Reply #9 on: November 19, 2007, 01:45:21 am »
Wow ...
And Chris, with "stop after one track" you mean at unattended playback, right ?
Or ?
« Reply #10 on: November 19, 2007, 03:15:28 am »
Chris ... no ... this must have been Attended Playback.
Solved per 0.9s-1.
But ... still the SQ improved so much ?
Now what ... if so, *that* was unintentional ...
wacko
« Reply #11 on: November 19, 2007, 03:34:42 am »
Now I think of it ... don't underestimate the new priority scheme ...
Chris V
« Reply #12 on: November 19, 2007, 10:08:26 am »
Glad you've fixed the problem  very happy
I cant grasp the concept of unattended operation, how does it differ from just loading lots of tracks and going away? I must be missing something wacko
Yes, I did note the new schemes and how they might help with glitches. Till now I have just run on SQ 14 with nothing else checked - so lots of experimenting to do Grin Grin
« Reply #13 on: November 19, 2007, 10:22:16 am »
Let's say it is a technical description of something really happening : the sound engine (#3) is like a running train, without the control of XXHighEnd. But with auto pilot it should do okay.
Also, and that is what it is all about, it eliminates the influence from the controlling section "XXHighEnd". That is, since we learned that it just influences, I wanted to get rid of it (the influence out of my control).
You could say that for the first time we are listening to the raw engine, and it expresses everything I layed in there to make it sound good. But mind you, I could never have heard it myself, so whatever it sounds like, so far this is kind of unintentional (intentional was : listening through the influence of XXHighEnd, although I did not know that at the time).
Chris V
« Reply #14 on: November 19, 2007, 10:33:50 am »
Good description and I seriously thought it meant leaving the room while the Hi-Fi was playing Happy Happy
I haven't tried unattended yet - perhaps more delights are in store clapping
Page created in 0.137 seconds with 19 queries.
