November 23, 2024, 05:10:30 pm *
Author Topic: Privileges have been set - Reboot now ... problem  (Read 4868 times)
« on: September 18, 2013, 02:34:47 pm »
Hey all,
On behalf of another user I have the question whether someone experienced the below, and if so what the solution is. We both got rather stuck ourselves.
We have a W8 Pro install. All actually works fine. This was an upgrade from W7.
Something goes wrong and the OS has to be reinstalled.
After that the message from the title appears from XXHighEnd, which by itself is the usual situation after the first playback attempt. However, after the reboot the message keeps on appearing, similar to how a Home or Starter version would do it. In the Tutorials there's a description for how to solve *that*, but in this case it all doesn't work because actually something else must be going on.
Never mind that the first OS install normally worked, did anyone experience such a thing for the Pro (or higher) version of Windows 8 ?
Thanks a lot for any possible help !
« Reply #1 on: September 18, 2013, 03:58:36 pm »
Not that I recall after you added in XXHE the correction for the administrative rights...
