April 06, 2025, 07:36:46 pm *
Pages: 1 2 3 4 5 [6] 7 8  All
Author Topic: WIN8 stops  (Read 112828 times)
« Reply #75 on: March 15, 2015, 10:38:13 am »
The last couple of weeks I have regulars Windows stops during playback. I have the impression that I have the most stops after a cold start of the machine. XXHE stops a couple of times in one track. Sometimes i see a message that xxhe is waiting on services to stop. Most of the time a move of the mouse or a key movement will fix the job. But very irritating. I'm now listening for tree track and I'm now 6 mouse movements further. The other solution is waiting and after 2/3 minutes it go's further. At the end of the day I have less stops.
I never had these problems in Windows 7. (I'm still thinking going back to win 7 for the other sound, but thats another discussion)
Any suggestions for these stops?
Regards johan
« Reply #76 on: March 15, 2015, 11:35:55 am »
Hi Johan,
It should be the obvious, but for the 100th time : Use Alt-u (or alt-d) after a minute or so into playback, after a boot.
Now it will never happen again.
But as said, "the obvious" so maybe you tried that already ?
« Reply #77 on: March 15, 2015, 08:07:06 pm »
did that work for you Johan?
Hi Johan,
« Reply #78 on: March 15, 2015, 09:57:32 pm »
but for the 100th time  unhappy: Use Alt-u (or alt-d) after a minute or so into playback, after a boot.
These stops are new for me. I was not expecting to have these problemes.
I have test the ALT-U or D today but it doesn't work. I'll keep these stops. I did reboots twice, Alt-U of D, a new startup, .....but it doesn't work. I think I have at least 10 stops per CD. I have my doubts about the sound of windows 8, but these stops makes it impossible to listen to music in windows 8 further.
I have red the hole topic about the WIN 8 stops twice, but I did not read a clear conclusion to fix the problem.
Please what are the right steps/procedure to get rid of these stops?
Regards Johan
tillen
« Reply #79 on: March 15, 2015, 10:03:45 pm »
Try this, it allways work.
Run as administrator, and reboot.
http://www.howtogeek.com/howto/15140/what-is-hiberfil.sys-and-how-do-i-delete-it/
Arnt
PC- Asrock X79 Extreme 4-M -
« Reply #80 on: March 15, 2015, 10:54:07 pm »
Thanks Arnt.
I have followed Coens procedure:
Solved?!!!!!
Without having any notion of the cause, but with plain practical thinking. Time will tell if it is really solved.
Here is what I did:
1) I booted into a "stops" version of the OS.
    I disabled the hiberfil.sys
    I rebooted, played some tunes, rebooted, etc
    As I expected the stops are there now at all boots.
2) so I enabled the hiberfil.sys again
    And booted into a "non-stops" situation
    I disabled the hiberfil.sys.
   As expected the stops are absent now at all boots (at least 3 in a row now).
Play and See, I mean Hear!
Johan
« Reply #81 on: March 16, 2015, 12:26:00 am »
I suppose this is the situation you never have started XXHE after a fresh windows 8 start!
First experience after this procedure after two tracks : one stop. wacko wacko
Johan
« Reply #82 on: March 16, 2015, 08:37:36 am »
Hi Johan,
If my suggested Alt-u does not help, then you didn't apply it. Haha. But I said after 1 minute and I read back a little ... must be after two minutes (not necessary to have that precise, but for 100% sure you can be too early).
So :
- Boot
- Play (Unattended !!)
- After two minutes Alt-u or Alt-d
done.
And please confirm whether moving the mouse helps when the sound has stopped. If not, then you're dealing with a complete different problem and nothing in this topic is going to help. Ok ?
« Reply #83 on: March 16, 2015, 08:43:37 am »
I'm pretty sure that somewhere in this topic Coen's procedure has been proven to not work for everyone.
The problem went away for almost everybody with a new version of XXHighEnd. Until later, here and there, it started to pop up again.
I, for instance, haven't seen it in 18 months at least.
Still it is no big deal at all, once you can apply that Alt-u etc. (needed only once per boot session). And I have never heard from anyone that *that* did not help.
« Reply #84 on: March 16, 2015, 05:10:59 pm »
It doesn't work. Stops again. A hit to the mouse and music plays again.
Regars Johan
« Reply #85 on: March 16, 2015, 06:19:38 pm »
Yes ... but I was only asking whether that helps to get the music going.
So it does. And so it is the same problem.
Now try to hit that Alt-u after two minutes and use a hammer when needed. And do not wait with it until the music has stopped ! (then it never helps any more). Anyway, check (and comfirm please) whether the volume changes indeed. Use 3x Alt-u if you're not sure you can hear it (yes, it is a bit difficult to check without Wallpaper).
Let me know ...
« Reply #86 on: March 16, 2015, 08:58:04 pm »
One stop only:
« Reply #87 on: March 16, 2015, 09:14:05 pm »
Indeed, Volume changed. After that two stops that evening.
« Reply #88 on: March 17, 2015, 08:06:04 am »
Hi Johan,
Why do I have the hunch that you mix two different "stops" situations ?
Did both these other stops continue by just moving the mouse ? Please answer carefully.
« Reply #89 on: March 17, 2015, 08:06:47 am »
One stop only:
rofl
