April 06, 2025, 08:41:08 pm *
Pages: 1 2 [3] 4 5 6 7 8  All
Author Topic: WIN8 stops  (Read 112841 times)
« Reply #30 on: September 17, 2013, 09:02:31 am »
FWIW :
Applied a cold boot last Friday, and sound stopped after a while (didn't take notice of the time). Stopped, Restarted and applied volume up. No more stops in something like 20 hours of playing in a row. Wink
Applied a cold boot yesterday. After 10 minutes or so, sound stopped. Moved the mouse, applied a volume DOWN. So, no Stop-Play this time. Did not help. Stop again after 10 minutes.
This time I did nothing and I just waited. Sound automatically continued after 3 minutes. I stayed out of any volume change (IIRC for all the hours I played), and no stop anymore.
The volume down not doing the job is I think the wrong conclusion. It just needs a Stop-Play. But when it happens again I will do that (with volume down).
« Reply #31 on: September 18, 2013, 09:00:06 am »
I had no more stops since I disabled the "hiberfil.sys" in the right OS condition.
Regards, Coen
« Reply #32 on: September 19, 2013, 10:40:09 am »
I am getting those stops regularly. Sometimes with every track. Sadly until now i cant boot in a situation where these stops do not apear.
Love the sound of though....
« Reply #33 on: September 21, 2013, 08:04:46 pm »
See my previous post ...
After a warm reboot, stop into the 10 minutes.
Moved mouse, Vol-Up this time. Stop again after the 10 minutes.
Moved mouse, did nothing, stop after 3:50.
So by now I now that Vol-Up or -Down doesn't matter and all is completely repeatable.
Only Stop - Play and then change the volume helps to eliminate it throughout the boot session.
And I sure can not relate that to anything in XXHighEnd ...
« Reply #34 on: September 21, 2013, 08:40:05 pm »
This is a way (see link below) to see if this hiberfil is on or off. Meaning dir c:\ /ah
I think i managed to get rid of it by means of the trick Coen wrote. Until now no stops anymore.
http://www.nextofwindows.com/hiberfil-sys-in-windows-8-and-why-you-shouldnt-disable-hibernation-to-delete-it/
But i have changed more things in the same time to be honest. I now that is stuppid.  unhappy
minzyman
« Reply #35 on: October 03, 2013, 06:02:47 am »
 unhappy Just reading thru these posts now as I am encountering exactly the same stops randomly during playback. I assumed it was clock as I was running playback at 1ms (Q1=14, Q5=5, Qx1=10) with standard settings elsewhere and no Xtweaks.
I found that changing clock to 10 or 15 ms seemed to stop the er...stops. But perhaps it was just me moving the mouse that did it? Have no idea but is frustrating.
/Lee
W8 = Jan 10, 2013 (1.186a)
Zalman (Fanless) Chassis with ZUMA Design: Intel DH77EB MB and Intel i7 3770s (quad core) CPU / 16GB RAM / Win 8 Pro SP1 from OCZ SSD / second (Playback) drive OCZ SSD / music on 3 TB eSata HD / XX on OS disk SSD Engine#4 Adaptive Mode / Q1/-/3/4/5 = *6*/-/*1*/*1*/*1* / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = *4.0* (max 120) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = *Core1-2* / UnAttended (Just Start) / All Services Off  / No Running Time / Minimize OS / NO XTweaks / 24/768 Phasure NOS1 async USB DAC, Driver v1.0.3 at *8ms* -> main amps -> speakers. No remote, screen off at unattend playback, cd rom unplugged, ethernet cable unplugged, max core temp 117 degrees F.
« Reply #36 on: October 03, 2013, 09:02:36 am »
Hey Lee,
The Clock Resolution is highly suspect, but only in theory; The processor frequency would be as suspect and at least that does not help (I tested that). Still, although both are related to eachother, the ClockRes on its own could do a couple of things.
Anyway, one time VolUp during playback (I assume Unatteneded and no idea whether that in itself is related) and the problem is gone for that boot session. Here that definitely helps. So, it is only frustrating when one doesn't know about this "trick".
minzyman
« Reply #37 on: October 05, 2013, 07:40:24 am »
Yes, strangely, this vol thing seems to work. Any idea why?
/L
« Reply #38 on: October 05, 2013, 10:52:43 am »
No. But is it something in the OS. Things which after a precise amount in time fall together and all stalls. I didn't investigate it (because it can't while moving the mouse already activates is) but it wll might be so that the whole OS is stalled at that moment.
As I said earlier in this topic - the log files show that just nothing happens anymore. Unrelated to the playback software.
Btw, I have the hunch that just using Alt-m after a reboot and when Unattended Playback commences, might do the job as well (so instead of Alt-u or Alt-d). I will try that when I rebooted for whatever reason (can easily take 3 weeks for that to happen here). In the mean time others may try that too.
« Reply #39 on: October 05, 2013, 06:24:51 pm »
No, Alt-m does not help;
I had an idea about it all, but the wrong idea obviously.
« Reply #40 on: October 05, 2013, 06:34:22 pm »
Forgot to tell :
For some test (more about this tomorrow) I changed my Q1 x xQ1 (@4096) from 14 x 10 to 14 x 1 while (because) I changed my SFS from 120 to 4;
This doesn't change a thing to the Stop issue.
« Reply #41 on: November 14, 2013, 09:24:19 am »
Although I have the experience of one boot only (and explicitly staying away from any volume change), in Windows 8.1 no stops ...
« Reply #42 on: November 15, 2013, 08:24:04 pm »
This can be regarded solved with Windows 8.1.
2glory
« Reply #43 on: January 25, 2014, 03:37:15 am »
I have 1.186a up and running and came across the old move the mouse trick to get the tunes back on track after the music shuts down. Did the whole re boot Alt U/D after the first song within a min or so. Did nothing! So taking a few swipes at the "fly" I said buggar it I will wait the guy out. 2 or 3 mins. later the fly is dead and the music is ripping out of the speakers.
One dead horse fly.
« Reply #44 on: January 25, 2014, 11:25:07 am »
Or IOW the question is :
Does anyone else still suffer from music stopping but moving the mouse brings it back ?
Please respnd when so, because I had the idea this was completely solved by 1.186a ...
Thanks !
Page created in 0.038 seconds with 16 queries.
