« Reply #15 on: September 10, 2013, 08:40:43 pm » |
Peter, I'm glad the stops were accidentaly reproduced in your system  . We aready picking the fruits of that misfortune! I have a remark about rebooting. There is a difference in w8 between closing it and restarting the pc and a win8 coordinated restart. The latter seems to take far more time and strange stuff happens. If i understand correctly your cpu multiplier changed, anyway i experienced a similar situation that my multiplier was changed (if that was the case with you). That was after a win8 coordinated reboot. I've not been playing attention to my vol changes and when I apply them. I will check this later tonight. Regards, Coen Regards, Coen
« Reply #16 on: September 10, 2013, 08:57:50 pm » |
....Windows Update... ?
Ok, well, hum... Not "Security" Ones... !!!!
I will also check the updates! (I was talking above about the volume setting Peter hints at to making a difference in the stop behaviour). Regards, Coen
« Reply #17 on: September 10, 2013, 10:00:03 pm » |
I don't think there is any need to look at services etc.; I've been looking too much at everything myself in similar situations that I think I know this won't bring a thing. What I would do for trials is shut off hybernating. If you want I can dig all up from somewhere, but this is about the actual "hybernate" mode W8 puts herself into while rebooting (or shutting down), which is the trick to boot faster. And it is here where things for sure "happen", although I don't recognize your situation Coen. But this doesn't tell a thing by itself. Ok, the link I had for it is dead by now, but this one looks to be OK : http://www.howtogeek.com/howto/15140/what-is-hiberfil.sys-and-how-do-i-delete-it/Maybe it is different for W8, but I guess Google will help you here. So, the "trick" is to disallow W8 to use the hybernation facility at normal shut down (or reboot). Undoubtedly this will slow down booting severely, but I think this is going to help. Notice : for consistent behaviour, which may mean that you now have the problem always. Investigate first how to re-avtivate this (I didn't look whether that is in that page I linked to). Peter I Googled on this and it seems that hybernate is NOT a default option of WIN8 anymore. All tips are about locating this function to be part of the options again. The hiberfil.sys file is used for speeding up all boot cycles in WIN8. It is not recommended to delete this file. Regards, Coen
« Reply #18 on: September 10, 2013, 10:33:20 pm » |
10:45 after the start of Playback - a stop. Move mouse, sound continues. 5:30 minute after that (actually during this typing) again stop. Move mouse - go on.
My timings are different: I booted from a win7 session into win8. For shure the stops will occur. And they did. The first stop happened today (after volume up) at about 8:30 minutes into the track accompanied with heavy HDD activity. After that I can play 3:58 minutes before the next stop. Stopping and starting gives at exactly that same time a stop repetitively. Changing the vol slider up or down seems to have NO effect. SQ has a fuzzyness. As below my cpu is @30X100MHz. This seems unrelated. After shutdown and restart there are NO stops anymore ánd NO fierce HDD activity at 8:30, the HDD starts though but very modestly. I did NOT touch the volume slider nor the mouse after starting xx (actually only the mouse for initating playback). SQ is clean. So it is not some uncorrelated WIN8 process. It has to do with the dataloading of whatever needs to be loaded for XX playback. Contrary to your postings I find a reboot makes all the difference in both sound and stops. Regards, Coen [edit] My first tracks are FLAC. Please note that I am open to the possibility that it is NOT boot related at all, but so far the stops have been cured by a reboot.
« Reply #19 on: September 10, 2013, 10:38:24 pm » |
Just for the record: I've absolutely no updates or hidden updates on my music PC. Software version is "plain vanilla" Windows 8 Pro 64 bit, build 9200. Regards, Coen
« Reply #20 on: September 11, 2013, 02:40:34 am » |
Well I did try the Windows Update for "experimenting" and I strongly advise against it... Something is generating a Service error and unattended does not work (in Minimise OS that is)...
There are lots of "unknowns" in W8...
« Reply #21 on: September 11, 2013, 07:45:46 am » |
The hiberfil.sys file is used for speeding up all boot cycles in WIN8. It is not recommended to delete this file. Hi Coen. I don't think you got the message from my post about this (looks like you didn't read it at all ?  ). Now, eliminate that process (and yes, didn't I tell about slower boots ?, so ... read please). Peter
« Reply #22 on: September 11, 2013, 08:35:16 am » |
The hiberfil.sys file is used for speeding up all boot cycles in WIN8. It is not recommended to delete this file. Hi Coen. I don't think you got the message from my post about this (looks like you didn't read it at all ?  ). Now, eliminate that process (and yes, didn't I tell about slower boots ?, so ... read please). Peter Ok, its off. Powercfg -h off. I followed your recommendation to google for win8. I found lots of tips that I don't trust. Experience tells me better safe than sorry in such a situation. Regards, Coen
« Reply #23 on: September 11, 2013, 08:43:42 am » |
Coen, that is OK.
I shut it off in my W7 ages ago.
For W8 it is about the "trick" it applies for faster boot, of which I have already proven it can do strange things. So, it now always works consistently. No guarantee that it works for the better either - I just don't know. But to remove the inconsistency coming from it ...
There should also be no difference anymore between cold boot (after power up) and reboot. There 100% was which I can easily see (with a dual boot and some tweaks regarding that).
PS: What happened to me yesterday ? still no idea. But after that Vol-up no single stop anymore for all the hours I played. And to remember (for myself) : When it happens (after a boot) and I stop playback and start again, all is happliy reset and the stop happens at the exact same time (different tracks, incluing tracks longer than before it stops). I didn't watch disk activity, but if so it can only be the OS disk (the only disk in there).
« Reply #24 on: September 11, 2013, 09:23:09 pm » |
Ok,
Solved?!!!!!
Without having any notion of the cause, but with plain practical thinking. Time will tell if it is really solved.
Here is what I did:
1) I booted into a "stops" version of the OS. I disabled the hiberfil.sys I rebooted, played some tunes, rebooted, etc
As I expected the stops are there now at all boots.
2) so I enabled the hiberfil.sys again And booted into a "non-stops" situation I disabled the hiberfil.sys. I rebooted, played some tunes, rebooted, etc
As expected the stops are absent now at all boots (at least 3 in a row now).
So Peter, if this applies to you (disabled hiberfil.sys) it looks like you are in situation 1), at which apparently over time the stops disappear at resetting the volume and magically reappear by an unknown event.
Of course this has to work for some time before it can be proclaimed "finally solved", when I run in to trouble again I will post.
Regards, Coen
[edit] To clarify "as I expected": my working hypothesis was that the hiberfil.sys was the cause of the "flip" between stops and no-stops operation.
tillen
« Reply #25 on: September 12, 2013, 12:07:45 am » |
Check defender, I ran into similar after an update. If it is about windows logging off.
PC- Asrock X79 Extreme 4-M - i7 4930K Hyperthreading On (12 cores) 32GB, Windows 10 Pro 64 bit build 10393.0 RAM-OS, music on LAN / Engine#4 Adaptive Mode / Q1/-/3/4/5 = 14/-/1/1/1 / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = 0.05 (max 60) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/ Playback Drive / UnAttended / All Services Off / Keep LAN - Not Persist / Minimize OS / XTweaks : Balanced Load = 43 / Nervous Rate = 1 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = Stable/ Custom Filter Mid 705600 / -> USB3 from MB - Sw#3 off NOS1a = Up) -> Clarixa USB-> 24/768 Phasure NOS1a async USB DAC 75B, Driver v1.0.4 (4ms) -> Blaxius BNC interlink
« Reply #26 on: September 12, 2013, 08:44:06 am » |
Coen,
That was a smart idea of me, right ? But your stacked idea is brilliant ...
« Reply #27 on: September 12, 2013, 10:08:19 am » |
Coen,
You know teamwork: 1+1=3  Regards, Coen
« Reply #28 on: September 12, 2013, 01:33:15 pm » |
Congrats to you two for this solution  I would never have thought about this ! But I also have to admit that I don't get it ? While I understand that hibernation in W8 keep what is active in ram, I don't understand how this had to do with the behavior about these stops. But on the other hand, I have to add that I never got these stops. I am clueless... Does this mean that the ramdrive is already there when the system boots ? Regards, Alain
« Reply #29 on: September 12, 2013, 01:58:18 pm » |
No, this means of faster booting is only for (driver) parts of the OS. But the principle of course is the same as normal hibernation (which indeed would reload all into memory as well).
