April 06, 2025, 08:41:09 pm *
Pages: 1 2 3 4 5 6 7 [8]  All
Author Topic: WIN8 stops  (Read 112842 times)
« Reply #105 on: March 23, 2015, 01:18:48 pm »
Johan, can you try this please :
Open a Command Prompt "as administrator";
(by heart : type cmd in the search box after clicking the Start button, rightclick on the link which appears and then "Run as administrator").
In there, type this :
powercfg -h off [enter]
exit [enter] (to leave the command prompt)
Now reboot.
This will disallow the "fast boot" and the saving of memory to disk (which Windows 8 otherwise will read back at a next boot).
Notice that with this you also eliminated the "hibernate" option from the PC, but this is no big deal (so only a normal shut down is possible now). If you want it back on then open the Command Prompt again and type
powercfg -h on [enter]
See if this changes things ...
PS: I am not sure whether I suggested this before but I don't think so.
« Reply #106 on: March 23, 2015, 05:46:50 pm »
I'm using this setting for one or two weeks. Thanks.
Regards Johan
« Reply #107 on: April 04, 2015, 09:16:20 am »
Johan, is there a difference when you do NOT stop Remaining Services ?
(but maybe you're already doing so)
« Reply #108 on: April 04, 2015, 10:20:06 am »
No, that makes no difference. Usual the music stops are there only in the beginning (startup pc) and without a errormessage. Mostly later in the evening no stops. But this morning every track a stop. To fix the stop two solutions:
- Do nothing, after 1 or 2 minutes music continues;
- Move the mouse.
One new situation after this services change is that when i start a music play session, sometimes xxhe first needs a mouse move or pause before starting.
Best regards johan
« Reply #109 on: April 04, 2015, 10:57:51 am »
- Move the mouse.
Best regards johan
Try to speed up the CPU. That helped a lot in my win 8 day's.
« Reply #110 on: April 04, 2015, 11:03:18 am »
Johan,
I have two more options, and the first one is only when you like to try it; I mean, that won't be for a definite solution I'd say : shut off Hyperthreading.
The second option I have more hope for : switch of the Garbage Collect which is in the Memory section in Settings.
I really don't know how this can behave so differently in your situation while actually it *is* the same problem. All I can see is that you use an MSI MoBo which is not the most common for us I think. Maybe the processor too is not common, but this is harder to judge for me.
Just trying ...
« Reply #111 on: April 04, 2015, 05:14:35 pm »
I have tested both options no positive effect. Stops remains.
I've also tested the suggestion of Gerard to speed up the cpu clock. I did a increment from 0,8 to 1.8 GHz. Also no effect. Today is a terrible xxhe day.
Best regards, johan Old
« Reply #112 on: April 04, 2015, 05:20:20 pm »
I was trying to test the following suggestion see link: http://www.thewindowsclub.com/usb-devices-not-working-windows , but i could not found the following parameter: EnhancedPowerManagementEnabled
« Reply #113 on: April 04, 2015, 11:29:52 pm »
After your earlier suggestion to change the services setting, it has the following effects on the stops.
- after a play comment no music direct a stop, moving the mouse starts the music;
- i have used a stopwatch and every 4 minutes there is a stop untill the end of the cd.
After selecting stop desktop / stop remaining / stop wasapi / stop all services: music starts after a play command and no more stops during this cd.
Johan
« Reply #114 on: April 05, 2015, 01:06:30 pm »
This morning only the first two cd's had stops every 4 minutes. Without a change it looks like all next cd's are playing well now without stops.
Any suggestions?
Best regards and a happy easter
Johan
« Reply #115 on: April 05, 2015, 01:16:01 pm »
Hey Johan,
I now wonder ... do you always shut down your PC each end of the day ?
« Reply #116 on: April 05, 2015, 01:42:08 pm »
......yes.yes
« Reply #117 on: April 05, 2015, 01:52:31 pm »
What about : then don't ?
I mean, if you seem to proove that you can get rid of it, why give yourself the trouble of running into it each day ?
All of my PC's are never shut down ...
