November 23, 2024, 08:17:26 pm *
Pages: 1 [2] 3  All
Author Topic: W8 Ticks  (Read 38364 times)
« Reply #15 on: September 08, 2013, 01:11:09 am »
Hi Paul,
I guess I will not taste my beer for a while, but I will raise my glass to you and the solution that will come from Peter Happy
« Reply #16 on: September 08, 2013, 01:35:19 am »
Hi Juan,
I think that the problem you express has more to do with the way the NOS1 and Windows behave.
I guess we are talking about unattended mode. I can't say if it does the same in attended mode.
Like you mention, if I wait long enough after the music is gone, then no noise happens.
When the music finishes, the NOS1 is still sending a "silent signal". I would compare this to "pressure in the conduit". If you immediately restart the PC, this is "cut" by Windows at some point and there is a residual that is "released" as a tick...
My explanation is "full of holes", but I am sure that Peter has a clearer explanation than I Happy
« Reply #17 on: September 08, 2013, 09:01:57 am »
Guys,
It looks like I need to close this topic. You are clearly talking about 3 totally different situations. This should be clear to you just as it is to me.
Ticks at reboot are very well known are are about the PC and USB (again) and it creates DC Offset. Watch the NOS1 meters. This should not be in this topic.
Ticks at track starts are even more known and this is a bug in the XXHE software which I guess I will never find. That these depend on buffer sizes is not known to me. Start a topic about this if you want. But not in here please.
What remains are the random ticks Paul talks about. I think that is allowed to stay because it was Paul's subject after all (but he could have made it more clear maybe).
« Reply #18 on: September 08, 2013, 11:20:47 am »
Thanks Alain.
Peter, that´s Ok, for my part the topic is closed, I do not experience random stops. The only other thing that happens to me, and very rarely, are stops in the middle of the music and it recovers with Alt + X or mouse movement, if you want treat it in another topic or here, what you think is best.
« Reply #19 on: September 08, 2013, 11:54:49 am »
Juan, please do if you think it should be solved for you. But I think a topic about that already exists ?
« Reply #20 on: September 08, 2013, 12:14:23 pm »
Ok: http://www.phasure.com/index.php?topic=2706.msg27988;topicseen#msg27988
« Reply #21 on: September 09, 2013, 10:21:49 am »
After running for some time with NOS1 driver buffer setting at 8ms I still get ticks but less than at 16ms. Actually it can be more like static so after a (sometimes considerable) period of say 10 minutes without ticks I get a short sharp burst of ticks. It is also more prevalent on string / guitar / cello music than on denser music. Actually if I play a denser piece of music I hear nothing at all.
I then reduced the buffer to 2ms (1ms does not work so 2ms is the threshold on my system) and apparently the ticks have stopped. I say apparently because I am not convinced that the problem has been fixed because if I listen carefully I can hear what sounds like spasmodic uneven sounds - maybe static that does not get a chance to get going because of the short buffer time. Well that probably makes no sense but anyway ............
Cheers Paul
« Reply #22 on: September 09, 2013, 02:21:42 pm »
I have had this issue as well but I think less often than Paul. In a two hour listening session it will usually happen one time, but sometimes two. It's always random and always in the middle of a track. Here it is somewhat like a popping sound though not very loud so it seems like a tick. I haven't tried adjusting the buffer yet but will give it a try. It happens with both the ASRock and ASUS mB's. Never happened with W7, which I haven't listened too in quite a while.
« Reply #23 on: September 09, 2013, 03:59:56 pm »
Paul (Brian won't be able to answer this I think ?),
Can you recognize that this is on the beat of the music ?
Maybe you recall a somewhat longer topic about this (W7 times and maybe just over a year ago). But this was solved if all is right ...
IOW, be sure to use the last XXHighEnd version (undoubtedly so, but saying anyway).
« Reply #24 on: September 09, 2013, 04:28:42 pm »
Peter - it is too random it does not seem to be related to anything in the music. Am using latest software. Will listen again tonight see if I can get any more clues.
« Reply #25 on: September 09, 2013, 06:19:27 pm »
What about changing the Clock resolution ?
Or first set Q5 to 0 maybe ...
« Reply #26 on: September 09, 2013, 08:00:44 pm »
Clicks occur with all the following settings:
Q5=0 and Clock Res=0.5
Q5=0 and Clock Res=Nothing
Q5=5 and Clock Res=0.5
Q5=5 and Clock Res=Nothing
Can take quite a while for ticks/static to come along because they occur so randomly.
« Reply #27 on: September 18, 2013, 09:23:39 am »
Hi Peter - I have not managed to solve this problem but the problem is reduced by reducing latency so with settings at Q1=10,0,0,0,5 Q1f=1 and SFS=2 the "Ticks" have become shorter more like the ticks between tracks. So not a solution maybe a workaround.
Oh and I have found an album track where the problem is totally repeatable. Maybe I could take a WAV screenshot and indicate where the problem occurs if that helps.
Any ideas for further tests welcome.
« Reply #28 on: September 18, 2013, 01:45:54 pm »
After further checks I found that these "Clicks" happen in Windows 7 as well. So then I checked the actual "ripped" track using a WAV editor. These clicks are on the file on disc. Now that is a worry. First thoughts were that these could have been caused by EAC but then I found clicks in a track I ripped many years ago and I know for absolutely certain that there were no clicks when the original track was ripped.
Is it possible that clicks have got onto the file during copying - that does not seem possible. Any ideas anyone? how could a file be corrupted? Actually thinking about it what is strange is that the file in question has clicks in very defined places in the music passage - along with the beat. I would have to think they must have always been there but for sure I would have noticed them they stick out like a sore thumb in the music.
 wacko Paul
« Reply #29 on: September 18, 2013, 01:54:38 pm »
Hi Paul,
Do you go on Qobuz website ? If you can and you find that album, it is most of the time possible to get only individual songs.
It could help you determine if this is in that recording or not ?
Pages: 1 [2] 3  All
Page created in 0.127 seconds with 19 queries.
