November 23, 2024, 07:33:29 pm *
Pages: [1] 2 3  All
Author Topic: W8 Ticks  (Read 38353 times)
« on: September 06, 2013, 04:27:00 pm »
When listening to music I get ticks/skips. Sometimes its OK sometimes it is infrequent sometimes worse than others. It happens when using IMDISK or running from HDD. It only happens in W8 it is never a problem in W7 with the same settings (dual boot). It seems to happen regardless of settings in W8.
I seem to remember you have mentioned this before and IIRC you had it for a while but it stopped.
Any ideas what I can do to rid my system of this pesky bug?
Paul (retired batch file programmer).
« Reply #1 on: September 06, 2013, 04:44:44 pm »
Hi Paul,
I can't explain why this happens, but I just know that at some point, I had to reduce the NOS1 driver from 16 to 12ms, even lower.
I also have experienced stuttering when having "Nervous rate" at 70 +...
Maybe you have already done this, but I suspect that what would have been working for W7 does not behave the same with W8 ?
« Reply #2 on: September 06, 2013, 04:49:03 pm »
Here I have also some ticks (not skips) with W8 but I had it with or without Imdisk, so I don´t think that the problem is Imdisk. One loud tick happens when restarting the computer at the moment it is turned off, that happens if I don´t wait for around 30 seconds after closing XXHE. Now I´m testing a linear power supply for the external hard drive (with data) and the ticks are much lower and very often there is none. Could those ticks have to do with the wall wart power supplies?
« Reply #3 on: September 06, 2013, 05:08:55 pm »
Hey Paul,
(and for others, I think Paul talks about ticks during playback)
I don't recognize ticks at all. The stops yes. I never ever had one anymore after my attempt to change the default "power saving" setting on USB (in Windows Power Settings). That made it worse (as it seemed; only used that setting for one hour maybe) and then I set it back to were it was.
No stops ever since. Can hardly be a coincidence, because I had one each and every day.
Try it ...
« Reply #4 on: September 06, 2013, 06:38:25 pm »
Peter & Alain - thanks for your suggestions I tried them both (NOS1 driver to 12ms) and USB power to off (still got ticks) and back to on (still got ticks). Actually maybe not so much ticks as occasional static sound.
So I still have ticks. Anymore suggestions welcome I have run out of ideas. By the way this is not new it has happened since going to W8 its just that only now have I had time to investigate properly.
P
« Reply #5 on: September 06, 2013, 07:18:29 pm »
Ok Paul - Ticks exactly when ?
« Reply #6 on: September 06, 2013, 09:13:40 pm »
Randomly during playback nothing for a while then some static/ticks together BUT earlier I reduced NOS1 driver further to 8ms and have not heard a tick since. Mmmm need to give it an evening to really give it a proper test as it was somewhat random before.
Watch this space.............
Alain - if it works I owe you a beer (or two.....)
P
« Reply #7 on: September 06, 2013, 09:30:52 pm »
Cool ! Happy
I remember now, it stopped at 8ms for me... I was trying to mimic Peter's parameters, then I realized i could not imitate him Wink
« Reply #8 on: September 07, 2013, 07:10:07 pm »
Hi Alain your solution works (almost totally). If I reduce the USB buffer size in the NOS1 driver from 16ms to 12ms the ticks barely audible and that´s being very near to the speaker and at 8ms I have to put my ear almost touching the speaker to ear an almost imperceptible tick every time a song starts. Now the ticks don´t bother me at all, so thank you! The problem, if it means that there is a problem, is that the ticks are still there.
« Reply #9 on: September 07, 2013, 07:23:15 pm »
Hi Juan,
I am not sure if this is related to underclocking or to any setting in XXHE that is too near some kind of boundary... I would try it in NORMAL OS mode also to see if anything about this has an effect or not.
Having multiple settings interacting with each other has its pros and cons Happy.
« Reply #10 on: September 07, 2013, 07:25:58 pm »
Hi Juan,
Alain, I haven´t tried it in Normal mode, I´ll do it to see what happens.
« Reply #11 on: September 07, 2013, 07:55:47 pm »
Juan,
Just an observation... The tick that you hear at the beginning of a song has been here since the beginning, when I was still using WinXP... Do you mean that or other ticks happening while the music is playing ?
« Reply #12 on: September 07, 2013, 11:00:33 pm »
Alain, I´m talking about the tick that´s at the beginning of a song, and yes it is there forever, I don´t know why I thought that with W8 it should have gone. Anyway, with your settings in the NOS1 driver (12ms/8ms) the tick is unnoticeable. The other tick I have is much loud and it happens when I restart the computer if I don´t wait for a while, 30 seconds or even more, after closing XXHE.
« Reply #13 on: September 07, 2013, 11:03:45 pm »
At 8ms the problem appears to be reduced for me - better than 16ms. But at 4ms it does not improve any further so not the complete answer. Interestingly I do not seem to get the problem at all on tracks/albums that are more dense with more going on in the bass. With string quartets and guitar music I still get the problem but it is certainly reduced compared with 16ms. It is only something that happens in W8 never had a problem in W7 with the same settings.
P
« Reply #14 on: September 08, 2013, 12:01:34 am »
Ah... Could it be that these 2 situations are from 2 different sources ?
Pages: [1] 2 3  All
