April 05, 2025, 06:35:46 am *
Pages: 1 2 3 [4] 5 6 7  All
Author Topic: USB Cables... again  (Read 96276 times)
« Reply #45 on: September 13, 2013, 06:57:33 pm »
Here's a cable thats a lot cheaper than the Enopias:
http://www.yourfinalsystem.com/component/virtuemart/v4-audiophile-usb-cables/highend-audiophile-usb-v4-cable-1-0m-dataonly-17-21-25-detail?Itemid=0
And a short article on the subject:
http://yourfinalsystem.com/cable-design-f-a-q/147-how-do-data-only-usb-cables-work
« Reply #46 on: September 14, 2013, 01:23:36 pm »
Thanks Brian, these cables at least have a reasonable price. Do you know someone who has used these cables?
It looks that the USB cable issue is still open...
« Reply #47 on: September 14, 2013, 02:13:14 pm »
Hey Juan, I don't know anyone who's used this cable, but they do have a 30 day return policy. If for a decent price they make them in a 6 to 7 foot length, I'm going to order one and will post here about it.
« Reply #48 on: September 14, 2013, 02:25:46 pm »
Brian, it looks that YFS has two Data Only USB cable, the Reference and the V4, I think that both are built only of 1 meter length (the V4 is also built of 0,6 m.) so I´m not sure if you could get 6 or 7 foot length. Would be nice to hear from your test if possible.
« Reply #49 on: September 14, 2013, 02:30:45 pm »
I have always wondered if a USB cable needed an "ideal" length to be efficient. From what I read about Peter's USB cables, it seems that it does not. On the other hand, someone told me that the Clearlink USB cable needed to be 3 feet, nothing more, nothing less. Maybe the design of that cable requires this, but some others will say that the shorter, the better - like in "the best cable is NO cable"...
« Reply #50 on: September 14, 2013, 02:42:16 pm »
This is from YFS web site: "Our Reference USB 2.0 interconnect only comes in a 1-meter length. This is based on the tedious work involved and the extra materials used to make the Reference design. It's not as easy as it looks. Contact us if you have a need for a length longer than 1 meter and we MAY be able to accommodate you. We aren't making any promises but we'll see what we can do."
I personally tested different lengths of the same USB cable, like 0,6m, 1m and 1,20m, and couldn´t see a difference. It looks like the problem is noticeable with lengths longer than 6 or 7m.
« Reply #51 on: September 14, 2013, 02:52:59 pm »
Juan, I'm waiting for their reply regarding the length. Will let you know.
« Reply #52 on: September 16, 2013, 09:17:49 am »
There is no USB cable issue. And if there is, the source of it is outside of "the USB cable".
Hopefully it doesn't sound too confusing, but when I have all right in the general noise department, there is also no USB cable noise issue. However, it is the most easy to imply issues hence to see the USB noise implied by USB transfer. Next you can (indeed and undoubtedly) solve that by means around the USB connection itself. Maybe it works for you, but how to tell it is for the better (and I still did not see it proven that what's perceived as "better" really is, because the worse situation implies more bass and less though blanketed highs - an easy pitfall).
The story will be more complicated I'm afraid, but "stating" that there's a USB issue goes too far. In general sure yes, but with the NOS1 no. And if so, people should (finally) be able to perceive crazy differences in SQ just by replacing the 1$ USB cable for anything else. And I mean normal means of USB cables, and not those with separate (additional) ground wires or whatever, like subject to this topic here.
And of course, everybody can do what he likes. But - and again - what I don't like is stating a general "USB issue". Not until it has been proven there is.
Did I say it in this topic somewhere ? First remove the audible noise from the speakers, which for 100% sure won't be reached by USB cables of any strange kind. Just saying (again) ...
PS: Juan, this for 100% sure was no personal attack. But we must realize that people are talked into obsessions unjustified (not that you started the subject, but you could be a first to be obsessed about something unjustified ... IMO).
« Reply #53 on: September 16, 2013, 12:06:49 pm »
Hi Peter, I only wanted to say that the controversy (if there is some controversy) on the influence on SQ using different USB cables remains open. Not in the sense of solving the problem of noise but in the sense that different cables produce different sound. The truth is that I have no noise problems, at least I do not perceive it and yet I notice differences in sound with different USB cable, just like I notice differences between a USB2 cable  and one USB3.  This is what I meant when I said that the USB cable issue remains open.
No way I could see it as a personnal attack, we are peaceful people ;-)
PS. Sorry for the errors and faults, I'm writting from muy phone and don't have muy laptop with me.
« Reply #54 on: September 16, 2013, 12:49:33 pm »
Hey Juan,
I am "working" from memory mostly, and I didn't recall any "issues" from your hand.
So, I just looked back in this topic to be sure, and I still don't see them. However :
Now you suddenly (??) write this. So you see ? this is how I feel entitled to not hype-up things (which in my view is about copying other's situations or expressions, which in the end have no merit (to me, and thus I feel that it should not have to others as well - which is just what I am warning for)).
But now your more full sentence (hence better context) :
Looks like an easy to write sentence to me, meaning that it can consist of some unmeant "merits". So, I read this as "different USB2 cables make a difference just like using a USB3 connection makes a difference". But is that what you really wanted to say ? Thus ... it is easy to think that a USB2 vs a USB3 connection makes a difference (which it does for logical (because electrical !) reaons), but mind the "connection") and "thus" USB2 cables will make a difference as well, no matter you never tried ...
(oops, this sentence may be hard to understand, sorry)
So, careful here. USB cables are allowed to make a difference (but where is the most clear example including a more or less proper description of it), while a connection means should make a difference. USB2 vs. USB3 is such an example, and USB2 copper vs. USB3 glass is another.
And please stay away from not daring to "admit" that even two USB2 cables on a USB2 connection make a difference for you (because I tend to say they should not, haha), because I can perfectly bear that. It's only that I never heard of such a thing clearly before, where btw Mani's connection (this topic's real subject) also is not about a normal USB2-USB2 (or 3) comparison (that's just about changing ground scheme's IMHHHO).
« Reply #55 on: September 16, 2013, 01:33:26 pm »
Peter, could be my english but I used the word "issue" more in the sense of topic than in the sense of problem and I was not talking only about this topic started by Mani but in general about other topics where we were talking about USB cables in general.
Sorry,  no more battery in my phone...
« Reply #56 on: September 16, 2013, 01:40:08 pm »
LOL!
« Reply #57 on: September 16, 2013, 02:00:09 pm »
No matter what I have tried, I was unable to hear a difference with the few USB cables I tried. The Clearlink plus USB cable is different with its concept and the philosophy behind.
The only moment I felt there was a difference was with AC cables that affected the sound. It added a "halo" around women's voices for a while, before finally settling...
I don't pretend there are no differences. I can only say that for my hearing capabilities (or lack of), I can't really "feel" the difference, but I certainly do not discard what is said about them.
I remember that someone said once that a cable will exhibit differences if it is straighet or twisted !
The link Jud put in another thread (http://www.audiostream.com/content/qa-john-swenson-part-2-are-bits-just-bits) is very interesting for this matter.
« Reply #58 on: September 24, 2013, 06:43:12 pm »
Received the
YFS USB REFERENCE - DATA ONLY CABLE from YFS today. ( 1m for $390,00 incl. shipping= €305,00)
This cable is a major step forward in SQ performance.
« Reply #59 on: September 24, 2013, 07:07:23 pm »
Ok Joachim. Thank you !
Can you now please describe the changes in sound with all the detail you can come up with ?
Thank you again,
