November 23, 2024, 10:04:50 am *
Author Topic: Batch file to use with Imdisk (ramdrive)  (Read 37985 times)
« Reply #15 on: September 03, 2013, 01:16:33 am »
Hi Juan,
Create a duplicate shortcut on your desktop for the programs that you wish to add to windows startup.  Drag the duplicate icon over the windows start button (in your win7 shell) - don't let go - then hover over "All Programs" - don't let go - hover over the "Start-Up" folder and drop the shortcut in there.
You can enable or disable the startup shortcuts using the "Start-up" tab in Task Manager.
Hope this helps.  There are other ways to do it, but I found this the simplest.
« Reply #16 on: September 03, 2013, 01:58:18 am »
Hi Anthony,
I was puzzled at first to find the startup menu, to finally realize that it was available through the Explorer 7 we use with XXHE Wink
But then I was stuck with another problem: How to determine  the order of execution when Windows starts... IOW, specify that the ramdrive batch file needs to start first, then after its completion, then XXHE can start ?
I found a solution, but how did you do it ?
« Reply #17 on: September 03, 2013, 02:06:41 am »
Alain, I just added them in the order that I want them to execute, so I put the batch file in first, then I did XXHE.  On my system it looks like both the batch file and XXHE are starting together, but if we really wanted to make sure the batch executed first we could just start XXHE from the batch file.
« Reply #18 on: September 03, 2013, 02:12:12 am »
Yes, that is the way I did it finally, but then I ran into another problem... The window showing the batch file execution was staying on the desktop... So I looked and found the "START" command.
START A:\xxhighend-09-a9\xxhighend.exe
I put it at the end of the batch file and all is good Happy
Now I wonder why I need to connect to the PC for it to really start... Maybe putting it in the public startup menu would do the trick ?
Edit: In fact it is logical to start only when the user access the PC, but I will do a few other tests to see with Public (Default User)...
Edit2: It does not change a thing to put the batch file in Public (Default User), except maybe it will start when the first user of the Widows session logs in...
« Last Edit: September 05, 2013, 12:39:37 pm by AlainGr » Logged
« Reply #19 on: September 03, 2013, 02:22:59 am »
I think your way is more elegant than mine Alain, so I will change my BAT file accordingly.
« Reply #20 on: September 04, 2013, 07:19:43 am »
Thank you Paul.
Notice that your line about XXData is wrong; it does not comply to advised settings, and now you will LOOSE your settings because of it. So, notice the advice about C:\XXData\ to be in Settings for XX Data folder (and not \XXData\).
Also it is better to not attch .bat files, because people might run them as such (instead of save). So better Zip them.
« Reply #21 on: September 04, 2013, 10:10:06 am »
Ah Peter OK - have removed post - before I always just let XX do its default thing with XXData and it worked OK - maybe now its time to read the instructions ha ha. Will check later.
« Reply #22 on: November 14, 2013, 10:53:52 am »
All, just a small notice :
The next version of XXHighEnd will save the (changed) Settings data automatically to the normal permanent storage location (folder) of XXHighEnd. So, no matter XXHighEnd was started from the RAMDisk folder and Settings are normally stored in there, they now will also be stored on disk and you won't notice a thing of it (apart from you will not loose your changes because you forgot to apply them to the "disk location version").
All IOW, there will be no need anymore for anything that I can see to write back the RAMDisk data to permanent storage by means of user procedure (which actually is the biggest pain at using RAMDisks, a bit depending on the type though).
« Reply #23 on: November 30, 2013, 03:12:11 pm »
Am getting ready to run Alain's batch file but am wondering if it automatically creates a copy of XX in one of the RAMDiscs or do I do that manually after the RAMDiscs have been created? If it creates a copy of XX on one drive automatically does XX have to be in a particular folder before I run the batch file? If, on the other hand, I have to create the XX copy manually, do I just copy/paste my current XX folder into the RAMDrive? Hope this makes sense. Thanks in advance.
« Reply #24 on: November 30, 2013, 03:55:00 pm »
Brian,
I didn't look at the latest version of the batch file, but it sure is meant to copy the XXHighEnd stuff in there. But, open it for "Edit" (see rightclick on it) and you will see a folder name which resembles the XXHighEnd storage location. If that is not yours, just change it to yours in there and save it. This is all quite harmless and the worst which can happen is that XXHighEnd won't be in there. But you will find that out soon enough.
Btw, as I know by now, click on your drive letter from Explorer to see the "Floppy" drives A: and B: in the right hand part of the screen. That will be the RAMDisks once created and you can just look in them.
Good luck !
« Reply #25 on: November 30, 2013, 06:10:32 pm »
oops
That was meant to be : Click on "Computer" from Explorer ...
« Reply #26 on: November 30, 2013, 08:34:15 pm »
Thanks Peter. Looks like I'll actually get to it first thing tomorrow.
« Reply #27 on: December 01, 2013, 02:24:57 pm »
Alaine, Peter, et al, batch file worked like a charm. After a good listen, I'll post later about SQ and Q5 in the appropriate thread.
« Reply #28 on: December 01, 2013, 02:42:10 pm »
Brian, good !
Notice that the message you will receive regularly because if A-B and changing between XXHE on disk vs on RAMDisk about the necessity to reboot - are actually about restarting of XXHighEnd. So no reboot is necessary at all and the message is just wrong.
May save you some time ...
« Reply #29 on: December 01, 2013, 03:20:13 pm »
Hi Brian,
I hope all will be for the better Happy I read a thread on another forum where people seem to discover virtues with a ramdrive, but I really feel we are spoiled to have the playback drive parameter that allows XXHE to take care of the copying process Happy
Page created in 0.139 seconds with 19 queries.
