November 23, 2024, 06:28:48 am *
Author Topic: Batch file to use with Imdisk (ramdrive)  (Read 37968 times)
« on: August 31, 2013, 03:40:28 pm »
This is the batch file I have written to allow 2 ramdrives. As Peter mentionned, my scope was quite too narrow and it could bring inconveniences as it could bring benefits.
This is assuming that one has installed Imdisk prior to anything that will follow...
I will do 3 things:
- Post the batch file as an attachment
- Print it in the next post with some precisions. It will be possible to "copy" and "paste" it as desired.
- Post my recommendations, adjusted to Peter's warnings (I hope).
First the attachment...
As you will see when unzipped, it does not carry the right extension. You need to remove the "NEW" from the ".batNEW" to have it workable. I did that to allow me to send it through email, since it was blocked...
(Date format is yyyy/mm/dd)
2013/09/02: The following has been changed in the batch file:
- Replaced "512m" (512MB) to "3g" (3GB) for XXHE and XXdata drive.
- The compressed batch file is XXRamDrv20130902.zip
2013/09/03::
- Added a line that starts XXHE (from the ramdrive)
- The compressed batch file is XXRamDrv20130903.zip
NOTE: for the moment, I leave all the versions as they evolve, but this will surely change.
* XXRamDrv.zip (0.66 KB - downloaded 792 times.)
* XXRamDrv20130902.zip (0.67 KB - downloaded 722 times.)
* XXRamDrv20130903.zip (0.68 KB - downloaded 794 times.)
« Last Edit: September 03, 2013, 12:28:43 pm by AlainGr » Logged
« Reply #1 on: August 31, 2013, 03:53:10 pm »
Now the printing...
(Shown here is the revised version 2013/09/03)
(start of the batch file) --------------------------------
@ECHO OFF
rem Creation of the "B:\" drive for playback ramdisk
rem Replace the number "2" in the "-s 2g" with a lower or higher value if desired
rem "2g" means 2GB of ramdisk
IMDISK -a -m B: -s 2g -o hd,rem -p "/fs:exfat /q /A:2m /y"
rem Creation of the folder "xxplay" in playback ramdisk drive
MD B:\xxplay
rem remove the word "REM" from the following line if you do not want any ramdisk for XXHE
rem EXIT
rem Creation of the "A:\" drive for XXHE and XXData ramdisk
rem After the "-s ", what follows is the size of the ramdisk
rem "m" after a number means amount of MB (Megabytes) of ramdisk
rem "g" after a number means amount of GB (Gigabytes) of ramdisk
IMDISK -a -m A: -s 3g -o hd,rem -p "/fs:exfat /q /a:512 /y"
rem -- At the right of the "=" in the following lines:
rem -- Specify the source drive where XXHE is located (JUST a LETTER)
SET XXDRIVE=C
rem -- Specify the XXHE directory to copy FROM (no "\" to begin or end)
SET XXHE=XXHighEnd-09-z9
rem Copying the content of physical XXHighEnd and XXData in ramdrive
XCOPY %XXDRIVE%:\%XXHE% A:\%XXHE%\ /E /Q /Y
XCOPY %XXDRIVE%:\XXdata A:\XXdata\ /E /Q /Y
START A:\%XXHE%\XXHighEnd.exe
(end of the batch file) ---------------------------------
This batch file creates 2 ramdrives:
- One for the playback (drive B:) = 2GB of ramdrive space
- One for XXHE and XXData (drive A:) = 3GB of ramdrive space
I have put emphasis on 5 parameters:
A) There are 2 lines that begin with "IMDISK". The bold parameter indicate the size of the ramdrive.
"2g" means 2GB
"3g" means 3GB
B) REM EXIT
If someone does not want to go further than creating a ramdrive for the playback drive, just remove the word "REM ". This will simply exit the batch file without doing what follows that line.
C) The paremeters in RED colour indicate where you specify the information needed to copy XXHE from your hard drive into ramdisk.
"C" is the letter of the hard drive where XXHighEnd and XXdata are located. If "C" is not the correct letter of the drive, you replace it with the right hard drive letter (D, E, R, Z...). Only one letter of course !
"XXHighEnd-09-z9" points to the directory of that hard drive that will be copied into ramdrive. For the moment, only this exact name will be copied into ramdrive.
For the moment, I will leave this suggestion: do not allow spaces in the title of the folder... "XXHE version 9" would not work, but "XXHEversion9" will...
2013/09/03:
Implemented from Anthony's idea about starting XXHE at user's login, the following line has been added to allow the start of XXHE from the batch file:
If you don not want this line to execute, simply insert a "rem" at the beginning of this line:
rem START A:\%XXHE%\XXHighEnd.exe
Edit: Every line that begins with "rem" is a comment line. It does nothing.
Edit2: Please read the 3rd post to complete these informations.
« Last Edit: September 03, 2013, 12:55:52 pm by AlainGr » Logged
« Reply #2 on: August 31, 2013, 04:48:32 pm »
Now some notes...
- The more you increase the capacity of your ramdisk(s), the less RAM you have available for the OS and the XXHE processes... It is a trade-off...
- Peter's post in another thread really has to be read to understand that what I wrote is not invariable forever. There will be modifications to come, like what Peter wrote about XXdata and that I am unsure of... If Peter mentions that XXdata should not be copied, then you can remove the following line from the batch file:
XXdata will not be copied, but you will then need to specify "C:\XXdata" in XXHE settings (the physical XXHighEnd that sits on your hard drive, not the one in the ramdrive).
- You need to specify the playback drive. Notice that I have taken the liberty to create a folder in the playback drive. It should be written like this: "B:\xxdrive\"
- You should ensure that the "Copy to xx-drive by standard" is turned OFF.
- If you want to modify something permanently, I suggest that you do so with the physical XXHE, then reboot the computer. This will prevent unwanted error messages...
- If you modify the batch file and want to restart it, you should reboot your system first
- Of course, it is necessary to execute the batch file each time you reboot (for the moment). When you reboot, the ramdrive(s) disappear since RAM if emptied from its contents each time.
- 2013/09/02: After doing some tests, I advice to define your ramdrives in Gigabytes (1g, 2g, 3g, etc)  instead of Megabytes (MB). Some values work, some others don't. If this happens, a windows will pop and ask to format a drive, confirming something is not right.
You can of course create 2 shortcuts:
- One that points on the batch file
- One that points on the copied (in ramdrive) XXHighEnd.exe file the first time. Of course, to do this, you need at least the first time to execute the batch file (to create this shortcut)...
I should point out that if something seems to be wrong and you are unsure it could be about the ramdrive, I would suggest that you reboot and try to re create this situation with the physical XXHE drive. This will help separate ramdrive related situations with situations that would otherwise not happen...
Remember to read what Peter posted prior to this. If there are contradictions, please report them. I did this post quite fast and will modify it with fellows comments, suggestions and corrections.
2013/09/03: for the moment the window that appears when the batch file is executing displays a lot of lines (quite rapidly), but I will make it more "silent" soon (will display a lot less) and maybe into a file (for support).
« Last Edit: September 03, 2013, 06:01:17 pm by AlainGr » Logged
« Reply #3 on: August 31, 2013, 04:52:42 pm »
Oh... And I am not always in front of my PC Wink It could take time for me to answer questions. I believe Peter will monitor this thread from time to time, but I hope it will not put a burden on him...
I have been a programmer in another life, so I can do a few things, but while I did this for me first and now hope it could help our community, I will count on you to help me to resolve the different problems that could occur. So be patient please Happy
And of course, Peter will have the last word Happy
« Last Edit: September 01, 2013, 03:43:21 am by AlainGr » Logged
« Reply #4 on: August 31, 2013, 07:37:34 pm »
Thanks Alain. As I said your software works beautifully well and I´m sure that this ramdisk contributes greatly to the good sound I have now. So far I haven´t had any problem with the sizes provided originally by Alain although, to tell the truth, I only charge one album at a time (flac or wav). Anyway, following Peter advise I´m going to increase the sizes of both ramdisks to 3Gb for the XXHE drive and 10Gb for the Playback Drive, that leaves 11Gb for XXHighEnd that should be enough, now I´m using again 24Gb of Ram.
I encourage other people to try it even if it is just for SQ, in my case it is better than ever as I say. Of course I do understand the point of view of Peter and, as you said Alain, the last word belongs to him.
Again I´d like to thank Alain publicly for his helpful work.
« Last Edit: September 02, 2013, 09:20:17 am by juanpmar » Logged
« Reply #5 on: August 31, 2013, 08:00:15 pm »
Great thanks Alain. And congrats on your achievement. Your efforts are not in vain now ...
(I know how much time Alain spent on it to get it flexible and right)
« Reply #6 on: August 31, 2013, 11:08:24 pm »
Alain, thanks for posting this.  I will try it out in the coming days.
« Reply #7 on: August 31, 2013, 11:09:03 pm »
It was about time I give back some of all I received from all of you no ?  blush1
I owe to a lot of people from this community.
« Reply #8 on: September 01, 2013, 08:20:53 am »
Hi Alain,
rem Replace the number "512" in the "-s 512m" with a lower or higher value if desired
rem "512m" means 512MB of ramdisk.
rem if you prefer to have a bigger XXHE drive, use 2g (2GB) instead
IMDISK -a -m A: -s 512m -o hd,rem -p "/fs:exfat /q /a:512 /y"
Strangely enough this part is dead wrong. You say "replace the 512 with a higher or lower number if desired. This is odd, because the Tutorial is all about that. Now the default will work out as wrong as it just is. So pleace replace that with 2G at least.
Now people may run into too few memory problems. But that is better than letting things go wrong unnoticed.
Do notice that not many people will be able to fuss around with .bat files. So they will start using it as it is, at least at first (and leave it be when it seems to work, which at first always is so ...).
« Reply #9 on: September 01, 2013, 08:22:24 am »
Alain,
As you told me by PM ... a definition of 2.4G etc. seems not possible. But what about 2400M ?
« Reply #10 on: September 01, 2013, 08:29:19 am »
Something I just thought of now, incurred for by a post in here (maybe it was Juan's) :
Indeed it is so that IMDisk needs to be installed under Normal OS. Next though, I found that (maybe by accident at first) the driver program gets removed by XXHighEnd's Minimized OS feature, and if not there then at the start of Unattended Playback. So I thought "OK, nice". However ...
Since the problems regarding the not reporting that the RAMDisk is full and things get overwritten (could even be normal memory as it seems), I am now thinking that this well can be because this driver program is not running. I mean, it seems strange to me that it does not need to. What is it for otherwise ? IIRC it isn't even active when booted into Minimized OS. So how can it all work then ? Is running the .exe sufficient ? Maybe. But maybe not ...
That driver program could be some kind of (protective) watchdog.
« Reply #11 on: September 01, 2013, 12:06:06 pm »
If the amount of memory is the main problem (perhaps not the only one), why not try the Ramdisk if only to see if there is a perceived improvement in SQ? Even if the amount of memory already installed is limited I think it´s worthwhile to test it.
If there is a better SQ then buy more memory to get at least 24Gb or even change the mother board if with the one you have it is not possible. I mean, just if the SQ perceived is noticeable better and you´d like to maintain this SQ. That´s around 300€ in the worst of case, buying an Asrock X79 EXTREME4-M (the one in the XXHE PC) and 16Gb of Ram, thinking that you already have at least 8Gb of Ram. I´m not saying to do it right now, I´m sure that this Ramdisk issue needs more experimentation but if after that the better SQ is consolidated, then to think in buying more memory wouldn´t be a bad idea. JMHO.
« Last Edit: September 02, 2013, 10:46:51 am by juanpmar » Logged
« Reply #12 on: September 01, 2013, 02:20:55 pm »
Hi Alain,
I wrongly assumed here... I will change it and will post as soon as I can.
« Reply #13 on: September 02, 2013, 07:18:28 am »
Alain and Peter,
Thank-you for the RAMDisk info and batch file.  A little bit of spare time came up today and I could not help myself so I downloaded IMdisk and Alains batch file and set to making a 2.8GB XX ramdisk and a 5GB playback drive using my 16GB of ram.  What do you know, a nice surprise and a I think a general lift in SQ which for me is characterised by a lower noisefloor, the background is more black.  Early days of course, but very promising.
One additional thing that I have done is to add Alain's batch file and a shortcut to XXHE (to the version on the ramdisks) to windows startup so both processes run automatically when the computer boots.  I just press the button to turn the computer on and then XXHE is sitting there running from the RAMDisks.  Nice!!
« Reply #14 on: September 02, 2013, 11:24:42 pm »
Alain and Peter,
Hi Anthony, would you please let me know how to add the batch file and the XXHE shortcut to the W8 startup?. I knew how to do it in W7 and how to delete files from W8 start up but I can´t find the way to add these files.
PS. Please put your signature whenever is possible, thanks
