« on: August 29, 2013, 12:08:33 pm » |
Hey Peter, what's going on? I've learned more about your way of thinking from the thread below, on another forum, than I have here on your own forum. Surely that's not on. Now, get your act together and share more of your thinking with us here too. http://www.stereo.net.au/forums/index.php?/topic/55227-phasure-dac/Or is it because you like Aussies more than the rest of us? I like them too, though they can no longer play cricket to save their lives... or rugby... or tennis... Mani.
« Reply #1 on: August 29, 2013, 01:12:21 pm » |
Woe is Aussie cricket to be sure.
But it sure has been great to have Peter over on our local forum for a little while at least. I know that I am learning a lot.
« Reply #2 on: August 29, 2013, 05:39:08 pm » |
Hey Mani - don't mention the cricket - we have to go there in November.
By the way that link does not connect to anything for me. Looks like Peter has brought the whole site down ha ha!!
P
« Reply #3 on: August 29, 2013, 10:45:23 pm » |
By the way that link does not connect to anything for me. Looks like Peter has brought the whole site down ha ha!! Peter enters the thread on end of page 2.
« Reply #4 on: August 29, 2013, 11:49:15 pm » |
P
I will be sitting in the stands at the Gabba for the first three days in November hoping that we put in a good showing in the First Test. Hoping...but not really expecting.
« Reply #5 on: August 30, 2013, 08:20:42 am » |
Hi Anthony - the site was down when I tried this morning it is back up so I shall have a read.
Could be a great series I will look out for you in the stands!! if you could hold up a sign that says XX that would help!!
« Reply #6 on: August 30, 2013, 10:59:41 am » |
Hey Peter, what's going on? I've learned more about your way of thinking from the thread below, on another forum, than I have here on your own forum. Haha Mani. But isn't it so that in Phasure I hardly ever (need to !) explain anything ? So in here is relatively nothing (I am serious). Btw, can you guys imagine that cheeseheads like the Dutch have no clue about cricket at all ? I guess that saves us quite some days without headaches. But I guess we compensate that with football (soccer). Ok, better stop following that these days ... Peter
Jud
« Reply #7 on: August 30, 2013, 12:16:07 pm » |
It's fine, Peter, I hear Steaua Bucharest is the new Barca, no shame in Ajax losing to them at all. (ahem) Anyway, Brazil 2014 should be a huge party!
Win 7 64-bit; i7-950@3.07GHz; 16GB RAM; OS on SATA 6GB/s SSD; AIFF files on external FW HDD; XXHE and Playback Drive on separate RAMdisks; no page file; Audioquest Dragonfly DAC/preamp; PSE Studio IV amp; Pioneer SP-BS22-LR bookshelf speakers or Etymotic Research ER-4P in-ear monitors. XXHE 0.9z-8-3a settings for the moment: Peak Extend; Arc Prediction; Redbook files upsampled 2x; KS Adaptive Mode; Phase Alignment off; buffer=512; Straight Contiguous; Playerprio=Low; ThreadPrio=RealTime; Unattended; OS minimized; all services off; Q1=17, factor=2; SFS=2.1; XXTweaks=Ultimate; Time Performance Index=Not the best.
