April 05, 2025, 06:17:52 am *
Author Topic: Settings  (Read 33118 times)
« on: August 25, 2013, 09:44:17 am »
Hey Peter - For a while I have been focused on setting up and tweaking my "new" speakers and as a result I have not made any changes to XX settings which I had thought I was happy with.
So last night I was thinking that the sound of my system was a tad hard and forward (actually a bit more than a "tad"). I changed my XX settings to those in your signature and what a difference!! - much much better now. The improvement is particularly noticeable with string quartets (trying to get to grips with Schoenberg and Berg!!!). I can't remember XX settings making such a profound difference before - maybe it is W8 or maybe my new speakers who knows but very happy with the result.
« Reply #1 on: August 25, 2013, 11:21:10 am »
Peter's settings do sound great; however, Q1 at 30 causes Hi Res stuff here to stop in the middle of a track. I posted about this weeks ago. An alternative which seems to provide a similar sound is to set the clock res to .5, Q1 to 14, but keep Q1 factor at 10 and, lastly, Q5 to 5. All other settings identical to Peter's. I also like the responsiveness of the GUI with the lower Q1 setting. Not sure if these settings sound as good as Peter's but they certainly sound very good here.
« Reply #2 on: August 25, 2013, 06:22:12 pm »
I think I vented my "real" settings at some stage, but/and actually they are the same as Brian just mentioned.
Must adjust my sig ...
« Reply #3 on: August 25, 2013, 09:50:18 pm »
Hi Brian - I have just loaded your settings and they sound fine. Previously I did have a problem with hi res at Q1=30 and I will see later if that is fixed.
The main thing is that strings now sound very very good - before I have to say they seriously upset the cat next door. And OK Mani unlikely to be as as good as SET/Horns but it is as good as I have heard here now.
Thanks
« Reply #4 on: August 26, 2013, 02:55:08 am »
I think I vented my "real" settings at some stage.....
Right, it's not like I made them up out of thin air: http://www.phasure.com/index.php?topic=2657.0
« Reply #5 on: August 26, 2013, 08:32:03 am »
Ha ha well I did read that post at the time but set Q5=3 and it sounded good at the time. I guess I forgot about the inconsistency warning. Sure my system sounded good for sometime but it went off in big style (washing machine and full moon together probably). Now it is fine though.
Thanks anyway.
P
« Reply #6 on: August 26, 2013, 07:20:54 pm »
Following Peter´s settings I´ve discovered a dramatic difference depending on the clock resolution value.
With this settings, which like others I´ve also found to be the best ones:
Q1=14, Q2,Q3,Q4=0, Q5=5, xQ1=10
SFS:120 (max 120)
XTweaks: Balanced Load: 45/ Nervous Rate: 100/ Cool when Idle:1/ Provide Stable Power: 1/ Utilize Cores always: 1
(See the complete settings in my signature)
If I use Clock Resolution at 0.5ms the sound is much more defined and 3D than if I use 1.0ms. With 0.5ms the background is blacker, the bass is more defined and vibrant and still the sound is silky smooth.
This is my best sound so far but it is reached also in combination with the other important settings like the use of XXHE and Playback Drive in Ramdisk.
« Reply #7 on: August 27, 2013, 02:36:35 am »
Hi Juan,
Could you please share your Ramdisk settings?  I've never used a Ramdisk and am only brand new to XX and the NOS1.  Is there somewhere here that I could find out how to do this?
Robert
« Reply #8 on: August 27, 2013, 08:58:06 am »
Yes I'm intrigued with ram disk and its implications. I downloaded Imdisk but can't get it to work. When I click on the icon in control panel it uninstalls. I do see that putting XXhighend and playback in ram disk is an advantage speed wise. Music wise speed has always been an advantage. I think this does need explaining more.
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #9 on: August 27, 2013, 11:17:34 am »
Hi Juan,
Hi Anthony,
I´m using a special software created by Alain (AlainGr) and as he is now on vacation would be better if we wait until he returns to ask him about it. This software permits to create two ramdisks at the same time, it places XXHE in one ramdisk and the Playback Drive in the other one. It works beautifully well, so my advise is to wait for Alain.
On the other hand to get the usual Ramdisk, (when I used it it was only for Playback Drive) you can do it this way:
Go to DRDataram and download the free software http://memory.dataram.com/products-and-services/software/ramdisk
To install it you have to bring back PC from minimized into normal mode. Previously you have to install Microsoft .NET 4 platform. If your PC is not connected to internet you can download an 'offline' installation found here:
http://www.microsoft.com/en-us/download/details.aspx?id=24872
Follow this steps:
- Change minimized mode to normal mode
- Install .NET 4
- Install RamDisk and choose either FAT16 or FAT32.
- Windows should report and list new HDD. Rightclick mouse format HDD to NTFS and 512b clusters (smallest)
- Try new HDD in XXHE (choose it for 'playback drive')
- Engage 'minimize OS' again
Robert
« Reply #10 on: August 27, 2013, 10:26:54 pm »
Thanks Juan, in searching the web some people suggest Imdisk is faster whether sonically this makes a difference.
Does Imdisk require .Net4 to work?
Is the playback ram drive 2g and XXhighend and data 500mb from your signature correct?
Perhaps we need a separate ramdisk subject topic unless I've missed it.
Interesting comparison here between different ram disks
http://www.overclock.net/t/1381131/ramdisks-roundup-and-testing
Oppo 205 UDP Dac
« Reply #11 on: August 27, 2013, 11:23:27 pm »
The IM disks seem to work fine here, followed the instructions on the site and it worked immediately. AFAIK I did nothing after the WIN8 install wrt DotNet.
Maybe important: I installed them OUT of Min OS thus in NORMAL OS. Running the whole package left me with two icons on the desktop. With the "ImDisk Virtual Disk Driver" you can make and delete disks of bring them back from an image.
They all show up after booting. Well, with the side note that after rebooting into win8 from leaving win 7 one of the two disks does not start on my system.
I'm experiencing some strange stuff on WIN8, which could be related to having XXHE on a ramdisk. With XX on the normal spinning OS disk I have less anomalies.
Since WIN8 is interactive as hell, I think I get the best sound with both XX and the playbackdrive on seperate drives. I still have to dig further for an SQ in WIN8 that suits me and might come to a different conclusion in the end (if I succeed into an end Grin).
Regards, Coen
« Reply #12 on: August 28, 2013, 01:42:24 am »
I use Imdisk but in someway modified by Alain making it easy to work with it. It creates two virtual disks named like two floppy discs A and B, you can give them the values you want but I gave them 2Gb for the Playback Drive and 500Mb for XXHighEnd/XXData. I gave this values because although previously I was using 24Gb of Ram now I downsized to 16Gb in order to use as less power as possible from the PSU, I´m just testing it and maybe I´ll return to 24Gb to give a bigger size to the Playback Drive. As I suggested, I would ask Alain about it when he returns from vacation one of these days, I´m sure he can give a much better explanation than me on how it works and how can it be installed.
Just in case you want to go ahead by yourself here you have information about Imdisk: http://www.ltr-data.se/opencode.html/#ImDisk
Robert
« Reply #13 on: August 30, 2013, 09:16:16 pm »
I managed to get Data ramdisk working and sure is better sounding aside from the extra wait for music to load.
How can I get two ram disks working the other with Xxhighend in it?
Oppo 205 UDP Dac
« Reply #14 on: August 30, 2013, 10:44:14 pm »
Just add one with the "ImDisk Virtual Disk Driver" utility (also on the IMdisk site). They even both seem to boot if you check "virtual disk drive access image directly" AND boot from WIN8 into WIN8.
And use a different drive letter off course.
In the timebar thread Peter advices to have the XX program IMDisk at 2Gigs (minimum?). For now this seems to cure some problems (not shure yet).
Regards, Coen
