November 23, 2024, 02:33:28 am *
Author Topic: Win 8, Unattend Playback Reboots My Computer  (Read 9270 times)
minzyman
« on: August 19, 2013, 06:41:22 am »
Has anyone experienced the situation with a new Win8 Pro rebuild whereby your newly activated XXHighend player, when run in unattend mode, automatically logs you off and drops you at the Login page of Win8? I cannot play in unattend mode, XXHighend crashes very quickly and the login page pops right up, asking me for my Win 8 login.
I rebuilt my machine using all the suggestions on the Win 8 Pro tutorials section, finally got red type saying that I had activated (I just kept pasting the activation code, about 6 times, then rebooting). Am running the Win7 shell and all is working smoothly now, except unattend playback.
When I log back in, the desktop comes back up and I see an error msg in lower right corner:
Windows couldn't connect to the system event notification service… etc.
Thoughts? Experiences anyone?
Thanks.
/LM
W8 = Jan 10, 2013 (1.186a)
Zalman (Fanless) Chassis with ZUMA Design: Intel DH77EB MB and Intel i7 3770s (quad core) CPU / 16GB RAM / Win 8 Pro SP1 from OCZ SSD / second (Playback) drive OCZ SSD / music on 3 TB eSata HD / XX on OS disk SSD Engine#4 Adaptive Mode / Q1/-/3/4/5 = *6*/-/*1*/*1*/*1* / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = *4.0* (max 120) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = *Core1-2* / UnAttended (Just Start) / All Services Off  / No Running Time / Minimize OS / NO XTweaks / 24/768 Phasure NOS1 async USB DAC, Driver v1.0.3 at *8ms* -> main amps -> speakers. No remote, screen off at unattend playback, cd rom unplugged, ethernet cable unplugged, max core temp 117 degrees F.
« Reply #1 on: August 19, 2013, 09:07:22 am »
I've had this happen twice in the last couple of weeks but I just press the power button on the pc to shutdown (rather than logging in) then restart and it all seems to work.  Unfortunately I am too new at this software to help you too much.
stefanobilliani
« Reply #2 on: August 19, 2013, 09:31:23 am »
detailed experience : you have to shut down windows defender manually .
May 27 -2013 ,  0.9z-9
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
Q1=8 , Q5=3 , res 1msec
« Reply #3 on: August 19, 2013, 10:53:27 am »
I'm sure if it's exactly the same, but I've had W8 installed since February (so not a new W8 Pro build) with no issues whatsoever, but only yesterday I was automatically logged off when entering an Unattended playing session (in Minimize OS mode).
I simply rebooted, went into normal OS mode, went into the W8 shell, and then back into the W7 shell. Booted up XX, went into Minimize OS mode and everything is working as expected again.
As I said, I've no idea if this is related to what you're experiencing, but if it is, at least there seems to be a simple solution.
Why this should have happened almost exactly 6 months after installing W8 Pro, I have no idea.
stefanobilliani
« Reply #4 on: August 19, 2013, 11:32:47 am »
Hello ,
see also : http://www.phasure.com/index.php?topic=2588.0
we examined by email the problem and it turned out that it was Windows Defender interacting with XXHE .
Stefano
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
minzyman
« Reply #5 on: August 19, 2013, 03:08:29 pm »
Thanks Guys, for the responses. I will try these suggestions and report back.
/LM
« Reply #6 on: August 19, 2013, 05:45:29 pm »
Lee,
Maybe it is behind the link I did not follow, but I know of at least one situation where Defender can not be shut down
By heart : put (windefend) in Services to Keep, and find the adjacent process for it (something with a Q In it). Put that in Processes to keep (between () ).
minzyman
« Reply #7 on: August 20, 2013, 03:31:10 am »
Easiest thing to do is turn off Windows Defender. That worked perfect for me— no protection! (Reminds me of high school...)
Sound is great now.
/LM
Page created in 0.126 seconds with 19 queries.
