November 23, 2024, 12:19:00 am *
Author Topic: Running Win8, XXHE shows 32bit WinXT  (Read 6483 times)
CaOd
« on: August 14, 2013, 08:34:15 pm »
Dear all,
more strange things on my end... or maybe quiet normal?
I have a clean install of Win 8 on a 64 bit machine, activated XXHE, run the Win7 shell, but XXHE says its running on 32bit WinXt...
Any idea? I think I saw Win8 in XXHE yesterday... And the Metro shell came back on after rebooting (computer shut down due to battery draining last night...)
Thanks Carsten
August 26, 2013 (0.9z-9b)
MacBookPro 15" i7 2,4Ghz,16GB,Win 8 Pro 64bits, OS on internal SSD, XXHE on internal SSD, Music (WAV) on spinning disc, loaded on Ramdrive,
Engine#4 Adaptive Mode / Q1/2/3/4/5 = 15/0/0/0/5 / Q1Factor = 10 (Dev.Buffer = 256) / ClockRes = 1ms / Straight Contiguous / PA off / SFS = 120 / not Invert / Playerprio = Low / ThreadPrio = Real Time / Scheme = 3 / UnAttended (Just Start) / All Services Off /XTweaks : Balanced Load = 45 / Nervous Rate = 100 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = On / Minimize OS = On / 4 times Arc Prediction Upsampling  -> Weiss DAC202 (modified by Klang&Kunst) -> Jadis DA50Signature -> Audioplan Kontrast V
« Reply #1 on: August 15, 2013, 03:00:24 am »
Carsten,
This can happen, but should not;
If you boot into Normal OS, I assume it is all right again. If you then boot into MinOs, is it then back to wrong ?
CaOd
« Reply #2 on: August 15, 2013, 07:22:28 pm »
Thanks Peter,
yes, it goes back to reading Win8 when booting into normal and is ok when then booting into MinOS. So it seems to be all ok.
Just sometimes Win8 shell comes up unintended, running the Win7Shell program again brings back Win7, so I hope everything is ok.
Is it correct, that the task manager shows all programs of XXHE (XXHE, Engine 3, HKey) as 32 bit?
Thanks Carsten
« Reply #3 on: August 16, 2013, 07:48:08 pm »
Yep, the XXHE programs are 32 bit in order to be compatible with all features possible.
What I noticed with the Metro Desktop coming back on is that this can happen with the wrong Explorer instance used. So, don't use File Explorer but Explorer. You can find the .exe for that in the folder you denoted installing the W7 Shell (which you kept default).
But notice that it is not completely clear to me what you said about "brings back W7".
Page created in 0.109 seconds with 19 queries.
