November 26, 2024, 11:53:37 am *
Pages: 1 2 [3]  All
Author Topic: PC motherboard upgrade  (Read 43184 times)
0 Members and 20 Guests are viewing this topic.
« Reply #30 on: September 16, 2013, 10:13:44 pm »
Yes, that's what I initially did, just plugged the ASUS HD with OS into the ASROCK and everything worked fine. Because I needed a backup drive, I subsequently reinstalled the OS to a new drive and copied all music to it as well. It works cause the chipsets are identical.
« Reply #31 on: September 16, 2013, 10:42:29 pm »
Hi Brian, thanks for jumping in so quickly. It's getting late here, but I'm tempted to swap the mobos out right now, knowing that there'll be no software installing to be done.
Cheers, Mani.
« Reply #32 on: September 20, 2013, 08:27:39 pm »
An update...
I did go ahead and swap the Asus mobo out for the ASRock mobo last week. Everything went smoothly up until I tried booting up and got nothing happening. My first thought was that I had buggered up the CPU or something. But then I realised that I wasn't even getting the BIOS screen appearing. Looking at the mobo, I saw an error code being displayed on the LEDs. Consulting the manual it seemed that I had a memory error. Looking deeper I realised that the ASRock mobo doesn't accept the 4x DDR3-2133 memory cards I had transferred directly from the Asus mobo. Fortunately, the music PC in my office had 4x DDR3-2400 memory cards and was happy with the DDR3-2133 cards, so I just swapped them around. After this, everything worked fine. Phew!
I didn't do any tweaking other than disabling all the USB2 ports  and one of the two USB3 ports (first in Win8 and then in the BIOS). I'm not using a USB3 PCIe card, and there remains just one SATAIII HDD connected to the mobo. The keyboard and mouse are both connected via PS/2. The NOS1 is connected via a single run of regular 5m USB2 cable (no separate data and power lines or anything fancy, though my 'USB grounding scheme' remains). And the sound...?
Well, I agree with everything that Nick and Brian say 100%. This is no placebo. This mobo really is better than the Asus, it's as simple as that.
Furthermore, in my 'USB cables... again' thread, I mentioned that I could 'hear' my mouse and HDD, etc through my horns if I used a regular USB cable (with both data and power lines) between the PC and NOS1. Well this has totally gone - proof that this mobo really is quieter/better than the Asus?
Thanks for all the encouragement to get off my backside and do this guys.
« Reply #33 on: September 20, 2013, 09:40:27 pm »
Mani hi,
I'm pleased it has worked out so well. im guessing there must be a lot pf delighted XXPC owners using this board too. It been interesting that we have all had the same experience, mobos really do matter it seems.
Good that you had spare memory Dimms to try. Just worth mentioning that here it seems to be better for SQ to only fit 2 Dimms not 4. Its possible just to take two out, the mobo sorts out what is fitted automatically.
It would be great to get together when you get back from your business trip. I would realy value you opinion on the sound of my NOS1 and it would be nice to take a look and listen to at your amps and Swings.
Best,
« Reply #34 on: September 22, 2013, 01:01:07 am »
Glad to hear it's worked out for you too, Mani. The only Bios tweaks I've done, to good effect, was reducing the CPU ratio and memory frequency by half.
[Edit] I have from the beginning had all usb2 and 3 options disabled, but just today I enabled one usb3 MB connection and plugged my generic usb 3 cable into that mb connection. I also  switched the HD/OS/Music connection from SATA III to SATA II. Both tweaks seemed to improve SQ. I tried taking the Startech Renesis pcie card out but, when I did,  s's became terribly sharp. I put the card back in and that problem went away, though nothing is connected to either Startech usb connection. Don't know if the card causes more or less noise. For me, eliminating all noise generally means turning the amp off and reading a book.  Happy
« Reply #35 on: September 27, 2013, 09:46:41 pm »
After fitting the new AsRock X79 Extreme4-M board I noticed that it is the same board that I think Peter uses/supplies in the the Phasure Music PC so I now have some sense of how good these PCs must be sounding for the people who have bought them.
Hi guys!
Inspired by your findings, I have decided to purchase this Mobo too. I will go for the non-M version.
Any other advices? -Which processors should I buy for it?
Today I am running all software on Flash memory. Should I put the XX on a regular HardDisk? -Which one to purchase, then?
Any input is appreciated!
« Reply #36 on: September 28, 2013, 02:49:19 pm »
Pedal, I think the cpu mostly used by XX'ers is the 3930,3.2 Ghz, as in my signature. However, I believe Mani uses the 3960 and Anthony-"acg"- the Xeon 8-core 70w 1.8Ghz which is a lot cheaper. So there doesn't seem to be one "recommended" cpu. I think the same may be true of HD's. I use a 3tb Seagate barricuda where I have both XX and music files, but that's a bit out of the norm I think.
Good luck with your upgrade, I believe you will have good results!
« Reply #37 on: September 28, 2013, 04:26:22 pm »
Not so. Besides I don't think this 1.8GHz can be obtained officially anymore, this comes from is a "China" source. Could be good anyway, but it was not new and *then* much cheaper, yes.
« Reply #38 on: September 28, 2013, 06:20:15 pm »
Sorry about that bad info. A little knowledge can be worse than none at all!
« Reply #39 on: September 28, 2013, 06:56:14 pm »
No worries. I operate not hindered by knowledge.
Haha.
« Reply #40 on: September 28, 2013, 10:50:08 pm »
Correct about the Xeon cpu Peter.  It is sold as an "Engineering Sample" but may well be a clone of some type, I really don't know.  It is cheap, low powered, and seems to run cool and work very well.  The real bonus is the low power:  if we all start to mess with linear supplies down the track then this psu uses a fraction of the current that the big i7-3930K uses so the likelihood of powering it directly by linear psu is much easier and much cheaper.
« Reply #41 on: September 29, 2013, 12:05:11 pm »
Maybe not continue this "power usage" in this topic. It is very much correct what you said, but at least I will be confused where to be since we're talking about the same in that other topic. Ok ?
« Reply #42 on: September 29, 2013, 12:16:30 pm »
No problemo!
Pages: 1 2 [3]  All
Page created in 0.127 seconds with 19 queries.
