November 23, 2024, 09:56:28 pm *
Author Topic: changeWP error  (Read 7511 times)
charliemb
« on: July 25, 2013, 02:17:34 pm »
BACKGROUND
I'm seeing a new changeWP error which first occurred after couple of blue screens which came after my attempt to play the last two songs of a playlist.  When I tried to play the last two songs over again with different interpolation settings (I was trying 4x 2x 1x, PE on/off, arcP on/off, etc.) that's when the blue screens started.
PROBLEM
Forget about the blue screens.  Now that I've recovered, the problem is that the desktop remains while unattended AND that I get the following error for each new track (paraphrasing):
changeWP Error
The paramater value must be < Width.
Parameter value: x
I'm also seeing these error messages popup during attended as well,  also one for each song or more than one.
July 2019:
« Reply #1 on: July 25, 2013, 03:31:37 pm »
Charlie,
I am not sure about this solution : Denote "Do nothing with Coverart at all" in Settings, play a little bit, Stop and Quit XXHE. Restart and do the same. Restart and now switch back on Coverart.
Maybe it is solved now, or at least I hope it is. When not we'd have to see further.
charliemb
« Reply #2 on: July 25, 2013, 11:49:43 pm »
thanks.  I'll try it.
July 2019:
charliemb
« Reply #3 on: July 27, 2013, 12:21:19 am »
That worked.   Thanks again.
I looks like the problem comes about because I have cover art that is short and wide, probably 800 pixels wide.  My settings were and are for 700.
P.S.
Why this leads to blue screens is another mystery.
July 2019:
« Reply #4 on: July 27, 2013, 09:04:16 am »
Ah great.
Blue screens : Not sure, but I reckon that Wallpaper I create should not be larger than the screen's size or otherwise the OS does not anticipate on it ?
I've put in on my ToDo to check for that.
Thank you for the feedback.
