November 23, 2024, 06:33:28 am *
Pages: 1 2 [3]  All
Author Topic: A Visit to Nicks and a Surprise Finding  (Read 43639 times)
« Reply #30 on: July 31, 2013, 03:54:11 pm »
Juan, yes, its the Platinum version of that 400 watt model.
« Reply #31 on: July 31, 2013, 04:05:12 pm »
One other thing. The Seasonic vents from the top
It was a shock to me when I opened the box so I had to buy a new case I recommend Antec One which is cheap (I love cheap!) and very well designed and laid out. Why pay more!
Nick and I have visited each other a few times now and we both agree that both of us have made big improvements to  our systems as a result. "Two Heads Are Better Than One" is the saying and that is certainly the case for us.
Anyway Nick's turn to come here next to listen to my new speakers which are nearing completion.
There have not been many responses to my recent post about speakers - you could be missing something very special - but Nick will get a chance to listen to S5's and S4's in separate locations and I am sure he will post comments on what he hears.
« Reply #32 on: July 31, 2013, 04:23:45 pm »
Paul,
I could not agree more ! and I cannot wait to hear your new speakers next trip down. Thanks again for lugging all of you fine kit to mine. Its so useful having known reference points to work with.
Best,
« Reply #33 on: July 31, 2013, 05:17:01 pm »
One other thing. The Seasonic vents from the top so if your case requires a top mount PS, like mine, you will likely need a new case. My Seasonic is currently sitting on top of the PC, on a mouse pad should case vibrations cause it to want to slide around. Need to start looking for a new case.
Brian ... huh ?
With all the trials and attempts for the better PSU I've run into these as well. But all I did was putting them upside down. Looks odd, but just works.
The BeQuiet (but please sort out whether it really is the same !) normally vents downwards. And the best thing of it, it is small(er) formfactor so it will fit all.
« Reply #34 on: July 31, 2013, 05:22:36 pm »
Peter, is your bequiet! also fanless?, what model is it?
« Reply #35 on: July 31, 2013, 05:29:58 pm »
Juan,
Oh wait ... about venting down or up or side ways ...
Are you guys referring to fanless designs ? OF COURSE *they* vent upwards.
Apologies if I have been confusing in this context.
No, the BeQuiet is not fanless. But you won't hear one thing of it (the whole XXighEnd PC is speced for under 19dBA).
« Reply #36 on: July 31, 2013, 05:31:26 pm »
I see, thanks Peter
« Reply #37 on: July 31, 2013, 06:37:29 pm »
Yes, you see. But I do not !
So ... are you guys talking about fanless designs ?
(sorry for asking again, but I feel a bit stupid now at having made the (possible) mistake)
« Reply #38 on: July 31, 2013, 07:32:34 pm »
Peter, yes, we are talking completely fanless designs. I'm amazed at the difference in SQ cause my Coursair PS fan only turned on above a certain temp, and, as far as I could tell, it never got hot enough to ever turn on!
« Reply #39 on: July 31, 2013, 08:28:56 pm »
In my pc case the Seasonic could go in the upper part the same way as the Corsair (I guess). All the four sides of the ps will be vented that way.
« Reply #40 on: July 31, 2013, 08:52:50 pm »
Juan,
Looking at the pictures of your case with ventilation on all sides I would think the Seasonic supply will get on fine in there. Mine is at the bottom of the case with no fans in the entire  pc and is fine for heat.
Jud
« Reply #41 on: July 31, 2013, 11:12:38 pm »
Re the manufacturer(s) for BeQuiet -
The smaller ones, including the Pro P10 550W are made by FSP which is Be Quiet's favorite OEM while the higher capacity ones are made by Seasonic, one of the best PSU manufacturers with great experience and high performance products.
I believe the SS models of BeQuiet begin above 550 watts, and below that they're made by FSP (Taiwanese if I remember correctly).
« Reply #42 on: August 08, 2013, 11:07:12 am »
I have the fanless Seasonic SS-400FL2 installed for one week now in my music pc. The first impression was of a more detailed sound, but after that first moments I realized that the differences, in my system, are minor if any. It is true that I´m making  at the same time changes in the bios with Nick´s settings, that could condition my opinion but I also made those changes with the Corsair AX750 with no appreciable differences among both ps. At the end what´s my opinion about these two ps?, well, if I´d have to buy a new ps I´ll buy the Seasonic, but if I´d have a Corsair AX-750 and it was working well (as was my case) I´ll keep the Corsair. Now that I have both ps I´ll keep using the Seasonic for two reasons, it is not worse than the Corsair in any case and I´m lazy to change the ps again. On the other hand the Corsair is enough powerful to don´t use the fan, in fact when I removed the Corsair from the case after more than two years of continue use the fan was absolutely clean, no dust at all, it means that the fan wasn´t used at all or seldom used. So if for some reason you want to have a more powerful ps than the fanless Seasonic I think the Corsair is still a good choice.
I respect other´s opinion but this is my experience. I hope it helps other Corsair owners.
Pages: 1 2 [3]  All
